New (old) bike
Discussion in 'Australian Motorcycles' started by bill_h, May 22, 2009.
  1. bill_h
    bill_h Guest
    I've acquired a 1990 Honda NTV 650 Revere as a bit of a project, and
    hopefully as a cheap runaround. The motor seems to run nicely,
    although cosmetically it's rough around the edges. Dings in the tank,
    stuffed fork seals (but fork legs not pitted), broken indicator, not
    pretty but it appears functional.
    Anyone know what tyres should be on it? It currenty has radials,
    120/70 ZR17 front and 170/60 ZR17 rear, the specs I can find suggest
    it should be running crossplys.
    cheers, Bill
  2. bill_h
    x.x Guest
    top bike them
    regoed?
    x.x, May 22, 2009
  3. In aus.motorcycles on Fri, 22 May 2009 18:40:44 +1000
    http://growell.proboards.com/index.cgi
    "Welcome to the Original English speaking Honda NTV and Revere Forum.
    We have been going now for over four years and have more than 300
    members from all over. Feel free to come in and look around."
    Zebee
    Zebee Johnstone, May 22, 2009
  4. bill_h
    It would've been on the cusp of radials but crossplys are gonna' be cheaper.
    I HEARTILY recommend Bridgestone BT45s.
    According to the Bridgestone site (
    http://mc.bridgestone.co.jp/en/products/machine/honda.pdf ) the 88/89 ran
    110/80-17 and 150/70-17 crossplys (on 2.5' and 4.5" rims), while from '90
    onwards they ran 120/70-17 and 150/60-18 radials (on 3.5" and 4.5" rims).
    Bridgestone don't make a 150/60-18 BT45 but I doubt a 150/70 would upset it
    much.
    Knobdoodle, May 22, 2009
  5. bill_h
    bill_h Guest
    Thanks Zebee, I also found http://www.ntvhonda.proboards.com which
    I've subscribed to. I figured perhaps one of the cognoscenti here
    might have some knowledge on the subject.
    I went and had another look at the bike and on the shaft housing it
    has recommended tyre types, including Dunlop 505, Bridgestone G548,
    and Metzler ME 55A, which as far as I'm aware, are all crossply.
    Looks like a change of tyres is in order.
    Bill
  6. bill_h
    bill_h Guest
    The rear is definitely a 17 inch jobbie, so it seems should be
    crossply. I'll have a look at BT45s.
    thanks, Bill
  7. bill_h
    oofo Guest
    Wow, what an awesome bike, I never realised until now how long the
    Deauville engine had been around! It doesn't look like its changed one bit.
    On a sort-of completely unrelated side note, why aren't there any
    shaft-drive 250cc bikes out there?
    oofo, May 23, 2009
  8. bill_h
    bill_h Guest
    Apparently the first incarnation was as the VT 500, and it has evolved
    since that time.
    Probably too expensive for the market, but there has been at least one
    shaft drive 250.
    Bill
    bill_h, May 23, 2009
  9. bill_h
    G-S Guest
    BMW used to make the R25 which was shaft drive.
    G-S
    G-S, May 23, 2009
  10. bill_h
    bt Guest
    Correct-amundo. And in further good news, today I bought an un-bent
    frame for my VT500E for $50. The swingarm and centrestand are still
    attached! ;-)
    On a VERY vaguely related note, my local Vespa shop has a shaft-drive
    bicycle for sale. It has a 7-speed rear hub and I reckon it'd be a
    nice commuter but I don't feel like spending $1200.
    bt, May 23, 2009
  11. bill_h
    TimC Guest
    A localish guy (170km away) has a belt drive bicycle. A rather nice
    bike, although it does present difficulties if the belt ever needs to
    be replaced. Never mind, the builder estimates it should be able to
    do another 100,000km.
    TimC, May 23, 2009
  12. bill_h
    I think it jumped from 650 to 680cc a year or two ago.
    Hope that helps.
    Knobdoodle, May 23, 2009
  13. bill_h
    CrazyCam Guest
    wrote:
    A Vespa might be OK for the latte set, but Harley Davidson built a shaft
    drive pushie, presumably for the proper tough bikies. ;-)
    regards,
    CrazyCam
    CrazyCam, May 23, 2009
  14. bill_h
    TimC Guest
    It's heavy and the rider makes a *lot* of noise huffing and puffing
    and struggling to get the thing uphill?
    TimC, May 24, 2009
