nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Oct 9, 2005.
  1. jlpridge
    jlpridge Guest
    Krusty,
    Well I found out why the stator failed the open circuit test
    My bike does not have magnets on the rotor. The black wire and the whit
    wire are a positive and negative lead that provides 12 volts to
    believe excite the field or stator providing the magnetism whic
    normally comes from the magnets and without power to those two wire
    there will be no ac output. Nonetheless the stator is bad because th
    the resistance on the those two leads is 1 ohm when the specs say tha
    it should be 4-6 ohms. I found I shop that had one for $65 and i
    should be here wednesday.
    Jef
  2. Aren't there any brushes that go to slip rings on the rotor?
    Do the black wire and white wire go to pins in the same connector that
    has the three yellow wires in it? If the alternator is actually an
    excited field alternator, the power to excite the the rotor would have
    to come from the voltage regulator. So if all those wires are in the
    same connector, and you have the connector disconnected to do the open
    circuit
    test and it would have to fail the test.
    krusty kritter, Oct 9, 2005
  3. Jeff,
    Here is a thought. If what you way is true, that the alternator is a field
    exciteable one, then why don't you excite the field manually and start it
    and see what happens to your AC voltage at the output of the stator?
    To be honest I am a little surprised you didn't see any brushes when you
    took it apart. Is it possible the brushes are so badly worn you can't see
    them unless you know what you are looking for?
    pierce
    R. Pierce Butler, Oct 9, 2005
  4. No, I can't killfile anybody using google groups. I just didn't happen
    to read your message, but the idea about a stationary field coil and
    transmitting magnetism through the rotating poles makes sense,
    explaining how a brushless excited field alternator works.
    Yes, I agree with your proposed test procedure.
  5. You are right. There aren't and I realized that after I posted. Trying to
    carry on two conversation and post to usenet just doesn't work well.
    pierce
    R. Pierce Butler, Oct 10, 2005
