MZing
Discussion in 'UK Motorcycles' started by JH, Oct 27, 2003.
  1. JH
    JH Guest
    Simply because I'm a mad bastard i decided to test the ExSweller, ExTog
    TS-150 on the work commute. Frost, Fog, mental cages on the A27/M23 duly
    despatched on the little beasty droning along at 50-55mph for 50miles.
    Now i wonder how good the lights are for the madness of the rush hour
    motorway dash home...
    Wish me luck...
    JH
    <makes mental note to get tax disc>
    JH, Oct 27, 2003
  2. JH
    You really live on the edge Man....
    Hog, Oct 27, 2003
  3. JH
    Welcome to the world of CG125 like perfomance..
    Muck
    Bandit 600n(With added ducktape); CG125(MSOHPR)
    "CG125 the most fun you can have at Mach 0.08539"
    DS#1 ; DOMO#1 ; SH#2 ; ICQ: 166144431
    Remove _TEETH_ to e-mail
    Muck, Oct 27, 2003
  4. JH
    JH Guest
    Indeedy, but with the added bonus of smelly faintly of 2 stroke oil when you
    get to work...:)
    JH
    JH, Oct 27, 2003
  5. JH
    JH Guest
    Probably more scary than a ton on a Gixxer to be honest...
    JH
    JH, Oct 27, 2003
  6. MZ headlights are the best 6-volt lights you'll find. Seriously.
    The Older Gentleman, Oct 27, 2003
  7. IF all the connections are clean and tight. But it's a bit like saying
    that my 3-legged dog is the best 3-legged dog in the neighbourhood.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Oct 27, 2003
  8. JH
    It's that pesky volts, amps, resistance thing.
    I've had 12v systems that were worse, even in good condition, than some
    of my MZ's. I've also had hideous 6v ones as well...
    sweller, Oct 27, 2003
  9. JH
    and ending up smelling like burned 2 stroke oil after a while too. :)
    Muck
    Muck, Oct 27, 2003
  10. JH
    Muck wibbled like a little girl....
    <fx: sniffs clothes>
    Yep, it takes ages to go away too.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3.
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 28, 2003
  11. JH
    Ducati 250 Mk3 narrow case. 28W 6v headlight. Genny capable of feeding 28W
    over about 60mph in top...just. Scary.
    Hog, Oct 28, 2003
  12. JH
    JH Guest
    Doesn't quite fit in with the Burton suited brigade at work...
    JH
    JH, Oct 28, 2003
  13. JH
    JH Guest
    Tis true, but they were surprisingly good last night, and better than the
    piss awful RXS lights i had last time. Traffic was a bit "entertaining" on
    the A23 tho...
    Must figure why the clutch is sooooo reluctant to disengage when it's cold,
    the crashing noises are making me whince, no matter how slowly i make the
    change.
    Oh yes and it's rattled out a bolt on the way home, i feel quite proud, a
    proper MZ.
    JH
    JH, Oct 28, 2003
  14. JH
    They all do that sir, but maybe not that badly.
    If it's just on startup try kicking it over a couple of times, ignition
    off clutch in.
    It's worth noting I never changed the gearbox oil just checked it had
    some. I'm pretty sure (read: certain) TOG didn't. Try changing it for
    some EP80.
    Which bolt? Vibration loosening isn't a *big* problem on MZs.
    sweller, Oct 28, 2003
  15. Having had experience of the TS250/1 lights, I agree they can be good
    (for a 6v system), but a 12v conversion was always at the back of my
    mind during ownership.
    I'd refill the gearbox with known proper oil (EP80, afair), Sweller will
    put you right on that. It's possible someone may have used 90 or 140 in
    it.
    Bolt shedding wasn't really a problem with them.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Oct 28, 2003
  16. Sir has a crystal ball, sir has.
    The Older Gentleman, Oct 28, 2003
  17. They've just got shite gearchanges. They *can* be tamed, with practice.
  18. JH
    JH was seen penning the following ode to ... whatever:
    You say that as if it was a bad thing.
    Timo Geusch, Oct 28, 2003
  19. JH
    JH Guest
    Heh. Today's engineering introduction to sales drones is a lovely whiff of
    diesel, got some on my boots from somewhere and being a generous sole (sic)
    i decided to see if i can smog out the entire open plan office. (1200bods
    might be a stretch tho...)
    JH
    JH, Oct 29, 2003
  20. JH
    JH Guest
    It was a very cold morning so that was unlikely to help. Not really
    concerned, more a character trait.
    Yup tried that, it's more linked to gearbox temp i reckons.
    I found a cracking website for all things MZ (in Germany nach) and they
    state on there a straight 80w. I did top it up (there's a weep underneath
    somewhere) with some 75W80 syntrax as a stop gap which made it no worse or
    better. Will change it out this weekend, can get the little stopper all the
    way back in tho! :)
    It looked like it had been recently changed to a stainless jobbie, the 2
    bolts holding the rear mudguard to the cast alloy section on either side. It
    was my fault i noticed they were very lose when i was leaving work. I
    tightened them up as best i could, but one had made a bid (buy it now?) for
    freedom on the A27.
    Now, about that ETZ300...
    JH
    JH, Oct 29, 2003
Similar Threads
Loading...
