Newsreader on a stick
Discussion in 'UK Motorcycles' started by ginge, Jan 4, 2008.
  1. ginge
    ginge Guest
    Any recommendations for Windows newsreaders that can be run standalone
    off a USB Memory stick?
    ginge, Jan 4, 2008
  2. ginge
    Ofnuts Guest
    Thunderbird does it IIRC.
    Ofnuts, Jan 4, 2008
  3. ginge
    Agent.
    darsy, Jan 4, 2008
  4. ginge
    Ben Guest
    I think you can run Agent from one.
    Ben, Jan 4, 2008
  5. ginge
    you definitely can - Agent (at least up to v2.0) runs as a simple
    executable with local data files, rather than as an installed
    application.
    darsy, Jan 4, 2008
  6. ginge
    Des Guest
    This was on the USB key that the Greater Paris region gave to all teachers
    and pupils this year ..
    http://sourceforge.net/projects/framakey/
    I _believe_ that there's a version of Thunderbird somewhere in that lot..
    D.
    des
    French Biking Vocabulary: http://minilien.fr/a0kg0p
    'Kaiser: "Can you prove to me the existence of G-d?"
    Bismarck: "The Jews, your Majesty. The Jews"'
    Des, Jan 4, 2008
  7. ginge
    Xnews
    wessie, Jan 4, 2008
  8. ginge
    Catman Guest
    Wot he said.
    www.cuore-sportivo.co.uk
    Catman, Jan 4, 2008
  9. ginge
    Switters Guest
    Aye, 'tis true.
    Switters, Jan 4, 2008
  10. ginge
    DozynSleepy Guest
    Thunderbird from portableapps
    http://portableapps.com/
    DozynSleepy, Jan 4, 2008
  11. ginge
    Switters Guest
    No, just you. Freak.
  12. ginge
    christofire Guest
    I've been using PA for many months and have never read it like that.
    christofire, Jan 4, 2008
  13. ginge
    christofire Guest
    I had a look at:
    Thunderbird - didn't like the threading/UI for newsgroups. I couldn't
    get it set up like I have Xana set up.
    XNews - got it working, seemed very old-school and not too bad but it
    seemed to want to do "online" reading all the time. It didn't seem the
    friendliest thing to set up, which for non-work related stuff means I
    pretty much don't bother.
  14. ginge
    DR Guest
    That's how I'm using Agent right now, as I'm not at home. Works fine.
    DR, Jan 4, 2008
  15. Aren't you already using it?
    Whinging Courier, Jan 6, 2008
  16. ginge
    ginge Guest
    No I'm using Gravity, on a home pc.. I need something I can plug into
    any random computer and take my newsgroup stuff with me.. portableapps
    seems the best option at present.
    ginge, Jan 6, 2008
