After having checked and adjusted the ignition timing of your ShiteOldHonda, you will find it runs much better if you tighten all the screws securing the points plate. That way you might not spend 13 quid on a new set of plugs which doesn't cure the misfire that's just appeared. Oh well, the CB550 needed new plugs anyway.
