new bike and a half
Discussion in 'Australian Motorcycles' started by Marty H, Sep 6, 2008.
  1. Marty H
    Marty H Guest
    Its a 1981 Honda CB900 with a DJP outfit on it.
    It doesn't start, It needs a new Timing chain (supplied) and hopefully
    that is all it needs on the engine front (thou I do accept it might
    need major work or a change over)
    other than that it needs a general clean up, a bit of surface rust
    removed. maybe a new chain and some wheel bearings. Also its unreg.
    I will also put in a rollcage and seat belt in the chair.
    Its cost me $2500 and prolly another $1k to get it on the road...
    cheap fun
    http://martyh.com/cb900/54.jpg
    http://martyh.com/cb900/55.jpg
    http://martyh.com/cb900/56.jpg
    http://martyh.com/cb900/57.jpg
  2. Marty H
    No no Marty; the timing chain doesn't go on the front. It goes in the
    middle!
    Knobdoodle, Sep 6, 2008
  3. Marty H
    I'll do it! My 2nd and 3rd timing chain installations were 100%
    successful!
    (Let's not talk about that first one).
    BT Humble, Sep 6, 2008
  4. Marty H
    G-S Guest
    Will you have it ready for the outfit rally in NSW in about 3 weeks Marty?
    We could always take our outfits up to the rally :)
    G-S
    G-S, Sep 6, 2008
  5. Marty H
    Marty H Guest
    no.. thankyou, the last time I did look at a timing chain it was at
    the front.. but it also had 2 more cylinders, one more wheel and a
    couple of more seats..
    the VFR had gears and I think the KLR was on the side
    mh
    Marty H, Sep 7, 2008
  6. Marty H
    Marty H Guest
    can you please let me know how not to do it then?
    mh
  7. Marty H
    Marty H Guest
    not a chance... maybe, but prolly not.
    thats sound dirty...
    mh
  8. Isn't this the 900 they made out of the 750 and the jiggery pokery to
    fit the head/cams in makes the timing chain the constantly busting weak
    spot? Something about an extra sprocket in there somewhere.
    Kim
    Doctor Shifty, Sep 7, 2008
  9. Marty H
    Marty H Guest
    I dunno, but I have been told that the top end on the 900 is a little
    on the soft side...
    but for $2.5k.....
    mh
  10. Marty H
    G-S Guest
    There is a sidecar rally in victoria in about 6 months... maybe you
    should aim for that one.
    Seriously, if you are going to take up riding an outfit you owe it to
    yourself to check out the weird and wonderful homemade contraptions
    people fit to them :)
    Mine isn't the topless outfit!
    G-S
    G-S, Sep 7, 2008
  11. Marty H
    G-S Guest
    You could probably pick up a CB750 DOHC motor cheap and fit it into the
    outfit fairly cheap if it became an issue.
    G-S
    G-S, Sep 7, 2008
  12. I think they used the 750 bottom end and relined barrels with new
    broader head with wider apart cams. The cam chain didn't fit the chain
    tunnel up through the barrels so they had to put in an idler sprocket.
    My Suzuki GS1000 was a 1981 model, so I sometimes got in pub
    conversations with others who had similar era bikes. Don't believe
    anything you hear in a pub or on the internet....
    Kim
  13. Marty H
    I never heard that. I thought the 900 came out as a distinct new model and
    maybe even preceded the twin-cam 750.
    The only weaknesses I've heard were the famously misaligned frames and the
    longish stroke (which caused higher than the norm-for-the-era piston-speeds
    and conrod/gudgeon failures.)
    Knobdoodle, Sep 7, 2008
  14. Marty H
    1. Get a decent service manual first;
    2. If for some reason you have to separate the sprockets from the
    camshafts, use a torque wrench and loctite when you put them back on.
    3. Try not to have visitors distracting you while you're working. ;-)
    BT Humble, Sep 8, 2008
  15. Marty H
    Marty H Guest
    coming with the bike
    almost bought a torque wrench yesterday..
    thats OK... I have no friends
    mh
    Marty H, Sep 9, 2008
  16. Marty H
    JM Guest
    Use new, genuine Honda sprocket bolts when you do. The old ones will
    be stretched and can (and do) give up when you re-assemble with them.
    For the cost of a half-dozen little bolts you could save a lot of
    trouble later, seriously.
    Oh, and line up the whole 'timing marks - chain links' thing a few
    times till you're totally happy with it. One tooth out can make huge
    differences and is dead easy to achieve; better to take a while to
    make 100% sure than shag the engine the first time out.
    Incidentally, if you have trouble getting spares (consumables and the
    like) try David Silver Honda over here in UK - they do lots of stuff
    for older Hondas.
    Cheers,
    Jeffles
    JM, Sep 9, 2008
  17. Marty H
    As it turned out, I didn't *need* to remove the cam sprocket from the
    CBR1000F motor at all, which made the snapped camchain and bent valves
    all the more irritating.
    BT Humble, Sep 9, 2008
  18. Marty H
    JM Guest
    Aye, now you mention it, with some bikes once you remove the pillar
    bolts and take out the tensioner assembly you can sometimes just use
    the slack to slide out the camshafts, although you'd still need to
    'undo' the chain somehow. I *did* see a split link in a camchain once
    (can't recall which bike) but think Therein Lies Disaster.
    Jeffles
    JM, Sep 9, 2008
  19. Marty H
    The GPZ900 one was already formed into a loop, and since the cam
    sprockets are at the end of the motor rather than the centre it was a
    doddle to fit.
