nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Sep 24, 2005.
  1. jlpridge
    jlpridge Guest
    Thanks Pierce. I have charged the battery overnight and will check i
    this morning. From all that I ahve read so far I think it is th
    Rectifier. I wish I knew how to test it
  2. Maybe you're not clear on the concept of the rectifier regulator unit.
    There are two parts. The rectifier and the *voltage* regulator. They
    are both in the same unit.
    You test the voltage regulator operation by doing the "charging voltage
    test".
    You test the rectifier by doing the "diode test".
    Charging voltage test:
    With a fully charged battery installed, start the engine. The
    headlights must be on to load the alternator. Hook a voltmeter across
    the battery with the voltmeter on a 15 to 20 volt DC scale. As you rev
    up the engine, the
    voltage should rise from 12 volts to about 15 to 16 volts. Then the
    voltage should drop off sharply. Roll off the throttle and roll it back
    on and the voltage should rise and sharply fall each time you do this.
    The charging voltage test will prove that the voltage regulating
    circuit works.
    The diode test: This works best with an analog ohmmeter, as some
    digital meters won't read a diode correctly. With the ohmmeter on the
    R X 1 scale, check from each AC pin in the alternator input connector
    on the voltage regulator to the DC positive output pin. You should be
    able to tell the AC input connector from the DC output connector
    because it's probably impossible to hook the AC input conector to the
    DC output connector, the connectors should be "keyed" differently. To
    check the first three diodes, touch the black lead's probe to the AC
    input pin and the red lead to the DC output pin. If you don't get a
    reading, check with the black lead from the AC input pin to the DC
    output pin. You must get the SAME reading from each AC input pin to
    the DC output pin. It might be around 15 ohms, but I can't say for
    sure because the battery in an ohmmeter biases the diodes and causes
    different readings depending on the ohmmeter. If you don't get a
    reading, that probably indicates a blown out diode. Now, reverse the
    leads and check the other three diodes. Whatever lead gave you
    continuity from the AC input pin to the DC output pin is the wrong
    lead, so reverse the leads and check from the AC input pin to the DC
    negative ground pin. Again, you must get the same low reading from
    each AC input pin to the DC negative output. You should NOT get a
    reading in both directions, that indicates a shorted diode. You SHOULD
    get the SAME reading through all six diodes, going first from the AC
    input to the DC output to check the first three diodes, then reversing
    the leads and checking from the AC input to the DC negative side.
    krusty kritter, Sep 24, 2005
