Neat blade fuse idea
Discussion in 'Classic Motorcycles' started by 'Hog, Jan 24, 2006.
  1. Leakage currents from something (but see 2).
    1. Check if the immersion is wired from the RCD - to avoid nuisance
    tripping, it shouldn't be. The cooker shouldn't be either, but if it is,
    you might have a dodgy leaky switch and element.
    2. The RCD might have gone over-sensitive and might be tripping on as
    little as 5 or 10mA leakage current.
    3. As it happens, all the wallwarts and computer PSUs plus all the other
    bollocks that's left plugged in 24/7 these days can contribute quite a
    bit in leakage current. Comp PSUs are bad for this, if you have 5 or 6
    running.
    4. To avoid angst, arrange a non-RCD feed to your freezer.
    Grimly Curmudgeon, Jan 29, 2006
    #41
  2. Bang wheeeeee... rat a tooie.
    They're little cunts for that. Mice, otoh, don't seem to like PVC.
    #42
  3. 'Hog
    muddy Guest
    We had a snake get across the 480V buss for a fan. We never figured out
    how it got inside the panel.
    muddy, Jan 29, 2006
    #43
  4. 'Hog
    deadmail Guest
    Oddly, it took a day or so to find it and by the time we found the rat,
    it was only half a rat. We made the assumption it was another rat that
    had eaten half of it.
    We had to use the backup method of driving the milking plant (from a
    tractor's PTO)
    deadmail, Jan 29, 2006
    #44
  5. 'Hog
    Dan L Guest
    the man with no idea wrote:
    Heh, same here. Just ordered some from TLC for my Wylex Board.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Jan 29, 2006
    #45
  6. 'Hog
    Dan L Guest
    Having just googled the Wylex pug in jobbies, they only seem to be available
    as B Rated. A motor rated (C or D) breaker might prove more robust, might
    be worth contacting Wylex to see if a motor rated version is available.
    Dan L (Oldbloke)
    Dan L, Jan 29, 2006
    #46
  7. 'Hog
    Guest Guest
    Wot eee said...
    Regards,
    Simonm.
    Guest, Jan 29, 2006
    #47
  8. 'Hog
    Guest Guest
    Replace the CB.
    I've been told they trip if the bulb filament vaporises sufficiently
    well when it blows and the conductivity shoots up for an instant,
    allowing enough current to flow to trip the breaker. This seems to be
    right, as I've found some brands (Philips especially) seem to do it more
    than others. If the CB is ageing, it'll trip too easily.
    That's house wiring. I guess it's similar on a bike.
    Regards,
    Simonm (who couldn't be a###d except he's had to give up on the car's brake
    pads as (a) it's far too cold and (b) he's not got the right socket...fnarr.)
    Guest, Jan 29, 2006
    #48
  9. 'Hog
    doc Guest
    Could be. Thermal protective circuits tend to degrade over time, especially
    if they are periodically exercised. Sort of like the pop-up indicator on a
    Butterball turkey, but not really.
    doc
    doc, Jan 30, 2006
    #49
  10. 'Hog
    doc Guest
    OIC. The excess current that causes your light bulb to blow isn't a "short
    circuit."
    That bit was written in fun. I thought you Brits and your celebrated sense
    of humor would appreciate it. I forgot that you're also a bunch of
    curmudgeons with stiff upper lips and no sense of humor at all. My mistake.
    Please don't slaughter everyone in my village in order to put me in my
    place.
    Will you return the favor?
    doc, Jan 30, 2006
    #50
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, doc
    The excess current... That causes...
    Oh, FFS. You really are incredibly stupid, even for a Septic.
    With pleasure.
    <plonk>
    Wicked Uncle Nigel, Jan 30, 2006
    #51
  12. 'Hog
    doc Guest
    Wasn't it you who said to put a nail across it? Here's the deal: I'll take
    you seriously if you'll return the favor. Or I'll laugh if you'll laugh.
    Or any combination of the two. I'm flexible.
    doc
    doc, Jan 30, 2006
    #52
  13. 'Hog
    doc Guest
    So, if it isn't excess current that causes the bulb to blow and the circuit
    breaker to trip, what is it? Excess voltage? Insufficient resistance? A
    newly discovered exception to Ohm's Law that only applies to this
    particular circuit? Faeries?
    You don't have a fucking clue, do you? And you call me stupid?
    Oh, that's right; I've been plonked, so you get to continue with your
    dismal ignorance without having to listen to anyone who you disagree with.
    Shut out the light, WUN, and only darkness ensues. Not that you'd ever
    understand, you close-minded little troglodyte.
    All my best,
    doc
    doc, Jan 30, 2006
    #53
  14. 'Hog
    DR Guest
    Don't worry about it, the RAF are precision-bombing experts;
    carpet-bombing is the USAF's gig.
    DR, Jan 30, 2006
    #54
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, doc
    Oh wait, I see the problem. You're American.
    OK, one last time, go and read up on UK (this is a UK group, y'know)
    household electrical systems.
    When you understand ring mains and that we don't have primitive
    individual feeds to each light (we don't use those fucking awful wire
    nuts either), then and *only* then will you be able to offer any sort of
    opinion on the cause of the problem.
    Clue. Whenever *any* bulb on the circuit blows (and they blow through
    old age, not because of a fault in the wiring) then the single CB that
    protects *all* the lighting circuits in my house pops.
    You see, in this context, you're the one without a clue.
    #55
  16. doc wrote
    Well, most commonly it is not a short circuit which makes the bulb blow
    in the first place but the bulb blowing in the first place that causes
    the short circuit. That is often what happens most of the time but not
    all of it. It is the debris from the disintegrating innards of the bulb
    landing where it shouldn't which actually conspire to cause the short
    circuit which makes the trip trip or the fuse blow depending on your
    personal technological environment, or the nail get hot. As to what
    makes the innards of the bulb disintegrate that is something that we are
    perhaps better off not knowing given the OP. As to what makes the bulb
    go that will depend on the bulb but most of the time it is put down to
    old age even when the old age is artificially induced by mistreatment.
    steve auvache, Jan 30, 2006
    #56
  17. Wicked Uncle Nigel wrote
    That's not right Nige, I'd do something about that if it were me.
    Well actually I wouldn't but we're not here to discuss me are we?
    #57
  18. 'Hog
    doc Guest
    Crap. At least with the USAF, I'd stand a chance as long as I was at
    ground-zero. Whatever happened to the British tradition of sportsmanship?
    Best,
    doc
    doc, Jan 30, 2006
    #58
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, steve auvache
    Yeah, I know. It's only the CB that plays up. If I bung the
    old-fashioned wire fuse back in there all is well.
    I think the CB's just too sensitive and the slight spike as the blub
    blows trips it.
    An electrician friend said "yeah, mine does that too...". Very helpful.
    I know (as I think Zymurgy mentioned up ^^^ there) you can get some
    slow-blow CB's that are less sensitive to very short spikes. I was
    hoping someone could recommend a model.
    Then Johnny Septic started shouting bollocks, and it all got rather
    tedious.
    Why ever not? How's life in Essex? MongVan back on form, is it? Up for a
    repeat trip to Dingle's World Of Closed Steam if I get back down to
    ooh-ahrr land this year?
    #59
  20. 'Hog
    Don't worry. This is ukrm, not the US Army.
    platypus, Jan 30, 2006
    #60
