Nitrogen inflation
Discussion in 'Australian Motorcycles' started by James Galloway, Aug 28, 2003.
  1. I've heard a lot about this, but only in reference to car tyres; has anyone
    done this with their bike? Is it worth it?
    Thanks
    J.
  2. James Galloway
    Dane Guest
    nah. its not worth it.
    its soooo two weeks ago
    Dane, Aug 28, 2003
  3. James Galloway
    Marty H Guest
    I put 80% pure Nitrogen in my tyres...works well for me
    Marty H, Aug 28, 2003
  4. James Galloway
    knobdoodle Guest
    James Galloway wrote in message ...
    It helps prevent the bends when you resurface.
    Clem
    knobdoodle, Aug 28, 2003
  5. James Galloway
    sharkey Guest
    Of course, that's just the license fee ... you'll have to arrange
    to put it into the tyres yourself.
    -----sharks
    sharkey, Aug 28, 2003
  6. James Galloway
    RM Guest
    yes, I use 80% nitrogen in my tires too, in fact i have a nitrogen
    pressuriser suitable for inflating motorcycle tires, yours for the low low
    price of $400
    Someone let James Galloway at loose on an internet
    connection and the result was:
    RM, Aug 28, 2003
  7. James Galloway
    knobdoodle Guest
    iCentral wrote in message
    Nothing; just kinda sits there (it's inert!).
    HelpDoodle
    knobdoodle, Aug 29, 2003
  8. James Galloway
    Dave Mojo67 Guest
    This started a huge thread two weeks ago. The gist was that there were lots
    of opinions but no one convinced me it was worth the cost and inconvenience.
    Give it a go for a while if you want, but I reckon just making sure you
    constantly have the right pressure in your tyres is much more important.
    Dave Mojo67, Aug 29, 2003
  9. James Galloway
    Conrad Guest
    Actually nitrogen is the main cause of the bends when you resurface,
    the benefit is it gets you 'drunk' whilst down due to Nitrogen
    Narcosis - and no handover!
    Conrad
    Conrad, Aug 29, 2003
  10. James Galloway
    knobdoodle Guest
    You're right; it was helium I was thinking of.
    Thanks ..... Clem
  11. James Galloway
    Conrad Guest
    Nitrogen is used to inflate aviation tyres for two reasons:
    Primimary reason is to eliminate a chemical reaction between the gas
    used to inflate the tyre and the inner tyre linning i.e. prevent
    explosion and combustion --- remember aviation tyres are subjected to
    huge stresses on landing (accelerate from 0 to the plane's speed in a
    split second and huge weight loadings). Aviation tyres may be
    inflated with a max of 5% oxygen under the aviation regulations (this
    does not apply to all planes such as ultralites etc.).
    Secondary reason is the use of dry nitrogen has a very low moiture
    content and without oxygen present the risk of oxidation damage to the
    interior of the tyre is reduced.
    The value of using pure nitrogen for a bike's tyres IMHO is bugger all
    -- stick the 80/20 nitrogen/oxygen gas mix readily available at every
    petrol station and check your tyre pressures every time you full up or
    ride.
    Cheers,
    Conrad
  12. James Galloway
    Theo Bekkers Guest
    "Conrad" wrote
    I have always wondered why they don't spin the tyres up before
    touchdown. Surely you would only need to put a couple of small vanes
    on the wheels.
    Theo
    Theo Bekkers, Aug 29, 2003
  13. James Galloway
    Theo Bekkers Guest
    "Conrad" wrote
    Is that why they call it dry?
    Theo
  14. James Galloway
    knobdoodle Guest
    Conrad wrote
    Doctor Karl said that there's a danger that lumps of ice could form inside
    the tyres and cause damage when the tyres spin-up on landing too.
    Clem
  15. James Galloway
    knobdoodle Guest
    Theo Bekkers wrote in message
    OK smarty; then why is dry beer just as wet? (and don't even talk to me
    about dry ginger-ale!)
    Clem
  16. James Galloway
    Nev.. Guest
    You're just going out of your way to be wrong so that you can then post 'I was
    wrong and I admit it' messages.
    Nev..
    '02 CBR1100XX #2
    Nev.., Aug 29, 2003
  17. James Galloway
    Conrad Guest
    Much the same as some of the 'dry' humor found here - really very wet
    verbal diarrhea :)
    Dry simply means the gas has been scrubbed(why the process is called
    scrubbed and not towelled or blowdryed we will never know) - but even
    dry nitrogen gas has some albeit small moisture content. Air for
    SCUBA tanks is also scrubbed so you don't end up with both an air and
    fresh water supply whilst underwater.
    Conrad
  18. James Galloway
    Doug Cox Guest
    Or corrosion in steel cylinders...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Aug 29, 2003
  19. James Galloway
    Conrad Guest
    Now if we used helium in the tires -- wouldn't that constitute a
    weight reduction modification, hence a true performance mod? But if
    it prevents the bends - well then that just isn't very much fun :-(
    But the upside again is if you wanted to sound funny you could always
    inhale a little of the gas and impersonate Donald Duck - always funny
    when the effects of Nitrogen Narcosis are been exhibited!
    Conrad
  20. James Galloway
    conehead Guest
    I used to go out with a scrubber. She never told me what she did for a
    living, but now I know.
    conehead, Aug 29, 2003
