New chain is loud, whats wrong?
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Oct 9, 2006.
  1. Masospaghetti
    John Johnson Guest
    Not really. I placed the oil feed in the center of the pipe, and tried
    to put each nozzle hole at the same distance from it. As it turns out,
    the inner nozzle appears to get more oil than the outer, but so long as
    both get some I really don't care much.
    VFR750: single-sided swing-arms are useful for tire changes. :)
    When I eventually have to change chains, I'll dismount the entire unit.
    It's held on by one nut, attached to that flat plate that itself is
    attached to the SSSA.
    And quite frankly, if I break it I'll just build another one. They take
    about 20min to set up, plus time for the JB Weld to cure. I've still got
    plenty of brass tube from the first one, too. If I do make another one,
    maybe I'll do something to make it prettier.
    lol, my job is pretty primitive compared to yours. I'd make mine pretty
    but I'd rather ride than fuss at this point. I've got enough maintenance
    coming up as it is. Your install looks really nice and clean; nice work.
    Later,
    John
    John Johnson, Oct 13, 2006
