New time waster
Discussion in 'Australian Motorcycles' started by Johnnie5, Sep 12, 2004.
  1. Johnnie5
    Johnnie5 Guest
  2. Johnnie5
    GB Guest
    GB, Sep 12, 2004
  3. Johnnie5
    Nev.. Guest
    Nev.., Sep 12, 2004
  4. Johnnie5
    Will S Guest
    79,850
    Will S, Sep 12, 2004
  5. Johnnie5
    Nev.. Guest
    99,576... quiet night at work.
    Nev..
    '03 ZX12R
    Nev.., Sep 12, 2004
  6. Johnnie5
    lemmiwinks Guest
    lemmiwinks, Sep 13, 2004
  7. Johnnie5
    sharkey Guest
    A pint of Coopers and a packet of crisps, thanks.
    -----sharks
    sharkey, Sep 13, 2004
  8. Johnnie5
    Nev.. Guest
    Hey sharks we still can't see your posts.
    Nev..
    '03 ZX12R
    Nev.., Sep 13, 2004
  9. Johnnie5
    sharkey Guest
    Who's this 'we', white man?
    I just bought a R100GS ... maybe your Honda has
    automatically killfiled me?
    -----sharks
  10. Johnnie5
    Bobby Guest
    100'819 after 20 mins of prac :)
    Bobby, Sep 13, 2004
  11. Johnnie5
    Stoneshop Guest
    Onya, mate.
    What year?
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede, Netherlands '91 R100GS/PD The Great Unwashed
    // N 52.2158 E 6.88589 '90 K75C Kommutabike
    // "Far away is only far away '81 MZ TS250/1+LSW Badkuip
    // if you don't go there" '79 Honda XL250S TBD
    Stoneshop, Sep 15, 2004
  12. Johnnie5
    sharkey Guest
    sharkey, Sep 15, 2004
  13. Johnnie5
    Moike Guest
    well, there's me.
    I can only see where someone has replied to you.
    Maybe it's the german newsreader. You wouldn't be doing something silly
    like using a sig file with an embeded image would you?
    Moike
    Moike, Sep 16, 2004
  14. Johnnie5
    Stoneshop Guest
    Beware the driveshaft. Take it out once a year and check for rotational play: if
    there's any the joint bearings are on their way out and you can expect total
    failure within 10.000km. Keeping the rear drive splines well greased with a good
    EPX grease will lower the stresses on those bearings; as they're sealed there's
    no immediate way to improve joint bearing life directly (but with some effort it
    can be done nonetheless). Taking the shaft out of the swingarm and putting it
    back in is a bit tedious, but with the right sequence of loosening this before
    taking off that, etc., it takes me about 1.5h. Loosen wheel bolts, undo front
    rubber boot, take out front pivot bolts. Then pull the swingarm backwards a bit,
    and undoing the four gearbox output flange bolts is suddenly way less fiddly.
    Also when reassembling: hanging the swingarm from the rear frame using a luggage
    strap, aligning it horizontally but two cm further back it's way easier to get
    those bolts back in.
    Check if it's got a grey coil (prolly not, for that year). Those are prone to
    developing cracks and hence cutting out in the rain.
    Generator rotor winding tends to fail at 80..100 kkm. The generator telltale
    light should light after turning the ignition key and before starting. If it
    doesn't, for whatever cause, charging won't be happening.
    And in the 'fluids' section of the workshop manual, cross out the '800ml' next
    to 'gearbox' and write in '1l'. The gearbox output shaft front bearing will
    thank you for it.
    Stoneshop, Sep 16, 2004
  15. Johnnie5
    sharkey Guest
    Yep, it's got grease nipples added and assuming I remember to
    actually grease it that should help. Bloody BMW, of all the
    things that should be set-and-forget ...
    Yeah, I think that's done. I'll check.
    Yep, recently changed along with the diode board.
    Cool. It's filled up to the level of the plug, do you mean lean
    the bike over the other way and 'overfill' it?
    -----sharks
    sharkey, Sep 17, 2004
  16. Johnnie5
    Stoneshop Guest
    [ good mods already done ]
    A bit; 800ml doesn't quite reach the filler hole yet when the box is level.
    Stoneshop, Sep 17, 2004
