New Router
Discussion in 'UK Motorcycles' started by sweller, Nov 4, 2010.
  1. sweller
    Looks like I need a new router my current Netgear WGR614v9 doesn't like
    the works VPN (I think it's Cisco). It also flatly refuses to upgrade
    its firmware.
    So, I need a wireless cable router with firewall, port forwarding, dyndns
    and the like.
    Of course with Virgin's upcoming 100Mb service I may not need one but
    it's getting on my tits the VPN dropping out so I'll probably have to get
    one anyway.
    What's the router of choice?
  2. sweller
    Catman Guest
    One of the only ones that stays stable on my Virgin connection. Setup
    could be better, frankly.
    Other than that, I had good experiences with Zyxel kit, but the cable
    device seemed far less accomplished than the corresponding ADSL kit, and
    far less reliable.
    www.cuore-sportivo.co.uk
    Catman, Nov 4, 2010
  3. sweller
    Buzby Guest
    We have a Netgear DG834Gv5 - works fine on SWMBO's cisco vpn. No idea
    about port forwarding, dyndns etc
    Buzby, Nov 4, 2010
  4. sweller
    Switters Guest
    That's a pity. Since upgrading the firmware on mine, I've had no troubles
    since. I've gone from rebooting once or twice a day to not needing to in
    about 2 weeks and counting.
    I'm sure you're happy to hear of my good fortune.
    Switters, Nov 4, 2010
  5. sweller
    Is there a way of doing it? It says "Firmware upgrade failed. Check
    file".
    Any idea?
  6. sweller
    Switters Guest
    Mine said it was out of memory on the upload, so I rebooted it and tried
    again. Then it worked.
  7. sweller
    A bit of Googling latter and I discover as it has Virgin branded firmware
    it can't be upgraded. So back to buying a replacement...
  8. sweller
    When I had cable I used a Linksys router. A housemate used to VPN into
    the uni system using it. IIRC Linksys is the retail arm of Cisco.
    The router still works and sits in a cupboard as a back-up for when my
    lad kills the Belkin attached to his cable modem.
    Of course, you could do a darsy and play the "I'm fucking off card" with
    Virgin and get a "free" replacement. It will be another Netgear but
    might be a better version.
    wessie, Nov 4, 2010
  9. sweller
    B 650 Guest
    On 04/11/2010 22:17, wessie wrote:
    I have used Linksys kit for years now, and they have generally been
    pretty good, although I had a very bad experience with a WRT160N last
    year, apparently it was acceptable for Linksys to sell a router that
    intermittently didn't allow communication between connected devices,
    only through the WAN port....
    B 650, Nov 5, 2010
  10. sweller
    Adrian Guest
    Odd. I've got a WRT160N here - and it plays that game just fine...
    (They take DD-WRT firmware, too)
    Adrian, Nov 5, 2010
  11. sweller
    SIRPip Guest
    Now, then. You're a youngster, in touch with the throbbing beat and
    street speak - so just WTF does that phrase mean?
    SIRPip, Nov 5, 2010
  12. sweller
    Catman Guest
    I *am* sorry, old bean. I should be interpreted as follows:
    Out of the entire set of devices that I have used to route traffic on my
    Virgin Media supplied internet connection, very few functioned
    acceptably. The Airport Extreme device was one of those that functioned
    acceptably.
    Had I realised that you were so advanced in senility, I should have paid
    more attention to my phrasing.
    However, the need to balance time spent composing posts to this august
    organ against doing other 'stuff' I find myself tending towards the
    attitude of Life's Too Short To Proofread Usenet. Or indeed, sense check
    it for the pedants amongst the putative audience.
    In closing, may I take this opportunity to wish you and yours the finest
    of all possible days.
    Catman, Nov 5, 2010
  13. sweller
    B 650 Guest
    I think there's 2 versions of the WRT160N, one takes the DD-WRT
    firmware, one doesn't... No prizes for guessing which one I had.
    B 650, Nov 5, 2010
  14. sweller
    One could re-write that post a lot more succinctly:
    "**** off, Pip!"
    CT, Nov 5, 2010
  15. sweller
    Catman Guest
    Please, don't put words into my mouth. If I'd *wanted* to say '**** off,
    Pip!', I would have done.
    I'm saving it for later ;)
    Catman, Nov 5, 2010
  16. sweller
    Adrian Guest
    Ah... <checks> There's three... v1(1.0 & 1.1) & v3 do, v2 is "can be, but
    not currently - it's in the works"...
    Adrian, Nov 5, 2010
  17. sweller
    malc Guest
    And there was me thinking you were going to do some DIY
    malc, Nov 5, 2010
  18. sweller
    SIRPip Guest
    Bait? Moi?
    No, really - that's one of my pet hate phrases that is widely (mis)used
    and doesn't really mean a damned thing. "One of the only" can be
    generally assumed to mean "the only one" and as you point out, I'd
    quite happily accept "one of the few" in this case. Bah!
    SIRPip, Nov 5, 2010
  19. sweller
    SIRPip Guest
    Pfft. That's your thick fingers getting in the way of your
    programming, that's all.
    Note the "SIR", mate. Senility In Retirement, that is. I'm closing on
    auvache in that respect.
    Plenty of pedants round here. Boy.
    I thank you, kind sir, and reciprocate. Blessed be.
    SIRPip, Nov 5, 2010
  20. sweller
    SIRPip Guest
    I think the great majority of responses to my contributions should
    really consist of your succinct suggestion and nothing else. Good
    work. ****.
    SIRPip, Nov 5, 2010
