[QUOTE="R. Pierce Butler"] jlpridge [email][/email] wrote in - R. Pierce Butler Wrote:- jlpridge [email][/email] wrote in - I recently (last week) purchased this motorcycle. IT runs well with a fully charged battery. However after I ride it for awhile and then park overnight it does not seem to want to run well at all. In fact the battery dies and the bike will not even start. I do not leave the key on or in it overnight. When I jump start it the bike starts up and as soon as I disconnect the jumper cables it dies. I do not want to start blindly replacing stuff. Please help. I do like this bike. - Something is draining the battery or the battery is bad. I have seen batteries discharge themselves. Charge them up and they pass the current draw test (barely). Let them sit and they are dead in 8 hours. To test for this, charge the battery and leave it disconnected from the bike and the charger overnight. Connect it to the bike in the morning. I the bike starts OK then the battery is probably good. If something is draining the battery, then you have to track it down. It could be a bad rectifier/regulator, switch or ????. pierce- The battery is brand new as of monday, so now I am going to start testing stuff. I will get a multimeter today to start on it. - While the possibility is quite remote, the new battery could be bad. As long as you hve the time, you mght as do the test just to be sure. You could hook up a tail light bulb in between the disconneted battery terminal and the battery lead. If it glows, then something is drawing current. Then you can start unplugging things to isolate the fault. pierce[/QUOTE] It appears that the only time there is a drain on the battery is whe the key is turned on (running or not). I am charging the battery no and will check in the morning to see if the voltage goes up once start it up. If it does not go up but stays the same or drops does thi indicate an alternator problem or could it also be the rectifier
