Never mind eh?
Discussion in 'UK Motorcycles' started by Muck, May 29, 2005.
  1. Muck
    You get a little money from somewhere and what happens eh? Your CG125
    forks erupt in rust under the chrome and destroy your seals and you have
    to buy new fork tubes / seals.
    Bloody stupid forks on there look as though the chome is wafer thick and
    not very well stuck at that.
    <fx: skulks off to sulk for a while>
    Muck, May 29, 2005
  2. Muck
    petrolcan Guest
    See, told you they were shit bikes.
    petrolcan, May 29, 2005
  3. Muck
    Muck says...
    Get them ground and industrial hard chromed. Probably work out cheaper
    than new stanchions and you know they'll last longer than a new set.
    Lozzo, May 29, 2005
  4. Muck
    Cab Guest
    Burn the heretic!!!!
    Cab, May 29, 2005
  5. Muck
    I've gone for some after market tubes, with a seal kit still come out
    £30 cheaper than a regrind will cost me. Still a bit of a pita though, I
    thought I'd had enough of rebuilding forks with the FZR. :)
    Muck, May 29, 2005
  6. Muck
    I got a fixed price chrome and regrind / polish for the FZR and was well
    chuffed with the results of that.
    I'd imagine it is a bit of a pita. Still, if you're set up for doing
    only that, you'd be able to keep the price down a bit.
    Muck, May 29, 2005
  7. Muck
    Sounds like a better option that.
    Yep, they listen and then, not always politely go back to doing it some
    old way, just because they've always done it like that. Happened to me
    at two companies I worked for.
    Muck, May 29, 2005
  8. Muck
    Robbo Guest
    I had the 'Wing forks done through this lot.
    http://www.hardchromeplating.co.uk/
    Damn fine finish and quite reasonable
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 29, 2005
  9. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    That's life, Bubba.
    Whinging Courier, May 29, 2005
  10. Muck
    I've got a couple of new tubes now, it was cheaper doing that on this
    bike.
    Muck, May 29, 2005
  11. Muck
    Heh... Yeh, shit happening. It does that from time to time. Just a bit
    pissed off that I can't get my 'sticky' tyres for the CG at the moment
    though.
    Muck, May 29, 2005
  12. Fucking dinosaurs. I've come across this on occasion - there's a bloody
    good modern way of doing something and some **** just won't take it in
    because he doesn't understand it.
    Grimly Curmudgeon, May 29, 2005
  13. Grimly Curmudgeon wrote:
    Fact of life #123: 'People' don't like change.
    Doesnotcompute, May 29, 2005
  14. Muck
    While you've got them off the bike, and they're still shiny and new, fit a
    set of gaiters.
    platypus, May 29, 2005
  15. You'll not reach honourary magpie status with logic like that.
  16. Muck
    Fact of life #124: Life is change.
    Muck, May 29, 2005
  17. Muck
    Good thinking. I'll nip into town on Tuesday and get some to suit.
    Muck, May 29, 2005
  18. Muck
    The other thing about gaiters is that an MOT tester can't look at what's
    underneath them. If you have scabby but still serviceable stanchions, it's
    a good way to smarten them up for the test.
    platypus, May 30, 2005
  19. Muck
    I may put some on my Bandit too, one day. It'll protect from stones and
    dents in the chrome a bit.
    Muck, May 30, 2005
  20. In uk.rec.motorcycles, platypus amazed us all with this pearl of wisdom:
    Do bits of bin liner held on with cable ties count as gaiters?
    Whinging Courier, May 30, 2005
