Nighthawk 650 Starter in a 700S?
Discussion in 'Motorbike Technical Discussion' started by Frank, Oct 31, 2006.
  1. Frank
    Frank Guest
    Hi,
    I recently bought a starter on ebay for my 1986 Nighthawk CB700SC. The ad
    said the starter was for the 650 or the 700 models. But the bolt holes don't
    go the same direction. The seller says I can just take off the cap from my
    starter and put it on the one I biught from him. Is this a good idea? Will
    this work? Or will all the guts inside come poring out or something? I'm
    comfortable changing the starter, but I've never had to take one apart
    before.
    Thanks for any help you can offer!
    -Frank
    Frank, Oct 31, 2006
  2. Frank
    Rayvan Guest
    Go to www.partsfish.com and look up both bikes' exploded drawings.
    Compare both assemblies and see if the common parts share the same part
    numbers. If they do you're in luck.
    Exploded drawings are also nice for those times where the guts come
    pouring out as you've stated and for when you end up with an "extra
    part" or two...
    Sometimes the simple exploded drawings work better than the factory
    service manuals.
    Rayvan, Oct 31, 2006
  3. Frank
    Darby OGill Guest
    take the broken one apart first to see if "guts come pouring out" ... no
    harm no foul
    Darby OGill, Nov 1, 2006
  4. Frank
    Frank Guest
    Good suggestions. Thanks everyone!
    Frank, Nov 1, 2006
