I have just had my noo bloo GS out for a pre fettling evaluation run and to use up all the petrol I put in, like you do. It is a completely different machine from the other one. Hard to believe really that they were manufactured only a few months apart. A little slower accelerating but, if the speedo is to be believed, (probably) a much higher top speed. It seems strangled so I am now more than convinced it is partly restricted still. What did surprise me though was that the valves didn't start bouncing until way up into the infra end of the red line, which is only going to encourage me further. The cables were all as stiff as me dick but a little oil has got the clutch and choke a bit better though the throttle still closes far too slowly. Other than the newly experienced really rather pleasant still air provided by the TCP Ellipse fairing the straight line ride is about the same, although there is a little more foam in the seat on the noo bloo one and having the swing arm free to move for most of it's travel certainly helps the comfort side of things on Essex B roads. I am sure I managed to get the front to go distinctly slightly almost nearly perceptibly light in first gear, so no change there then. Apart from a touch of sponginess, the front brakes are spot on, genuine two finger stuff. Which has brought about an immediate halving of my braking distances with all the added bonuses for the inevitable adrenaline rush which follows. The pads are EBC HH "New C Formula" apparently and the callipers not being in the latter stages of seizing up means the brakes come off as quick as they go on, which is good. Shod with BT45s (the red one is on Avon's) the front end generally is much better especially after I reduced the front tyre pressure from the nearly 50 it came with to the 31lbs/in it should be (I took 10 out of the back as well) and I have a new scar on the outside of the sole of my right boot to prove it from when I inadvertently left it hanging out in the wind whilst taking the tight line round a slowish roundabout. It flicks nice too. So the list sort of comes down to: Whatever general routine type maintenance plus: carbs off and sorted, a set of new fasteners for the fairing and a new windscreen. Added extras will include sacrificial mushrooms and paddock stand shit bobbin stuff because it has no centre stand, which I assume is to do with fitting the fairing and some decals to hide the scuffs. That's about it really.
