nitrogen
Discussion in 'Motorbike Technical Discussion' started by Cyril Bonnett, Dec 20, 2003.
  1. Hi
    Is there really any benefit of users of road going bikes to inflate their
    tyres with nitrogen? are there any negative point about using it??
    cyril
  2. Cyril Bonnett
    Don Fearn Guest
    Not sure *what* was going on, "Cyril Bonnett"
    Nitrogen is F_A_S_T
    In winter your tires will explode
    -Don (don't believe everything you read in a newsgroup)
    I, Pooder, aPproved this Post . . . .
    Don Fearn, Dec 20, 2003
  3. Cyril Bonnett
    Don Fearn Guest
    Not sure *what* was going on, (Kaybearjr) leapt
    in with:
    [snip some serious stuff]
    I think this means "no". The question was for "road going bikes" and
    while all that might be significant for someone riding in a race at
    the very edge where a few milliseconds can make the difference between
    first and second, on the street it would be totally lost . . . .
    -Don
    Pooder aPproved this Post . . . .
  4. Cyril Bonnett
    OH- Guest
    "Kaybearjr" <> skrev i meddelandet
    Sorry, I might be dense but I don't get this.
    OH-, Dec 20, 2003
  5. Cyril Bonnett
    John Johnson Guest
    In the case of a high-volume, high-pressure tire, even if you don't
    remove all of the "regular" air (at atmospheric pressure) in the tire
    before adding dry nitrogen, you end up with the vast majority of the
    stuff in the tire being nitrogen.
    In a smaller, lower-pressure tire, the proportion to nitrogen to
    atmospheric air is much lower, which significantly reduces any benefit
    you intended to get from using nitrogen in the first place. To raise the
    proportion, you have to fill and empty the tire a couple of times
    (creating one of those really nasty mixing problems that they give you
    in chemistry).
    I do have a question for kaybear, though. Did you guys air up those
    tires to 175psi absolute, or is that guage? I'd have thought that it
    would be guage psi, which should change your math a little bit,
    shouldn't it?
    John Johnson, Dec 21, 2003
  6. Cyril Bonnett
    Les Guest
    Seems like I've read that nitrogen won't change in pressure as much as air
    does. This allows better control of the tire pressure for tuning purposes.
    Les
    Les, Dec 22, 2003
  7. Cyril Bonnett
    Ben Kaufman Guest
    Ben Kaufman, Dec 23, 2003
  8. Cyril Bonnett
    Les Guest
    I just did a quick search on Google and found this...
    http://www.branick.com/n2/faq.html
    Les
    Les, Dec 24, 2003
  9. Cyril Bonnett
    AnyBody43 Guest
    I just did a quick search on Google and found this... I suspect:
    Above web site should be read as 'marketing' material.
    Nitrogen used in competition tyres mostly to ensure no water (less)
    present since I think that as the tyre tempreture changes the water
    will cause greater pressure changes than would occur with a pure gas.
    I lost my steam tables years ago and would not know what to with them
    now anyway.
    I thnk that some racing bicycles use helium filled tyres due to the
    weight saving. Now they do leak a lot.
    AnyBody43, Dec 24, 2003
  10. Cyril Bonnett
    Steve Guest
    Why would anybody want to inflate their tyres with Oxygen ? Most people use
    air which has a high nitrogen content anyway...
    Steve
    Steve, Dec 24, 2003
  11. richard cortese wrote
    hey the merkins are up.
    happy chrimas dudes.
    i wave a glass ion your fgeneral direction.
    You can all **** off now.
    steve auvache, Dec 25, 2003
  12. Cyril Bonnett
    Ben Kaufman Guest
    Yes, that's what they mean, through the tire, but they seem to ignore that air
    is over 70% nitrogen and this means that the partial pressure of the oxygen is
    much lower and that will slow diffusion down. But let's play Devils advocate
    and say that air diffuses out of a tire 2 times faster than pure nitrogen. It's
    inconsequential because the rate of diffusion is slow to begin with. It would be
    much more susceptible to changes in pressure by day to day air temps. Also,
    anyone who is considering using "exotic" gas in their tires is already probably
    checking them fairly regularly.
    Ben
    http://autos.groups.yahoo.com/group/rockland_mc_riders
    Ben Kaufman, Dec 25, 2003
  13. Cyril Bonnett
    Ben Kaufman Guest
    That does not make sense. Water vapor gas obeys Charle's and Boye's laws like
    Nitrogen.
    Ben
    Ben
  14. Cyril Bonnett
    PymerOne Guest
    Shame on you Jack, throwing rocks at a perfectly nice girl like that!!!
    Dang you made her cry boy...
    Good for you & congrztzz
    Grtz, P1
    PymerOne, Dec 25, 2003
  15. Cyril Bonnett
    bowman Guest
    One wonders about a tire with a pint of slime in it.
    bowman, Dec 25, 2003
  16. Cyril Bonnett
    Ben Kaufman Guest
    Yes, it would be an entirely different matter if there was sufficient liquid
    inside the tire but how likely is that to be?
    Ben
    Ben Kaufman, Dec 26, 2003
  17. Cyril Bonnett
    Ben Kaufman Guest
  18. Cyril Bonnett
    Ben Kaufman Guest
    Jack, I'm not accusing anyone of being full of hooey. I'm just asking questions
    with the ultimate goal of either debunking or learning something.
    I did a search on the net and yes, indeed, lots of pro racers are filling their
    tires with nitrogen. However, invariably, the reason given is that water vapor
    expands differently under temperature than "dry" air. In and of itself, this is
    not a correct statement. Water vapor is a gas and will obey gas laws.
    Some of the sources cite problems with humid days. Well, this may be the
    answer. Humid air has larger amounts of water vapor in it and as the vapor
    content goes up at 1 ATM, under increased pressure, it is more likely that there
    will be condensation.
    Ben
  19. Cyril Bonnett
    Ben Kaufman Guest
    OK, so I learned something :).
    Ben
  20. Cyril Bonnett
    AnyBody43 Guest
    I cannot remember this stuff much at all however the behaviour of
    water as its temperature rises above boiling point (at whatever
    pressure you choose) is not as one (well I) might expect.
    At 100 C it does not suddenly all become vapour. At room pressure <g>
    just over 100 C there is some kind of mixture of liquid and gaseous
    water the ratio being mostly? liquid water and a bit gaseous water vapour.
    As the temperature rises the ratio of liquid to vapour falls until at
    some higher temperature we eventually have all vapour.
    I have no idea how a mixture of water and air might behave however
    I suspect that there will be some liquid water in every road
    bike tyre in the UK due to the above effects.
    The state where all of the water in steam is in the gaseous state is
    known as superheated steam. The temperature required to maintain
    this state increases with increasing temperature.
    As has been stated I believe that the reason that Nitrogen is used by
    the racing people is that it is dry. I suspect that the reason that
    this is important is that there is liquid water in the tyre
    even if it is not visible as a pool running round at the bottom.
    AnyBody43, Dec 27, 2003
