Neat blade fuse idea
Discussion in 'Classic Motorcycles' started by 'Hog, Jan 24, 2006.
  1. 'Hog
    Eddie Guest
    Isn't that an old "trick" for forcing oneself to make up ones mind?
    Get a coin, and say heads it's 'A', tails it's 'B'; toss it in the air,
    and before it comes down you'll probably have decided which way you want
    it to land.
    That's the theory, anyway. Whether it works in practice is another matter.
    Eddie, Jan 26, 2006
  2. 'Hog
    Eddie Guest
    Well, something like that anyway.
    The cash is always the problem for me. Although that situation looks
    like it should improve shortly.
    < snip >
    But why did you decide to sell it? Does whatever convinced you to make
    that decision still apply?
    Eddie, Jan 27, 2006
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, the man with no
    They do. Circuit breakers.
    The only problem with them on the lighting circuit is that when a bulb
    blows it trips the breaker, killing all the lights.
    Unless anyone knows a better solution...
    Wicked Uncle Nigel, Jan 28, 2006
  4. 'Hog
    A circuit for each light? :)
    Muck, Jan 28, 2006
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, the man with no
    <waggles feet, realises he's out of depth>
    Dunno mate. I found some doo-hickeys that plugged straight into the
    wossname, replacing my cartridge fuses with circuit breakers.
    Wicked Uncle Nigel, Jan 29, 2006
  6. Yep, some CUs were sort of future-proofed with that in mind, but these
    days yer standard MCB mounts on a DIN rail, which most of the old fuse
    boxes didn't have.
    As an aside, the previous generation leccy fuse boxes common in Ireland
    were made and supplied by Siemens - which handily enough have a DIN rail
    inside.
    Grimly Curmudgeon, Jan 29, 2006
  7. 'Hog
    doc Guest
    All circuit breakers have an ampere rating, e.g., 20 amp & 30 amp, the most
    common household ratings.
    All circuit breakers and household circuits employ the "selectrive
    tripping" principle. I.E., the further the circuit from the common circuit
    breaker, the fewer amps it takes to trip. In other words, a light bulb
    should burn out before the circuit breaker trips.
    It makes sense, actually. Why put a 10 amp fuse to protect a 20 amp
    circuit?
    The problem with these new blade fuse circuit breakers is the same problem
    with any thermally-protected circuit: the more they trip, the lower the
    current they trip at. And binding them down with tape or any other method
    is pretty much the same as just replacing them with solid 4-gauge wire, if
    they can even be held down and maintain continuity in the first place,
    which is highly doubtful. Almost all thermo-trip devices need a cooling-off
    period before they can be reset. Holding them down just ensures they never
    get the chance. Sort of like the pop-up indicator on a Butterball turkey.
    Tape that baby down and you'll have the driest bird in town.
    More likely, though, is that nothing will happen: taping down the reset
    button never allows the circuit to reset since the excess current never
    stops, and the likely result is either no current at all or melting of all
    all insulation and all small-gauge wires between the problem and the source
    of power. In other words, if there's a short circuit, bypassing the
    protective circuits gains you diddly-squat. You're shit-out-of-luck. You're
    up shit creek without a paddle.
    You're boned.
    If your circuits blow a fuse, or a circuit breaker, or one of these
    marvelous, expensive blade-type resettable hoo-haws, you still have a
    problem and haven't fixed it. Anytime a protective device actuates, you
    better find out why before you attempt to reset it, and fix the problem
    that caused it. Ohm's Law, gentlemen, has so far proven to be immutable:
    decrease the resistance and you'll increase the current. That protective
    device gave maximum resistance when it tripped; that's what's we want: no
    electrical current. Reset it and you give minimum resistance and, ergo,
    maximum current. Ever watched your motorcycle's wiring harness shrivel up
    and smoke as you're doing the ton?
    Best,
    doc
    doc, Jan 29, 2006
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, doc
    Fascinating.
    I expect.
    Meanwhile, back on planet Earth...
    Anyone know a good solution (other than putting the wire fuse back) to
    my (really rather minor) problem of why my CB trips whenever a bulb
    blows?
    (For the terminally paranoid amongst us, the CB can be reset immediately
    after it trips, so long as you can find the fucking thing in the dark).
  9. 'Hog
    Wicked Uncle Nigel emerged from their own little world to say
    Use a new fangled low energy, long life bulb you fucking pikey
    wessie, Jan 29, 2006
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    Ah, but how would this work with the dimmer that I use to get Mrs WUN in
    the mood for conjugal wossnames?
    Answer me THAT!?
    Anyway, they still blow (eventually) and they take too long to "warm
    up".
    And they look funny.
    Apart from that, good idea.
    Well done.
  11. 'Hog
    Do they? Never had one go yet.
    The Phillips ones that Powergen sent as a freebie are hopeless in that
    respect
    Only because you are a reactionary git
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    Have you *seen* my garage?
    Of course I am.
  13. 'Hog
    doc Guest
    So you say.
    Why, pray tell?
    No doubt; no doubt, sir.
    Of course, sir; of course one doubts. It's akin to saying that the Earth
    rounds the sun, isn't it? Pure poppycock and blasphemy, eh? Pure poppycock
    and blasphemy, indeed!
    Ahh, I see. Georg Ohm's laws don't apply to Twits or Brits.
    German, wasn't he?
    Deuced shame he wasn't British! Pity!
    One lump or two, m'lord?
    And how's the British Empire doing these days, m'Lord? Just asking for us
    wogs, of course, m'Lord. We couldn't understand, of course, m'Lord.
    You have a short-circuit. Your circuit is drawing more current than it's
    designed for. Any time a circuit draws more current than it's designed for,
    the protective circuits will activate. In your case, it's a fuse. The
    solution for you, as a Brit, is to keep increasing the amperage of the fuse
    that you use until it stops blowing.
    For non-Brits, check each branch circuit. Use the standard
    open-circuit/closed circuit troubleshooting method.
    For Brits, replace everything at the greatest expense until it's either
    fixed or you invoke the Royal "**** it! It's good enough!" Then install
    anything from Lucas.
    Pity that Georg Ohm was a German, eh? You Brits might have escaped Lucas
    electrics!
    Still love you, though,
    doc
    doc, Jan 29, 2006
  14. Learn to snip, newbie....
    The Older Gentleman, Jan 29, 2006
  15. 'Hog
    Mo Childs Guest
    My main house rcb tripped last night at about 2am under as light a load
    as it's likely to get. It does that once every 3 or 4 months, any
    suggestions as to why?
    Mo Childs, Jan 29, 2006
  16. 'Hog
    deadmail Guest
    Rats.
    We had rats in one of the farm buildings attack the wiring once. My
    father was milking, suddenly there was a bang, the machinary stopped and
    the lights went out. A rat had been chawing its way through the cables
    and suddenly made contact.
    deadmail, Jan 29, 2006
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, doc
    No I don't, you stupid bastard.
    The CB trips whenever a bulb blows. Other than that, it's fine.
    Point me to the bit where I increased the "fuse" rating. I just sigh,
    reset the CB and all is well. Until the next CB blows.
    Now do me a favour and **** off, eh?
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Mea Culpa.
  19. Replace the MCB, it's probably drifted down in sensitivity.
    Or just put a nail across it.
  20. Do you actually have any idea what you're talking about?
