[QUOTE="jlpridge"] Krusty, Well as the old saying goes "more will be revealed." I believ the alternator is brushless. I have conducted yet another test found i the clymer manual. It is the test of the ignition pulse generator. Th test has you check the resistance of both pickups. The correc resistance is 330 ohms. One pickup tested fine. The other had n reading at all. If my suspicions are right I will check this again thi evening after letting the bike sit all day and the one that tested ba will test good. I believe this will be the case because the bike run fine when it has sat for five or six hours then as it heats up it run like crap. It would really be nice if I could talk with you onth phone. I would understand if that is not convienient for you. You hav been a great help and I appreciate your help very much. If we coul talk you can email me your number at [email][/email][/QUOTE] Krusty, My suspicions are confirmed. I waited a couple of hours an went out and pulled the cover to inspect the pulse generator. There wa some corrosion around where that bad pickup bolted in. I cleaned tha area up good and tested the resistance and it was in specs. I figure problem solved but found out while riding that as soon as the bik heated up good the problem (running rough and missing) returned. Sur enough upon testing the resistance on the two pickups the same one wa bad. Any thoughts you have on this are greatly appreciated. Jef
