natural gas
Discussion in 'Motorbike Technical Discussion' started by zoot, Sep 17, 2008.
  1. zoot
    zoot Guest
    should be clean and cheap. anyone tried to convert yet? what would it
    take?
    zoot, Sep 17, 2008
  2. zoot
    . Guest
    1. A fearless rider who doesn't mind having a 6000-psi compressed gas
    cylinder in close proximity to his family jewels.
    2. A special compressor capable of filling the compact pressure bottle
    to 6000 psi.
    ., Sep 17, 2008
  3. zoot
    S'mee Guest
    Only partially correct. The problem is NOT the saftey of the tank but
    rather the shape. Currently I'm only aware of cylindrical tanks being
    made. None mountable in an aceptable manner. 8^( There was a company
    in england attempting to make tanks that are usable on a motorcycle.
    LOL no you pull up to a filling station that delivers CNG with no
    problems but good try at being a spoil sport.
    S'mee, Sep 18, 2008
  4. zoot
    . Guest
    OK, so what pressure does the station deliver the CNG to your tank?
    And what does it take, about ten gallons of CNG to go 200 miles?
    That's a rather inconvenient cylindrical tank to be straddling...
    ., Sep 18, 2008
  5. zoot
    S'mee Guest
    I'd have to ask. Might later this week as I've two 5gal tanks to top
    off.
    I've never heard data on how far you can go on a CNG fuel motorcycle.
    I to would like to know.
    They were working on shapes more plauable to motorcycle usage for just
    the reason you gave. It's an akward problem to be sure. I know I don't
    have the answers. But I'm sure there is somebody or some corporation
    out there that can do it. The question then is WILL they do it. I
    think it would be interesting to see if they work it out. Until then
    we'll have to settle for gas, diesel, electric or steam.
    S'mee, Sep 18, 2008
  6. It's interesting that you're buying CNG the same way
    you can buy propane. A neighbor was happily running
    a CNG Honda as a commute vehicle and refueling it
    at a local filling station in the bay area.
    Apparantly $5-6 grand gets you a home refueling
    station if you want it.
    http://www.newsweek.com/id/154709/output/print
    My understanding is that by volume, a gallon of CNG
    gives you roughly 70% of the energy of a gallon of
    gasoline.
    Any gaseous fuel will run way cleaner than gasoline or
    diesel. I put 12,000 hours on a propane powered genset
    that was still running strong on the original valves and
    rings when we sold the house. No contamination of
    the oil or washing it off the cylinder walls. The used oil
    comes out clean but somewhat thicker on oil changes.
    Rob Kleinschmidt, Sep 18, 2008
  7. zoot
    . Guest
    3,600psi, according to Rob's article.
    Do you really *want* a pressure bomb in your crotch?
    ., Sep 18, 2008
  8. zoot
    . Guest
    We had two propane-powered Cushman three-wheelers to get around the
    wastewater treatment plant. They would only be driven 2 or 3 miles a
    day and it seems to me like we were only getting about 100 miles on a
    5-gallon tank of LPG.
    ., Sep 18, 2008
  9. Nice chart of energy content found at the URL below
    Fuel Type BTUs Per
    Unit Gallon Equivalent
    Gasoline, regular unleaded, (typical) 114,100
    1.00 gallon
    Gasoline, RFG, (10% MBTE) 112,000
    1.02 gallons
    Diesel, (typical)
    129,800 0.88 gallons
    Liquid natural gas (LNG), (typical) 75,000
    1.52 gallons
    Liquefied petroleum gas (LPG or propane) 84,300 1.35
    gallons
    http://tinyurl.com/2alhb
    http://www.nafa.org/Content/Navigat...els/Energy_Equivalents/Energy_Equivalents.htm
  10. zoot
    . Guest
    So you would need 7.5 gallons of LNG to equal the range of 5 gallons
    of gasoline...
    That's a *huge* gas tank...
    ., Sep 18, 2008
  11. zoot
    S'mee Guest
    Read what I said earlier...any way if the tank is certified, has good
    reliable saftey valve. Well then I have no problem as long as it fits
    in the OEM location of my motorcycle with no modifications to the
    frame. It's hard ever get truly scared after you've driven through
    minefields in the dark "Sure it's safe the engineers cleared them".
    Aint' skeered no mo'.
    8^)
    S'mee, Sep 18, 2008
  12. zoot
    . Guest
    Most people recover from their military experience after twenty years
    or so and they usually realize that most people don't care about their
    war stories
    after only about one year back home.
    ., Sep 18, 2008
  13. zoot
    S'mee Guest
    And some of get over before we got out and just love tellin' war
    stories...the cunts that couldn't cut it tend to piss and moan about
    the story tellin'. ;^) I could have said that after you've been punted
    by a horse you no longer get scared easy.
    S'mee, Sep 18, 2008
  14. zoot
    S'mee Guest
    and some people kiss krustys ass but you don't see me getting on their
    case do you?
    S'mee, Sep 18, 2008
  15. Depends. A truck diesel, running with a cat and a CRT, actually emits
    less NOX, CO2 and even particulate matter than a gas truck running
    without.
    I've driven both diesel and gas powered heavy trucks. fascinating. The
    gas powered trucks run a lot smoother. Range is the crucial problem with
    them.
    The Older Gentleman, Sep 18, 2008
  16. Or: do you want thin-wall mild steel, or even plastic, that contains
    four or five gallons of high-octane petrol?
  17. zoot
    S'mee Guest
    That stuff will stick to you! DAHIKIJK okay?
    S'mee, Sep 18, 2008
  18. Well actually, when I spoke of "cleaner" I was thinking of
    mostly of oil and internal engine contaminants, though
    I would have expected good emissions as well. I
    really like the lack of oil contaminents.
    And when you speak of "gas", this is CNG or propane or
    "gas" as American for gasoline ?
    NOX and CO2 would seem to be pretty much a given for
    any ICE, though you might expect less CO2 and more H2O
    for CNG.
    Lower particulates seems surprising.
    How about hydrocarbons ?
    Rob Kleinschmidt, Sep 19, 2008
  19. My current gasoline tank is 6.5 gallons and I'd like larger.
    MPG, range and tank size is a legitimate criticism though.
  20. That was pretty much my thought, though I think
    I'd want the safety valve pointing somewhere other
    than at my crotch. If nothing else, flash frostbite
    on the family jewels sounds very unpleasant.
