nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Oct 13, 2005.
  1. jlpridge
    jlpridge Guest
    The Saga continues... Eureka! The $65 stator works great!!! A
    3000rpm the votage at the battery is 14 volts. This increases up t
    14.8 or so as the rpms increase to 5000. The fix took only about 10mi
    to install and now the bike is doing fine. I cannot tell you all tha
    have offered assistance how much I appreciate it. Thanks so much!!!
    Jef
  2. jlpridge wrote:
    Progress at last. You may not be completely out of the woods yet...
    Does the voltage rise to the peak voltage specified in your manual and
    then drop off? Or does the voltage continue to rise?
    The voltage regulator in an excited field alternator has a large
    transistor that is supposed to switch the excitation voltage on and off
    at certain levels.
    There has to be a reason why the excitation coil in your old stator
    shorted out. It may be that the voltage regulating part of your RR
    wasn't working right and the RR kept sending voltage to the exciter
    coil continuously, burning it out.
    Also, keep an eye on your battery water, if you have a non-maintenance
    free battery.
    krusty kritter, Oct 13, 2005
  3. For sure, it's not normal for the Voltage to stay high. After a start, the battery needs to be refilled, so the voltage
    will rise to 14 volts or more, then after a short time the Voltage should drop to about 12.8 volts.
    It depends on the condition of the battery of course, this is for a good battery.
    If the voltage stays high, the battery could be toast, or the regulator is not working. Definitely check it out, or
    you'll fry more than the alternator. Bulbs don't like voltage that high so if you've been blowing some bulbs, you've
    definitely got a problem.
    James B. Davis, Nov 7, 2005
