nail in rear tire
Discussion in 'Texas Bikers' started by Lynn McGuire, Jan 23, 2004.
  1. Lynn McGuire
    Lynn McGuire Guest
    I noticed last Wednesday night that I have a nail in my rear tire.
    My tire pressure is not noticably down (I have yet to check it). I
    did not pull the nail out yet (I figure that I will wait for someone
    who knows something to do that).
    Should I patch/plug the tire or replace it ? I called Wild West
    Honda in Katy and they said that they could vulcanize patcht the
    rear tire for $100. Or, they could sell me a new rear tire for $200
    mounted. Is the patch a little high ?
    Thanks,
    Lynn McGuire
    2000 Nighthawk 750
    www.mylinuxisp.com/~mmcguire/
  2. Lynn McGuire
    Lynn McGuire Guest
    I think that $100 bucks for a patch is high. I think I paid $75 once to the
    Yup, the nail is in the middle of the tire. It is a small nail (about
    a 8 penny I think). The tire is 3 years old and has 3000 miles
    on it (with a lot of tread !).
    THanks,
    Lynn
  3. Lynn McGuire
    Lynn McGuire Guest
    Your best bet for your safety is to replace the tire. I wouldn't trust a patch.
    If it was my front tire then I would replace it no questions asked.
    But, the back tire ?
    Thanks,
    Lynn
  4. Lynn McGuire
    Bill Walker Guest
    Tube type or tubeless ?
    Bill Walker, Jan 23, 2004
  5. Lynn McGuire
    res0f8mp Guest
    id say stick a tube in it.
    (after you yank the nail out and it IS in fact leaking. ) it might not
    leak.
    res0f8mp, Jan 23, 2004
  6. Lynn McGuire
    Lynn McGuire Guest
  7. Lynn McGuire
    Bill Walker Guest
    Plug the thing and forget it.. Use a good quality plug .. With no more miles
    than you have on that tire, you should be alright.. A small nail hole that
    is straight in doesn't tear or rip the tire .. The suggestion to use a tube
    makes the tubeless concept useless.. If you do that, you'd be better off to
    replace the tire.. If that tire isn't obviously losing air pressure, then
    the damage is slight.. When you pull the nail, be sure to have the kit ready
    to install the plug.. Good luck..
    Your friend in Irving
    Bill Walker
    Bill Walker, Jan 24, 2004
  8. Lynn McGuire
    Ed Stimach Guest
    Plug it Lynn.
    Wild West Honda sells the Stop and Go Tire Plug Kit.
    It works great!
    -- Butch --
    Ed Stimach, Jan 24, 2004
  9. Lynn McGuire
    Lynn McGuire Guest
    Plug it Lynn.
    I just ordered this off the internet last night from http://www.stopngo.com/plugger.htm
    I did not know that Wild West Honda sells the kit also. Maybe I
    need to ride over there tomorrow.
    Lynn
    Lynn McGuire, Jan 24, 2004
  10. Lynn McGuire
    dave d Guest
    I know in my heart the smart thing is to replace the tire, but when it
    happened to me a brand new tire I plugged it and then later patched it. I'm
    still alive, but I don't ride very hard and maybe I've just been very lucky.
    I got a big old nail right in the middle of the tread of the my rear tire on
    my Fireblade. The tire had lost no pressure, I don't know how long it had
    been there. It deflated immediately when I pulled the nail out. First I
    plugged it with a cheap kit I bought at an auto shop. The plug was a goody
    pipe cleaner looking thing that you push in and twist. About two weeks
    later I decided to patch it. I left the wheel on the bike and fought that
    bead for several hours with clamps and such until it finally broke loose. I
    expected the plug to be mushroomed flat against the inside tire wall, but
    instead it looked like a round wad of gum. If I ever plug a tire again I
    will definitely get some decent mushroom plugs. I was glad to get that
    thing out of my tire. I cleaned and patched the tire and fought the bead
    again for several hours until it finally seated and the tire inflated. It
    was REALLY difficult to seat that bead. I spent about everything I saved
    doing the job myself on a decent air compressor. I bet it would be much
    easier if one had access to a really high-volume air source. I never took
    the wheel off of the bike or the chain off of the sprocket. No, I didn't
    balance the tire.
    I have over 10K on the tire since the repair and plan to replace it soon,
    and am really curious to see what it looks like in there.
    Gook luck!
    ----- Original Message -----
    Newsgroups: tx.motorcycles
    Sent: Friday, January 23, 2004 3:41 PM
    Subject: nail in rear tire
    dave d, Jan 24, 2004
  11. Lynn McGuire
    Bill Walker Guest
    lucky.
    You can consider yourself one of the worst nightmares to the dealers who
    sell tires.. LOL.. They don't like it when someone insists on a patch rather
    than buying a new tire.. Maybe if more of us "repaired" rather than
    "replaced", the price on those puppies might come down a bit.. Within
    reason, of course.. repair of a perfectly good tire is the most reasonable
    option..
    Sheesh.. that is the tough way to attack a tire, alright.. You are
    definitely tougher than I am.. LOL.. A slip in "mushroom" is the way I have
    done it.. With good results.. That way, you don't HAVE to remove the wheel..
    If I were going to install a vulcanized type patch, I'd go ahead and remove
    the wheel and dismount the tire..
