Newby riding in cooler weather clothing question.
Discussion in 'Motorbike Technical Discussion' started by That One, Oct 7, 2009.
  1. Real honestly, I'll have to go look again. The grips were
    installed ~10 years ago by a previous owner.
    I'd expect that the grips would run from the fused circuitry,
    while the regulator appears to be running directly from the
    unfused diode board on the charging system.
    OTOH, the wiring's been hacked at by a long line of bozos.
    I'm only the most recent one. Thanks for the thoughts.
    Rob Kleinschmidt, Oct 30, 2009
  2. In this case, there are two 400 watt upgrades and
    one 800 watt upgrade available for the bike. 280 watts
    would be a little marginal for ~160 watts of gear and
    the normal draw of the lights and ignition. I've also
    got 100 watts of running lights that I can't run full
    time.
    One other thing I really like about one of the available
    upgrades is that it's a permanent magnet rotor with a
    RR combo. This package has half the parts count of the
    energized rotor package and of this reduced parts count,
    the only one that's likely to go wrong is the $100 RR.
    The stock system has a $100 rotor, $30 brush set, $100
    diode board, $30 regulator and lots of wires running all over.
    I lost a whole rally weekend troubleshooting this mess,
    only to find that the problem was a $12 3-wire cable between
    the stator and diode board.
    Agreed that there's **probably** enough power at speed.
    I like the idea just for the temperature regulation, but I'd
    also like to have more watts to spare.
    Like I said, KISS principle says brute force beef up the watts.
  3. That One
    frijoli Guest
    If what you're describing what is true, it sounds like you
    need to rip all the wiring out and fix it anyway. If so go
    for the upgrade. KISS applies to the wiring in my opinion
    more so than the upgrade.
    Go for it. It's what you want to do anyway.
    Clay
    frijoli, Oct 30, 2009
  4. The grips are clearly not wired directly into the charging circuit.
    I've been through that one enough to know. The bike has
    two stock wires to +12, a fat one for charging and a smaller
    one to drive lights, ignition, etc. It's clearly wired into that
    circuit and controlled by a relay, as it won't draw down the
    battery when the key's not turned on. Where exactly is
    something I don't recall, if I ever knew.
    The regulator draws +12 straight out of the diode board
    and appears to be well isolated from other circuits.
    The path to battery +12 is pretty clean too. 3 wires from
    stator to diodes, single wire from diode board to starter
    terminal, fat wire from starter to +12.
    Only place I've ever seen problem were in the 3 wire AC
    hookup and the battery grounds, though I maybe ought to
    swap the diode to starter wire out too just on general principals.
    Rob Kleinschmidt, Nov 2, 2009
  5. I'm not 100% sure there's a problem to be found or more
    watts to be wrung out. Could be just plain underpowered,
    but a couple tests for voltage drop are certainly a good idea.
    Thanks
    Rob Kleinschmidt, Nov 4, 2009
  6. That One
    Greg.Procter Guest
    Any voltage drop will get translated into heat at 100% efficiency.
    Some of that heat might be other than where you actually want it ;-)
    Greg.P.
    Greg.Procter, Nov 5, 2009
  7. As I'd said, without the heated grips or aux lighting, it'll bring
    the battery to 14 volts at highway speeds and stop driving the
    battery discharge light about 1400 RPM. For that particular
    charging system design, I'm not so sure there's much more
    to be wrung out of it.
    Rob Kleinschmidt, Nov 5, 2009
