nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Sep 28, 2005.
  1. jlpridge
    jlpridge Guest
    Krusty,
    I have not run the open circuit voltage test yet because th
    bike will not rev to 5000 rpms. I will rechare the battery again an
    hopefully the bike will run well enough and long enough to do thi
    test. As far as the wires to the rectifier, there are three. Re
    w/white stripe, green, and black. I really do appreciate your time o
    this
  2. So, I suppose that there are three yellow wires from the stator going
    to the RR, and red w/white stripe, green, and black, for a total of six
    wires.
    Honda's color coding may be red/white for the DC power output, green
    for ground, and the black wire may be the sensing wires. Check it out
    with your owner's manual wiring diagram and keep on tracing it out.
    krusty kritter, Sep 28, 2005
