Newbie help FZS 600 revs and gear
Discussion in 'UK Motorcycles' started by rob2, Apr 10, 2005.
  1. rob2
    Leo Guest
    As others have said, this depends on your riding style and the current
    conditions.
    As a newbie, you may be asking exactly what revs you should be using,
    so all the advice saying "whatever the bike feels comfortable with"
    may not be helping you a lot.
    So I thought I'd throw in 2p for you:
    I ride a Thundercat, which has basically the same engine as your
    fazer. It's a fairly free revving sports engine that is happiest
    between 6 and 12K on the rev counter.
    It starts pulling at 4 (which is basically idling it - you should be
    slipping the clutch or just trickling along if you are riding at less
    than 4K), but there is a flat spot in the rev range around 5K so if
    you start an overtake at 4K you tend to run out of oomph at
    inappropriate moments.
    So, town riding:
    I therefore tend to try and stay at or around 6-7K in town to allow
    for getting out of trouble asap without giving the cage drivers too
    much to complain about in the way of noise. When filtering I'll
    usually stay in 1st gear whatever speed I'm doing as if the traffic is
    moving too it is nice to let them know I'm there anyway. So I'll
    happily go to 9K in first gear in that situation. More than that and
    you shouldn't be filtering anyway as the cars are moving fast enough
    that you don't need to.
    When not in heavy traffic I'll drop into a higher gear to reduce noise
    and consumption and go into more of a 'cruise' mode, but still keep it
    at around 6K.
    Straight bits:
    The bits in the rev range where the cat pulls most are at 6.5 and 9K,
    so most of the time if I'm cruising I'll be just below the lower of
    those two bands. This gives me spare power where I need it if I want
    to do a quick overtake.
    If you want fun and excitement on a 'FOF or a ride out with mates,
    then keep the revs higher and prepare to be kicked in the arse when
    you reach the 9k band. It'll continue to pull amazingly quickly from
    there to the red line, and the grin will probably reach past your
    ears, but be prepared to reach for the wallet more often.
    In the rain:
    Lower revs generate less torque, and you are less likely to spin up on
    corners, so riding in the 5k flat area isn't a bad idea all the time.
    As a general rule, bigger engines will generate more power lower down
    the rev range, so they don't need to go so high. Your 600 should see
    you happy for a good few years though. The only time mine seems to
    lack anything is two up for long periods on a motorway when it has to
    try a bit hard.
    If some of this is too obvious to you then I apologise, but when I
    first started this is the sort of thing I was looking for.
    Oh, and by the way, don't get fixated on what revs you are doing. As
    you ride more and get used to a bike you'll find yourself starting to
    do things automatically. One of these is learning when to change gear
    and what gear to be in for hazards coming towards you.
    I'd recommend reading Keith Code's Twist of the Wrist books. They did
    my riding a lot of good.
    Basically, (and yes I know I'm possibly saying ignore all of the
    above) just get out there and enjoy it. Summer's coming and you've
    got a fun bike to be on.
    Leo, Apr 14, 2005
  2. rob2
    rob2 Guest
    <snip very useful advice>
    Got some earplugheadphone er6 things today and it feels so
    much beter riding and not having the engine noise so loud but
    still audible, a lot more relaxing also solved my clutch slipping
    habit. Using the revs you suggested now,
    rob2, Apr 19, 2005
  3. rob2
    Eddie Guest
    Oooh, groovy - those look even smaller than the Sony Fontopias I've got now.
    Hang on, how much are they? <fx:boggle> Think I'll stick with the Fontopias.
    Eddie, Apr 19, 2005
