nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Sep 30, 2005.
  1. jlpridge
    jlpridge Guest
    Krusty,
    Well I just did the open circuit test and the readin
    never went over 1.0 volts with the multimeter set on 200vac. Also
    just received the Clymer manual and it said to test the resistanc
    between the white wire and black wire from the stator and upon testin
    them I got a reading of 1 ohm when the specs are between .4 and .
    ohms. Both results point to a bad stator but it still does not addres
    why the bike is moody. The smell of gas is overwhelming when the bike i
    running leading me to believe it is running rich. But that does not
    explain why all of the sudden it go from running ok to missing and
    backfiring all of the sudden. It seems that letting it sit overnight
    ensures that it will run well for a little while the next day and then
    go back missing and backfiring.
  2. If your spark is really weak, it can't ignite the fuel air mixture
    properly and it will kick out a lot of unburned hydrocarbons. Also, if
    the motorbike has sat for a few months without being ridden, you'll
    smell some horrible odors coming out the exhaust. Compounds called
    aldehydes break out of the gasoline molecules and and they really
    stink.
    Now, I'm wondering about the black wire and the white wire you
    mentioned.
    What is their function? I thought you said that the stator output wires
    were yellow, that you also had a red/white wire, a green wire and a
    black wire coming from the regulator.
    Some Hondas had excited field alternators. They had a white wire and a
    black wire going to carbon brushes on the alternator. The brushes
    conduct current through the slip rings on the rotor and it becomes a
    rotating electromagnet, inducing current into the stator windings.
    Does your alternator have brushes? There are no brushes shown on the
    parts fiche for the 1983 CB550 Nighthawk at www.partfish.com.
    krusty kritter, Oct 1, 2005
