Navagtion Aids
Discussion in 'Australian Motorcycles' started by will_s, Jul 18, 2007.
  1. will_s
    will_s Guest
    After something like a Tom-tom for my bike and Car . So what ever I buy
    will have to be easily moved between them. Ok, I have the BMW K1200R and it
    has a socket but will that work for these devices ?
    Also how would you go about getting earphones etc in the helmet so you can
    hear the instructions and / or mp3's ( helmet is a Nolan Classic N-Com
    N102...well will be when I get the parts that fell of replaced )
    And yes the amount of research I have done is sfa because I believe the
    intelligence and experience in this group will give outstanding results (
    thats my groveling for this year done )
    thanks
    will
  2. will_s
    Nev.. Guest
    I can't speak for the other brands available, but Tomtom Rider can
    switch between car and bike easily but doesn't have a speaker so you can
    only hear instructions through a bluetooth headset. Doesn't bother me
    at all of course. The instructions are fucking annoying. I prefer to
    glance at the screen occasionally instead. As for the power the TomTom
    Rider mounting bracket is powered so you just wire that directly into
    your fusebox.
    TomTom comes with it's own bluetooth headset (mono). I made my own
    adapter so that I could just plug in my headphones I use with my MP3
    player instead. Have only used it once on the bike, riding through
    Sydney. Didn't really enhance the experience much over just looking at
    the screen. Having a voice spewing out instructions repeatedly is quite
    annoying.
    Nev..
    '04 CBR1100XX
    Nev.., Jul 18, 2007
  3. will_s
    Burnie M Guest
    Burnie M, Jul 18, 2007
  4. will_s
    will_s Guest
    Thanks Nev
    How do they hold up in the rain ? I hope they are sealed and I assume they
    are on the expensive side
  5. will_s
    will_s Guest
  6. Have a look at the Garmin Quest. There is a motorcycle powered cradle (with
    audio socket) available. I use one in both my ute and my K1100RS.
    Andrew
    Andrew Hatcher, Jul 19, 2007
  7. will_s
    Theo Bekkers Guest
    Maps are much cheaper. I highly recommend the Australian Motorcycle Atlas.
    Fits neatly in the plastic see-through bit on the tankbag too. $26.95.
    http://www.guidesgalore.com.au/default.asp?p=product&productid=4149
    Theo
    Theo Bekkers, Jul 19, 2007
  8. will_s
    Burnie M Guest
    The argument goes
    "A paper map cannot fail like an electronic device"
    To which the response goes
    "Ever tried to read a paper map at 110kph in the rain ?"
    A GPS is significantly more useful than a paper map
    I use both
    Burnie M, Jul 19, 2007
  9. will_s
    Burnie M Guest
    GPS to consider for onroad use;
    Garmin zumo
    GPSmap 276C
    Quest
    GPS to consider for offroad use;
    GPSmap 276C
    GPSmap 60Cx
    Magellan eXplorist XL
  10. will_s
    CrazyCam Guest
    Often. It isn't hard.
    As Theo said:"Fits neatly in the plastic see-through bit on the tankbag".
    For road use, a GPS is only as good as the electronic mapping available.
    As I understand it, mapping of Oz is sufficiently good to make GPSs
    useful here, but I'm still trying to find decent e-mapping for Greece.
    regards,
    CrazyCam
    CrazyCam, Jul 19, 2007
  11. will_s
    Theo Bekkers Guest
    You could get a paper map, but they'll be all Greek.
    Theo
    Theo Bekkers, Jul 20, 2007
  12. will_s
    CrazyCam Guest
    Indeed, Theo, I have, in the past, managed with paper maps in Greek.
    The big trouble with navigating in Greece is that most of the signs by
    the road side have been covered over by adverts for the local
    butcher/nightclub/drug dealer, so it becomes a full time job being
    navigator.
    Angie is not, understandably, interested in doing that full time job,
    but neither is she particularly keen on driving over there.
    She helps out by doing all the swearing. ;-)
    If I can get a system which warns me when I am 100 metres away from ,
    say, a right turn, I can then see if there is indeed such a right turn,
    or, perhaps that the road junction has been re-aligned in some way.
    (which happens a lot in Greece).
    Even a "moving map" type system would help considerably, without the
    turn by turn instruction.
    I have Microsoft's Autoroute software, which claims to cover Europe,
    but, while it seems to give excellent coverage of Scotland, is pathetic
    for Greece, outside of Athens.
    So far, the best I have found is OziExplorer on the laptop, with a blue
    tooth GPS, and marine charts for Greece, which also show quite a
    reasonable range of the major roads.
    Given the wide variety of (often unexpected) expertise in all sorts of
    stuff displayed by aus.moto folk, I thought I'd mention the problem in
    case someone had a solution.
    regards,
    CrazyCam
    CrazyCam, Jul 20, 2007
  13. will_s
    Theo Bekkers Guest
    Next you'll be expecting a policeman who can spell!
    If I was doing a drive-yourself in a country where I didn't speak the lingo
    or recognise the alphabet, I'd certainly be looking at a Nav-system. In Oz,
    I'd stick to paper maps. Now if I was going to Scotland........
    Theo
  14. will_s
    CrazyCam Guest
    Even being comfortable with the language and alphabet, I am looking for
    a Nav-system, as I have explained.
    Me too. After all, while it _is_ a big place, there aren't really that
    many roads. :)
    you'd have absolutely no problems at all.
    You'd be able to read the street signs, and probably have a better
    chance than most english folk of pronouncing place names.
    Paper maps, OS 1" to the mile, are absolutely superb.
    You'd also have a better shot at understanding most Scottish accents
    than the poms do.
    Remember, Dutch is only bad German, spoken with a Scottish accent.
    regards,
    CrazyCam
  15. will_s
    Theo Bekkers Guest
    That may be the Scottish perception. The reality is, when I was last there,
    I might as well have been in Greece. Reading signage was not a problem,
    verbal directions were given in an entirely different language. :)
    Theo
  16. will_s
    CrazyCam Guest
    Ah, I see what you were doing wrong.
    Even Scottish folk don't ask for verbal directions unless they are in
    their own town or village.
    The folk just up the road talk funny and are a bit hard to understand.
    Stick to showing them a map and getting them to point to where you are.
    :) (Kinda like a non-electronic GPS!)
    regards,
    CrazyCam
  17. will_s
    Theo Bekkers Guest
    I had more luck in Germany (Dutch _is_ a different language by the way),
    people there tried to speak English, not thought they were.
    Theo
  18. will_s
    CrazyCam Guest
    Moite, you are fishing again! :)
    If Scottish folk thought they were english they would either run away to
    the other side of the world, or try and drink themselves to death as
    quickly as possible.
    Hmmmm, maybe that's what we are doing wrong?
    regards,
    CrazyCam
  19. will_s
    a t e c 7 7 Guest
    In what manner does their version of point differ ?
    a t e c 7 7, Jul 20, 2007
  20. will_s
    a t e c 7 7 Guest
    That reminds me about a joke that starts
    "One fine day in Scotland a troop of Roundheds were marching ..."
