Network Storage - Freecom classic 160GB Ethernet
Discussion in 'UK Motorcycles' started by Hog, Apr 19, 2006.
  1. Hog
    Not really OT as so many posters have SoHo networks.
    Just installed a Freecom classic 160GB Network Storage drive. £120 from
    PCW.
    # 2 machines using it are XP though there are 2 W98 to follow
    # 100MB switch
    # 802.11B WLAN
    Noting that this is a USB2/Firewire and 100BaseT product - no GigaLAN
    support
    The copying of DVD/CD media has led to HDD capacity problems and I did
    not want a single PC solution or one which required any particular PC to
    be booted first. I also wanted a better data backup solution.
    I read the CD based manual 1st. Shock horror!! It's a fair idea in this
    instance.
    Almost idiot proof though, I think.
    1 hour had it running and active on the 1st 2 machines (all my PC's are
    laptops of one sort or another)
    I know you can get 250GB of USB2 storage for the same price but if you
    want the added functionality this unit comes *highly recommended*. It
    rocks a phat one, *Delighted*
    If you have another spare Switch port then 2 can be nested providing
    320GB of primary storage or 160BG Raid-1
    Data transfer:
    # many small files and folders - 160seconds/GB
    # large mpeg files - 130seconds/GB
    Hog, Apr 19, 2006
  2. In uk.rec.motorcycles, Hog belched forth and ejected the following:
    Coo!
    So tell me, for the relatively uninitiated, is it simply a case of
    plugging one into the free ethernet slots in my router?
    I've had to stop using uknova and the like, see.
    Whinging Courier, Apr 19, 2006
  3. Hog
    Correct, then load up a small application on each pc which will access
    it. Enter the device ID and PIN into the pc app and Bob's your cross
    dressing auntie.
    Security seems to be pretty good and the drive can mounted/unmounted
    from the app which is resident in the systray
    Hog, Apr 19, 2006
  4. Hog
    I don't know about the drive in question, but for the Maxtor one I
    have here, it's to handle the encryption.
    darsy, Apr 19, 2006
  5. In uk.rec.motorcycles, Hog belched forth and ejected the following:
    Many thanks, Mr.Hog.
  6. Hog
    As Darsy comments it is probably about security. Whatever, it works and
    I am liking it a lot today.
    Hog, Apr 19, 2006
