Neat blade fuse idea
Discussion in 'Classic Motorcycles' started by 'Hog, Jan 24, 2006.
  1. <raps on monitor>
    Ken? Is that you?
    The Older Gentleman, Jan 31, 2006
    #81
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    LOL! is he *still* banging on?
    Wicked Uncle Nigel, Jan 31, 2006
    #82
  3. doc wrote
    What electrodes?
    No hang on I see where you are coming from now, it's the TV thing innit.
    You are suggesting that as the plasma cloud forms the components combine
    together to form a modest Cockcroft-Walton Voltage Multiplier circuit
    just like you get in televisions?
    Won't happen.
    Better than you understand condensers probably but I am not very good on
    the internal chemistry on modern ones it has to be said.
    steve auvache, Jan 31, 2006
    #83
  4. 'Hog
    zymurgy Guest
    It wasn't me but I do feel eminently qualified to comment [1] if you
    like.
    If you have an MCB on the lighting circuit it is common for a filament
    bulb to cause a nuisance trip. When the bulb blows, there's a large Arc
    current carried by the bulb on the circuit momentarily that trips the
    MCB.
    There's a good write up here from sci.engr.lighting =>
    http://groups.google.com/group/sci.engr.lighting/msg/5e03bf99a8306d5b
    A Type C MCB due to the trip characteristics will reduce the incidence
    of this happening, but not completely.
    As long as your Consumer unit is wired to split lighting circuits
    sufficiently then a bulb blowing shouldn't cause too much
    inconvenience. If it's taking out all the lights in the house, then it
    looks like they're all running through the same MCB, which isn't ideal.
    Either split upstairs and downstairs through 2 mcb's, or (more easily)
    replace the bulbs with energy savers.
    Cheers,
    Paul.
    [1] I have C&G Electrical installations and HND in Electrical,
    Electronic and Communications engineering [2]
    [2] (Cor !)
    zymurgy, Jan 31, 2006
    #84
  5. 'Hog
    Guest Guest
    I want one like you used to get in the Science Museum <evil grin>
    Regards,
    Simonm.
    Guest, Jan 31, 2006
    #85
  6. Most, yes. I'm not misinformed about this; there are thousands of houses
    sitll wired in aluminium.
    Don't believe me? Look it up, and look up the reason for it.
    Grimly Curmudgeon, Jan 31, 2006
    #86
  7. Nope. Go and look for yourself.
    By the way, who mentioned HV cabling? I didn't - I specifically
    mentioned house wiring, a whole different kettle of apes.
    So, you admit that wirenuts are about the equivalent of shite soldered
    joints? Refreshingly honest of you.
    Bty, look up 'creep' with regards to electrical connectors and aluminium
    wiring. It also happens with copper.
    You really are a know-nothing wanker.
    Happy living in your wooden house, are you? With all those dodgy
    electrical connections?
    I sure as shit wouldn't be. Quite frankly, I don't how you can sleep at
    night without worrying about the unseen and unknown connections buried
    in your walls, slowly developing high resistance joints and gradually
    getting hotter.
    Pleasant dreams...
    #87
  8. 'Hog
    Andy Bonwick, Jan 31, 2006
    #88
  9. 'Hog
    kenney Guest
    I would have thought it was fairly simple. You are effectively
    replacing a high resistance coil (filament) with a low resistance
    plasma. The voltage does not have to change for current to
    increase. I would not have thought the inductance of the filament
    would be high enough to be significant,
    Ken Young
    kenney, Feb 1, 2006
    #89
  10. 'Hog
    kenney Guest
    You mean filament bulbs do not have a rated life time in the US?
    Filaments degrade, the vacuum is not perfect for a start, plus
    you get mechanical creep and electrical migration of atoms away
    from the centre.
    Ken Young
    kenney, Feb 1, 2006
    #90
  11. I thought it was that aluminium is half as conductive but a third of the
    weight. steel core for strength and aluminium for current carrying and
    lightness.
    copper not strong enough, neither is alu, for big runs of cable.
    Austin Shackles, Feb 1, 2006
    #91
  12. IRTA "craps on monitor"
    #92
  13. wrote
    Where does the plasma come from? How long does this take to happen?
    what occurs before the plasma develops? Are conditions within the
    envelope of the bulb the same in every instance?
    Neither would I but what do modern solid state sensing devices sense is
    it voltage or is it current? Are they sensing the slope of the change
    and interpolating from that or are they working slightly behind time?
    steve auvache, Feb 1, 2006
    #93
  14. 'Hog
    Austin Shackles emerged from their own little world to say
    That's what I (mis)remember from college 16 years ago.
    wessie, Feb 1, 2006
    #94
  15. 'Hog
    kenney Guest
    The filament gets hot enough to vaporise. Because the resistance
    drops it does not stay hot and the tungsten condenses on the
    glass. In my experience conventional light bulbs usually go when
    switched on.
    Ken Young
    kenney, Feb 1, 2006
    #95
  16. Grimly Curmudgeon, Feb 2, 2006
    #96
  17. 'Hog
    Guest Guest
    Guest, Feb 2, 2006
    #97
  18. Grimly Curmudgeon, Feb 3, 2006
    #98
  19. 'Hog
    David Toft Guest
    This one is priceless...
    How about this scaffolding
    http://electrical-contractor.net/ubb/Forum4/HTML/000870.html
    David Toft, Feb 3, 2006
    #99
  20. Priceless. Mind you, as one of the posters says there, if it wasn't for
    HSE and similar, we'd still be doing shit like that.
    It wasn't so long ago I walked off a job when asked to rewire some barn
    lights by standing in a tractor bucket.
    ****'em.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
