No more oily rag
Discussion in 'Classic Motorbikes' started by Dr Ivan D. Reid, Aug 20, 2005.
  1. DT175 now has a Genuine Yamaha oiled-foam air-filter element,
    courtesy of the fine ladies at the Kawasaki shop opposite West Drayton
    station. Cost £7.53 -- M&P wanted £9.99 (plus postage one presumes).
    Now, how does one measure transmission oil level with a Yamaha
    dipstick? Screw it all the way in, or just rest it on the threads (like
    a Honda)? I've got enough oil left over from Black Kat's last change so
    I might as well make sure it has fresh oil in it.
    What's the weather like in Bedfordshire?
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
  2. Dr Ivan D. Reid
    Dry, light breeze, overcast.
    Pip, Aug 20, 2005
  3. Much like here then.
  4. Dr Ivan D. Reid
    Nick Guest
    I used to work there in the late 70's When it was called ABC Formerly R G
    Smith, big in Nortons.
    So what? Yeah I know!
    Nick, Aug 20, 2005
  5. Dr Ivan D. Reid
    Well the sun's gone for a rest behind a few clouds and I'm expecting
    it to piss with rain later in the afternoon when I collect the bike
    after they've finished servicing it. That's if they finish it today
    because I raised a small 'issue' and it might take more than an
    afternoon.
    Andy Bonwick, Aug 20, 2005
  6. I get the same feeling here. Just took the DT across to the Garden
    Centre on a shake-down and came back soaked -- the humidity is so high.
    Oh well, guess I'll be off in a little while dodging showers...
  7. Dr Ivan D. Reid
    Dr Ivan D. Reid says...
    That Michelle's[1] ok, isn't she? I quite fancy her.
    Rest it on top of the threads on all the Yamahas I've had, in a Honda
    stylee.
    Good
    [1] The younger of the two, the other one is her mother. Mind you, her
    mum's lovely too.
    Lozzo, Aug 20, 2005
  8. Dr Ivan D. Reid
    Dr Zoidberg Guest
    My SRX manual said to rest it on the threads rather than have it screwed in.
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Aug 20, 2005
  9. Yes, not bad at all. Tho' I only noticed the old Triumph up
    above the shop today -- I'd probably take that instead. :)
    I seem to have overfilled it a bit -- either the Haynes book
    has the wrong capacity or I'm shit at estimating 600 ml! Still, it got
    me there and back, at just on two hours each way -- total of 114 miles.
    Let's see, it took 4.8 l at 64 miles = 13.33 m/l = 60.5 mpg = 21.4 km/l.
    It was cold enough that I volunteered to do the cooking, to stay
    near the warm barbecue... Now; I'm home, where's the booze?
