nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Sep 27, 2005.
  1. jlpridge
    jlpridge Guest
    Krusty,
    The wording is as follows: "Bad connection from the battery (+
    through the ignition switch to the switched +12v supply-input on th
    rectifier. Check the whole electrical circuit. This is one of the mos
    difficult faults to find. Suspect the ignition switch itself, the fus
    box and its connections. The rectifier thinks the battery voltage i
    too low while the voltage is correct or too high. Disconnect al
    terminals and clean them with contact cleaner." Hopefully this wil
    clarify some things.
    Jef
  2. Yes, I think I understand what Electrex is trying to say. It's just
    that running the battery *charging* wire from the rectifier DC output
    through the ignition switch to the battery terminal is such a bad idea
    because it requires the ignition switch to carry so much current.
    However. There are some Hondas that have six terminals instead of five
    terminals coming from the rectifier regulator.
    The three AC inputs, a DC positive output and a DC negative output can
    also be found on the typical five wire regulator. Charging voltage in a
    five wire RR is monitored directly from the positive battery terminal
    or from a point between one pair of diodes *inside* the regulator unit
    itself in a five wire RR unit.
    The sixth wire on some Hondas is a sensor wire. If I understand the
    sensor wire business correctly from what some Honda riders have posted,
    the sensor wire seems to monitor charging voltage at some remote point
    on the battery bus or on the ignition bus. If the sensor circuit has to
    add the voltage drop across dirty ignition switch contacts and corroded
    electrical connectors, it may sense low charging voltage and may not
    tell the silicon control rectifier inside the RR unit to ground out the
    stator.
    That could result in frying the stator.
    It's no wonder Honda riders have been cutting off their electrical
    connectors and soldering the wires together to get rid of all the high
    resistance connections.
    It seems to me that the best place to attach a sensing wire that's
    supposed to monitor charging voltage would be directly to the battery!
    So. How many wires total go to your rectifier regulator unit, five or
    six?
    And, have you done that open circuit voltage test I mentioned?
    krusty kritter, Sep 27, 2005
  3. It seems that all Honda is doing by using a remote sensing wire is
    saving about 1/100th of an amp current drain...
    I learned a great deal about voltage regulation and electronic ignition
    systems from a set of motorcycle repair manuals I found in the local
    library back in the 1970's. The typical owner's manual will have wiring
    diagrams showing all the wires going to mysterious empty boxes or
    circles.
    But this set of manuals showed diagrams and schematics and even gave
    resistance values for components, so I copied those diagrams for future
    reference as at least typical wiring and resistance values.
    The current reducing resistors that tailor the current going to the
    zener diode that triggers the thyristor in a shunt type voltage
    regulator might total around 1100 ohms, as I recall.
    If current flows through those resistors all the time, I calculate that
    you'd have 0.01 amperes flowing through them, the battery would take
    1400 hours, or 58 days to discharge down to 12 volts...
    krusty kritter, Sep 28, 2005
