Need some general info about Suzuki GSX 750
Discussion in 'Motorcycle Technical Discussion' started by oldgeezer, Sep 25, 2006.
  1. In the case of missiles and suchlike, I sometimes heave a sigh of
    relief. Swords into ploughshares and all that.
    But I do sometimes look at the pix of Davis-Monthan and sigh
    wistfully.....
    The Older Gentleman, Nov 19, 2006
    #41
  2. oldgeezer
    Ian Singer Guest
    I hate to ask but is it possible or probable that my carbs are so far off?
    Removed the rack of carbs
    Removed the float bowls
    Removed the main jets and lock washers
    Removed the rubber plugs by main jets
    Washed everything with whole can of spray cleaner
    Ran wire through main jets as a couple seemed a little smaller
    There is a piece that looks like a rod with a small jet that hangs down
    between the floats. I am not sure if it is clear or how to remove it.
    The shop manual says with carbs upside down, and bowls and gaskets
    removed, the distance from where the metal would contact the gasket to
    the upper flat surface on the float (not the round part but where the
    round part mates with it) should be 22.4 mm +/- 1.0 mm.
    Trouble is I am measuring
    #1 17.6 mm
    #2 18.8 mm
    #3 16.6 mm
    #4 17.3 mm
    That means that there is 5.8 ]mm to 3.6 mm too MUCH (?) fuel in each carb.
    Remember this is engine that only runs on #1 which was also putting gas
    into the airbox expansion chamber.
    Ian Singer
    See my homepage at http://www.iansinger.com
    hosted on http://www.1and1.com/?k_id=10623894
    All genealogy is stored in TMG from http://www.whollygenes.com
    Charts and searching using TNG from http://www.tngsitebuilding.com
    I am near Toronto Canada, can I tell where you are from your reply?
    Ian Singer, Nov 21, 2006
    #42
  3. oldgeezer
    Ian Singer Guest
    The Suzuki manual says "invert the carburetor body holding the float arm
    pin so it will not slip off. With the float arm kept free, measure the
    height (A) while the float arm is just in contact with the needle valve
    by using the calipers." that's what it is doing and the tang on the
    float is touching the needle valve but it doesn't have enough weight to
    depress it.
    I have not removed the carb tops as can't crack the screws loose.
    But the carb does not have drain nipples it has screw in bolts and I do
    not have screw in nipples to replace with.
    I won't adjust anything unless its seriously suggested it is wrong.
    Another unrelated question. When looking into the carbs from the choke
    side three of them have a hole inside the body on either side. One only
    has one hole. Why is that?
    Ian Singer
    Ian Singer, Nov 22, 2006
    #43
  4. oldgeezer
    B-12 Guest
    Not from the factory, but who knows what Joe Shadetree the enthusiatic
    mechanic may have done to your carbs?
    The main jets would have a flat washer under them, not a lockwasher.
    The main jets screw into the
    brass jet holder, and it can be pressed out of the carburetor body so
    you can clean the air emulsion holes.
    The nature of a CV carburetor is that it doesn't allow the engine to
    even *begin* to draw very much fuel through the main jets until the
    slides lift past the untapered part of the jet needle. The engine is
    getting 3/4's of its fuel from the idle jets until the slide has lifted
    to about 75% open.
    The idle jets would be under those rubber plugs. Did you remove the
    idle jets so you could clean the cross-drilled air emulsion holes?
    Never try to remove an idle jet unless you have a small radio slot
    screwdriver that fits the jet perfectly.
    I don't know whether you're decribing the main jet and its holder, or
    if you're decribing the brass tube that goes down into a hole in the
    float bowl and draws fuel for the idle jets. The idle jets were
    concealed under those rubber plugs so they wouldn't "see" a variable
    fuel level as the motorcycle traversed road bumps are was leaned side
    to side.
    The system is due to the EPA's clean air requirements.
    That's the same dimension as the BS-34SS carbs on my GS-1100EZ...
    Are you sure the floats are installed right side up?
    B-12, Nov 22, 2006
    #44
  5. oldgeezer
    B-12 Guest
    Are you looking at the inlet bell mouth? You would typically see a
    round hole on the same side as the starting enrichener valve, and that
    would be the air inlet for the "choke". The small round hole on the
    opposite side would be either an inlet for emulsion air for the needle
    jet, or it might be the idle air inlet. But in some carburetors, the
    idle air inlet is inside the carburetor body, underneath the diaphragm.
    A large oval shaped hole would be the air inlet for atmospheric
    pressure to lift the slide as engine vacuum sucks air out of the
    diaphragm chamber.
    Looking at the other side of the carbs, downstream of the throttle
    body, you would see the triangular pattern of the transition jets, the
    single idle outlet port that is controlled by the idle mixture screw
    and the starting enrichener's outlet, which would be a much larger
    hole.
    One carburetor of the bank of four (probably #2) would have a similarly
    large hole for vacuum to operate the petcock.
    While you have the carbs off the engine, are you going to drill out the
    EPA plugs and clean out the
    idle port?
    B-12, Nov 22, 2006
    #45
  6. oldgeezer
    John Johnson Guest
    ??? Is it possible that some PO installed a mismatched set of mains?
    Note that the float heights on #1 and #4 are quite similar, within
    0.3mm. I'd expect #4 to run, were it the case that the float height were
    the only problem. This does not rule out float height as a problem,
    however.
    As I understand it, low height means too much fuel in your carbs, and
    that is consistent with the #1 carb puking fuel into the airbox.
    However, it is _not_ consistent with dry spark plugs in the other three
    cylinders.
    Later,
    John
    John Johnson, Nov 22, 2006
    #46
  7. oldgeezer
    Ian Singer Guest
    Maybe when I put back together I will find that I flushed some junk out?
    Yes one of the reasons I am confused. Spark on all four plugs but three
    plugs are dry. Don't forget coils, CD Ignitor and regulator are all off
    of other bikes.
    Ian Singer
    #47
  8. oldgeezer
    Ian Singer Guest
    My error they were flat washers
    How do you press it out of a hole? Remove the top plate which has frozen
    screws and slide and everything else up there?
    OK just pulled idle jet on #2 and it's plugged solid. Eyes are getting
    too old to see that it would even come out, ended up with reading
    glasses, magnifying glass and flashlight. Will try and run a wire down
    it from stranded 22 gauge wire until I get thickness that fits. After
    will pull others. Looking in the shop manual again that jet they call a
    pilot jet. They say there is another pilot jet on the left side of the
    intake throat when you look into carb from intake side.
    Must be the brass tube I am talking about that I can't see in the
    manual. It has a hole in the end and at the opposite end (towards top of
    carb) there is hole in side. Looks like the hole in end might be plugged
    but not sure if it's removeableor how best to unplug.
    OK I see what gives now. Manual says remove the gasket. I removed gasket
    and measured with carb inverted from the top of the metal flange to the
    top flat surface of the float. Yes it's correct way up. Looking again
    that's not where to measure, it's supposed to be to the bottom surface
    of where the gasket goes, so that adds 3.1 mm, meaning #4 is not 17.3
    mm but 22.3 mm (OK so there is also a .1 difference where I can't
    measure). That makes a lot more sense and means that one is right.
    You ae right again. #2 on exhaust side is for vacuum petcock.
    I know I should but where is it? My older bikes used to have two
    adjusting screws, one for mixture and one for speed, but this style does
    not.
    If I get too confused might end up posting pictures on my website so we
    are talking about same thing. Diagrams on Bike Bandit are not good enough.
    Ian Singer
    #48
  9. oldgeezer
    B-12 Guest
    Yes, from what I recall, it pushes down toward the float bowl when you
    have the diaphragm cover off.
    It doesn't take a lot of force. There may or may not be a rubber o-ring
    on the jet holder.
    Probably the pilot air jet, which meters air to the idle mixture
    passages.
    Use aerosol carburetor cleaner to spritz it out.
    BS34SS carbs had EPA plugs on top of the carbs.
    Look for a round aluminum plug on top of each carburetor, forward of
    the diaphragm cap.
    You can take a small drill and very carefully make a pilot hole in the
    EPA plug, then enlarge it so you screw a small sheetmetal screw into
    the plug. Then you can pull the screw out with a pair of pliers and the
    EPA plug with come with it.
    Don't drill your pilot hole too deep, you'll hit the idle mixture
    screw. The aluminum plugs are very thin though.
    Once the plug is out, screw each screw all the way clockwise until it
    bottoms lightly, counting the turns.
    Write that number down, it may be unique for each carburetor. Then
    remove the idle mixture screws, keeping track of the spring, tiny
    washer, and tiny o-ring. If there is no o-ring, it's probably still in
    the hole.
    Once you have the idle mixture screws out, you can spritz aerosol carb
    cleaner through all the holes while blocking off some holes with your
    fingers to be sure that you see a strong flow of carb cleaner out of
    each set of holes.
    Then you can re-install the idle mixture screws, paying careful
    attention to the order of assembly. Spring goes on the screw, then
    washer, then o-ring.
    Screw each idle mixture screw back into the same hole it came out of.
    Bottom the screw lightly in the hole, then back it out the same number
    of turns you wrote down, and you will be back to the original factory
    setting, which is probably too lean for easy starting and quick warm
    up.
    You can enhance starting and warm up and throttle response by opening
    the idle mixture screws 1/4 to 1/2 a turn. If the idle mixture is too
    rich, the idle RPM will tend to hang up for a long time when you
    "blip" the throttle.
    There is a photo article on www.thegsresources.com about cleaning a set
    of really grungy carbs. You might learn something useful by looking at
    that page.
    B-12, Nov 22, 2006
    #49
  10. oldgeezer
    John Johnson Guest
    As your conversation with B-12 indicates you have already found: dry
    plugs = no gas = plugged up carbs. I'd urge you to pull down the carbs
    as far as you can, and clean every part as well as possible. You might
    get lucky and _only_ have incredibly plugged-up carbs.
    For the tops, if you're not willing/able to use an impact driver on
    them, you can try heating the screws (be _extremely_ careful using heat
    sources around components that have been in contact with gasoline!). The
    differential heating of steel and Aluminum should break loose the
    corrosion that's holding it all together, and do so fairly quickly.
    Penetrants may or may not work, depending mostly on whether or not you
    can get them into the holes.
    Later,
    John
    #50
  11. oldgeezer
    Ian Singer Guest
    Turns out they were all plugged except for #1 which I can not remove.
    Some of them looked pretty mangled so someone has been in it before. I
    either leave #1 or see if its possible to drill out and put a new one
    in. Inclined to leave.
    Actually it's good and hadn't seen that one before. Suggest the PDF at
    http://www.thegsresources.com/files/GS Carb Cleaning Series.pdf as
    its much easier and makes thing a lot clearer.
    Ian Singer
    #51
  12. oldgeezer
    Ian Singer Guest
    Lists the tang? Not on mine. The tang presses against the float needle,
    it is not connected to it and does not lift it. As the floats raise they
    press against the valve to close it.
    Ian Singer
    #52
  13. oldgeezer
    B-12 Guest
    I've read about a lot of concerns about inadvertently bending the tang
    on the float that pushes against the float valve, and I suppose you
    could bend the tangs out of adjustment if you set the carburetors float
    side down on your work bench with the float bowls removed.
    The pressure of gasoline against the float valve is very low, something
    like 1/4 of a pound per square inch, and the seat area of the float
    valve is far less than 1 square inch, so the float operates against a
    very small resistance from fuel flow, it has a lot more bouyancy than
    the fuel pressure it's trying to
    shut off.
    In fact, a carburetor float will sucessfully control several pounds of
    fuel pressure from an electric fuel pump.
    If the tang was really easily bent under normal operating conditions,
    the floats would go out of adjustment frequently, but they just don't.
    The float valve itself has a small spring on it that takes up extra
    motion of the float, after it has shut the fuel flow off. I'm trying to
    imagine the bouyancy of the float lifting it so hard that the tang
    bends, but I can't...
    B-12, Nov 22, 2006
    #53
  14. oldgeezer
    B-12 Guest
    OK, I looked at the carburetor cleaning photos on
    www.thegsresources.com and found out that the brass tube with its fixed
    starter jet is the fuel supply for the starting enrichener (so-called
    "choke").
    The starter jet has to suck fuel out of a well in the front of the
    float bowl, so cleaning that tube and the well out at the same time is
    important.
    B-12, Nov 22, 2006
    #54
  15. oldgeezer
    Ian Singer Guest
    And as three of them are blocked that would explain three dry plugs.
    Finally got through them with WD40 (as it doesn't stink so bad as the
    carb cleaner in the house) and their "Special Tool" of a wire from a wire.
    Ian Singer
    #55
  16. oldgeezer
    B-12 Guest
    It's amazing that your engine would even run on one cylinder...
    B-12, Nov 22, 2006
    #56
  17. oldgeezer
    Ian Singer Guest
    After replacing spark plugs, cleaning the inside of the carbs, main and
    pilot jets, all except for #1 pilot that will not remove, wiping down
    needle valve, not removing air screws, or adjusting floats, or removing
    float valves, checking diaphragms, replacing bowl screws and top cover
    screws with allen head, it started first time on three cylinders and
    fourth kicked in after a bit. Idle was much too high so adjusted nuts on
    throttle cable.
    Stupid drain plugs were leaking again so had to tighten more.
    Are the air screws with the EPA covers the vertical one on the engine
    side of throat? If so I have no covers on them and can't see how they
    could have them as they sure are not recessed.
    Engine sounds a little loose with a bit of slap someplace. Can't tell
    where, know it has not been running for at least five years so will see
    what it's like when I change oil and filter and put new tires on.
    Thanks for help.
    Ian Singer
    Ian Singer, Nov 28, 2006
    #57
  18. oldgeezer
    B-12 Guest
    Maybe the mechanic who drilled the plugs out adjusted them five turns
    out? Anything more than three full turns open is usually far too much,
    even for a # 35 idle jet.
    If you pull the clutch lever in, and some noise goes away, it is a
    loose clutch basket.
    A metallic clanking sound on the left side of the engine can be a loose
    starter clutch.
    Also, check the cam chain tensioner to be sure that the plunger isn't
    stuck.
    B-12, Nov 28, 2006
    #58
  19. oldgeezer
    Ian Singer Guest
    Thought you were going to say that. On older bikes they were on the side
    of the carb and all you needed was a long screwdriver. Looks like to get
    to these you have to pull the tank and use a super long one. Probably
    before touching them I should run it long enough to check out the plugs,
    and if they look OK maybe not mess with them. Also if there was another
    1/2" of space back to front the carbs sure would be easier to remove.
    As in one of the springs being weak or broken?
    It's not a clanking, and it really does sound like a slapping sound and
    thought it would be from top or bottom of one of the connecting rods
    being worn. Can't isolate where it is but is definitely not cam chain
    hitting something and not a scarping sound. Was too late at night when I
    had it running to rev it up as sounds very throaty.
    Ian Singer
    #59
  20. oldgeezer
    John Johnson Guest
    Most likely just a clutch basket that has enough clearance to rattle a
    bit. Many bikes do it and it's not an issue.
    Later,
    John
    John Johnson, Nov 28, 2006
    #60
