new or used: a question of economy
Discussion in 'Australian Motorcycles' started by bikerbetty, Oct 26, 2008.
  1. bikerbetty
    jl Guest
    Well I'd like to think I am ! And anyone who wants to burst my bubble
    can go stand in the far queue.
    Only $10 cheaper - it was $60 cheaper than the genuine alternative for me
    Well I don't have a philosophical issue with giving Feeney's my money as
    such, the issue for me is always the fact that I'd like the parts THIS
    decade. So I prefer to buy the things that are actually immediately
    available which coincidentally never seem to be the genuine Cagiva/MV
    stuff for some reason.
    JL
    (no I'm sorry I won't wait 4 months for a fuckin' air filter OK - the TL
    one will fit just fine)
    jl, Oct 28, 2008
    #81
  2. In aus.motorcycles on Tue, 28 Oct 2008 21:45:42 +1100
    More horses from smaller packages, more equipment... that means the
    bikes are harder to work on.
    The Norge is fuel injected so it's harder to work on without expensive
    kit than a carbed bike is. WIlder cam timing, twin plugs, and it's
    still a relatively simple bike to get at.
    I learned on old bangers that were easy to work on (how hard is an RD250
    to service?) if I was new to working on bikes now and confronting a fuel
    injected twinplugged thing covered in fairings I'd think twice.
    Someone who starts with a GPX would be OK, but a babyblade owner?
    Zebee
    Zebee Johnstone, Oct 28, 2008
    #82
  3. bikerbetty
    G-S Guest
    I have a soft spot for the LAMS DR650SE but then it's basically a 20
    year old bike that's still being made and one that wasn't exactly state
    of the art when it was introduced :)
    G-S
    G-S, Oct 28, 2008
    #83
  4. bikerbetty
    CrazyCam Guest
    Going down the gears is part of the "standard" script for the NSW
    pre-learners.
    The course is fairly well defined and each school or instructor is
    supposed to stick to the standard script, so, in theory at least, all
    new riders in NSW should be taught the same things.
    regards,
    CrazyCam
    CrazyCam, Oct 28, 2008
    #84
  5. bikerbetty
    sharkey Guest
    He's a good man, and thorough.
    -----sharks (it's okay Betty, in-joke)
    sharkey, Oct 28, 2008
    #85
  6. bikerbetty
    theo Guest
    Stop skirting around the issues.
    Theo
    theo, Oct 28, 2008
    #86
  7. bikerbetty
    theo Guest
    Unscrew the plug on the bottom, let it run out, screw the plug back
    in, fill it at the top. It's not rocket science Betty.
    What is that?
    Pretty simple, they just have one bolt. Give it a go.
    You may need to offer some-one a beer fot this information.
    Sorry, I don't have one of those either.
    Theo
    theo, Oct 28, 2008
    #87
  8. bikerbetty
    theo Guest
    You have wiggly bits?
    Theo
    theo, Oct 29, 2008
    #88
  9. bikerbetty
    theo Guest
    Totally agree. OTOH, my ex-brother-in-law thought there was a
    manufacturing problem with the head-bolts on his Marina after he
    snapped the fourth bolt.
    Theo
    theo, Oct 29, 2008
    #89
  10. bikerbetty
    theo Guest
    That sounds a bit silly. I was taught by my National Safety Council
    (sadly defunct and their track has turned into a parking lot for ECU)
    that, when you have a need to emergency stop, you forget about the
    gears, the indicators, the dashboard clock, the CB radio, the people
    behind you, annd just concentrate on stopping.
    Of course the best lesson is not to allow yourself to get inot such a
    situation in the first place, because, if you do it regularly, you
    will die.
    Theo
    theo, Oct 29, 2008
    #90
  11. bikerbetty
    CrazyCam Guest
    If you are applying the correct technique to your braking, what do you
    lose by tap-dancing on the gear shift at the same time?
    Assuming you manage to stop without bumping into anything, it is a handy
    option to be able to go again reasonably promptly.
    I certainly agree that avoidance of the need for an emergency stop is a
    better option.
    regards,
    CrazyCam
    CrazyCam, Oct 29, 2008
    #91
  12. In aus.motorcycles on Wed, 29 Oct 2008 13:04:28 +1100
    I tend to get distracted by the way the gearshift lever locks up or
    otherwise protests.
    Haven't tried it on the Norge, but the other bikes don't much like it.
    (and it's way too much like work on the Devil, as it's pull up not
    push down.)
    Heh. Not in 3rd or stuck in some suddenly appeared neutral it isn't.
    Zebee
    Zebee Johnstone, Oct 29, 2008
    #92
  13. bikerbetty
    CrazyCam Guest
    Fine...don't do it.
    I do the down shifting out of habit, but will probably not do it, at
    least intentionally, on the BM.
    Of course there will be perfectly valid reasons for some people riding
    some bikes to not do it.... that's OK.
    I still think it's a good thing to teach. I also think, in most cases,
    it's a good thing to try and practice.
    Probably Dave, on his hand-shift WLA might not try it.
    Most reasonably modern motorcycles will happily put up with the down
    shifting business.
    Well, that's exactly the point. If you stop and are still in 5th or 6th,
    you'll either stall it trying to move away, because when you've _had_ to
    do an emergency stop, you forget things like that, or you have to then
    find first.
    regards,
    CrazyCam
    #93
  14. In aus.motorcycles on Wed, 29 Oct 2008 15:28:30 +1100
    I have done it on bikes that tolerate it, but not ones that don't.
    Like most things taught to learners, experienced riders know the
    exceptions.
    Heh.... old bikes are too expensive for learners nowadays!
    Zebee
    #94
  15. bikerbetty
    Nev.. Guest
    the bit that connects the engine to the gearbox :)
    Nev..
    '07 XB12X
    Nev.., Oct 29, 2008
    #95
  16. bikerbetty
    Moike Guest
    Moike, Oct 29, 2008
    #96
  17. bikerbetty
    jl Guest
    Could be OK, but there's 4pots and 4pots - the stock one on the trx sucked
    Mmm yeah OK, but why not buy a real bike (or in fact you could probably
    get 3 decent bikes for the cost of a fat bob). You know you want a Striple.
    JL
    jl, Oct 29, 2008
    #97
  18. bikerbetty
    jl Guest
    Well.... a bit like bestiality - it might feel good doing it, but it
    really is wrong.
    Yes well that is indeed a plus.
    Can't argue that logic
    JL
    jl, Oct 29, 2008
    #98
  19. bikerbetty
    jl Guest
    Nope it was an 860 twin
    JL
    I think, it's a very brief hazy memory now
    jl, Oct 29, 2008
    #99
  20. bikerbetty
    jl Guest
    Errm all of them got it right - they broke up with me didn't they ? Well
    ok, all bar one. But she never progressed to her Ps - kidlet screwed
    that one up for her.
    JL
    (all passed, all bar one still ride AFAIK)
    jl, Oct 29, 2008
