Name That Thread.
Discussion in 'UK Motorcycles' started by Krusty, Nov 9, 2007.
  1. Krusty
    Mine should handle significantly better with all the fancy new
    suspension components[1] & poly bushes. With a bit of luck I'll get the
    brakes fitted today, then it should be ready for an MoT next week.
    [1] The composite rear spring is a work of art, & weighs about as much
    as a sandwich.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Nov 10, 2007
  2. Krusty
    Beav Guest
    Well as this thread began with wheel nuts, I thought it might not be a bad
    idea to keep them in the discussion.
    I tend to use metric threaded nuts for metric threaded bolts/studs/whatever
    and the same thing with UNF, BA and Imperial, so no I've not tried mixing
    and matching.
    I'm sure it does, but you're pressing a point that was never made. I said
    that there's no perfect match and so far you've not convinced me otherwise.
    "Close", "pretty close" and "might" aren't "perfect".
    I wonder what your definition of perfect is? "Close enough" doesn't do it
    for me.
    Exactly my point.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 10, 2007
  3. Krusty
    In the case of 19mm v 3/4" I'd say you'd be hard pushed to describe it
    as being less than perfect. You'll get a bigger difference in the
    tolerance on the flats across the fastener.
    Andy Bonwick, Nov 10, 2007
