NEED CARBURATOR CHOKE PART 83-86 HONDA VT-500 SHADOW
Discussion in 'Motorbike Technical Discussion' started by mike, Oct 20, 2003.
  1. mike
    mike Guest
    NEED A CARBURATOR CHOKE PART
    FOR A 83-86 HONDA VT-500 SHADOW
    Picture is here:
    http://nm7u.tripod.com/homepage/want.html
    It's the part in the yellow circle. Screws into
    the side of the carb and the right-angle boot
    slips over it. I have the gold tip piece and
    can make the spring. I'd make the missing part out of
    a bolt, but it's 12mm x 1.0 thread and the bolt dealers
    can't get 'em. The only threading die I found cost
    more than the bike. Ideas welcome.
    Maybe I'll have to buy the whole cable assembly.
    Whatchagot?
    Also need a clutch lever for the same bike.
    Probably will find that I need other parts as
    I start putting this rebuilder back together.
    Thanks, mike
    return address is good
    Bunch of stuff For Sale and Wanted at the link below.
    laptops and parts Test Equipment
    4in/400Wout ham linear amp.
    Honda CB-125S
    400cc Dirt Bike 2003 miles $550
    Police Scanner, Color LCD overhead projector
    Tek 2465 $800, ham radio, 30pS pulser
    Tektronix Concept Books, spot welding head...
    http://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Oct 20, 2003
  2. Why don't you just use that lathe and whip one up out of plastic or
    aluminum?
    Kevin Something, Oct 21, 2003
  3. mike
    mike Guest
    That's the fallback position. That lathe doesn't cut threads.
    Plastic will probably "cross thread" from a close SAE thread.
    mike
    Honda CB-125S
    mike, Oct 21, 2003
