My thick post of the week...
Discussion in 'UK Motorcycles' started by dwb, Apr 27, 2005.
  1. dwb
    SteveH says...
    Add the weight of 3 boxes YTC. Also, have you seen the position of top
    box and panniers on a ZZR1100C2. The top box is about as high as my
    shoulders and the panniers sit a long way back and make the bike about
    as wide as a Mini.
    3 large boxes stuck out in the breeze again, none of which are
    particularly aerodynamic in design. With the just rack and pannier
    rails on I noticed no difference to the way the bike handled.
    I still ride quicker and safer, even on a bike that handles like shit
    and is down maybe 70Bhp on yours. So who has the mind problem?
    Lozzo, Apr 27, 2005
  2. dwb
    Bear emerged from their own little world to say
    wessie, Apr 27, 2005
  3. dwb
    SteveH Guest
    This seems to be moving the goalposts a tad. You don't have to leave the
    boxes on unless they're needed. Of course 3 ****-off big boxes will have
    _some_ sort of effect, but if it's an issue, take them off.
    Quicker, I'll give you that.
    Safer is open to debate.
    SteveH, Apr 27, 2005
  4. dwb
    Pah, I'll see your paltry 124 litres & raise you 220 litres!
    Krusty, Apr 27, 2005
  5. dwb
    SteveH says...
    No you thick thick ****. YOU moved the fucking goalposts so don't try
    turning it around on me, you fucking retard. I said that "The Nonfango
    hard luggage I had on the second ZZR11 really fucked the handling up,
    even when empty." Where did I say I that just the rack alone fucked up
    handling?
    So I go out to pick stuff up on the bike, do I send the empty panniers
    on beforehand by Securicor, or do I put them on the bike and take them
    with me?
    Answer that one Einstein.
    Lozzo, Apr 27, 2005
  6. dwb
    It does depend on the bike though. My brother's CBR600 wasn't happy
    with a top-box, but my Tig doesn't seem to suffer apart from a weave
    from about 110mph, even crossing the extremely windy dyke across the
    north of Holland.
    The increase in surface area presented to cross-winds is fairly minimal
    on a big trailie given their size, and the naturally more stable
    steering geometry tends to keep things calm. I doubt Dan will have too
    many problems with hard luggage on his DL.
  7. dwb
    SteveH Guest
    Maybe I cover too many miles with a pillion.... even riding the VFR solo
    with a full set of empty luggage makes it feel completely different.
  8. dwb
    Different, yes - especially in cross-winds & when passing lorries on
    the motorway. But not different enough to be a problem, & certainly not
    dangerous - at least not on the Tiger.
    I would expect it to be more noticeable on a VFR as they have less
    surface area to start with, & are fairly aerodynamic compared to the
    small bungalow profile of a big trailie.
  9. dwb
    Krusty emerged from their own little world to say
    I've just looked at some pics of the Vstrom. The twin exhausts seem to be
    positioned very high up. Not very good for a bike sold with touring
    pretensions. I'm not surprised he's struggling to fit the soft luggage. Any
    hard panniers will probably need heat shields like the left hand one does
    on an R-GS.
    I agree with your generalisation about the top box and big trailies. I only
    really notice the weight of the top box at very low speeds as it makes the
    bike feel an ickle bit more top heavy
  10. dwb
    Ballast is the answer. If you're running with the panniers empty, fill them
    up with water to give you a nice, steady roadholding weight. Then, when you
    want to put stuff into them, you simply dump the water. Sorted.
    platypus, Apr 27, 2005
  11. dwb
    Mine's the old twin-can Tiger, & they're high up too. It does make
    throw-overs hard to fit, which is why I sling mine over the tank
    instead when I use them. This has the added advantage of keeping the
    weight further forward, & keeping the weather off your legs.
    Add the rear panniers, top-box & tank bag, & there's enough space to
    keep the SO happy for 2 weeks of touring.
  12. dwb
    Savour it - I only have one a year :)
  13. dwb
    Wind speed increases with altitude. The weight will compress the
    suspension, thus lowering the bike's profile and getting it down into calmer
    air. It'll also tend to damp out any aerodynamic flutter.
  14. dwb
    SteveH Guest
    The whole argument seems to be centered around 'hard luggage fucks up
    the handling'.... this may be true with all the luggage fitted, but, if
    you have the cases themselves fitted I'd sort of assume there was a
    reason for it. If you don't need the luggage you remove it and the bike
    will feel more or less the same as a bike without a Wingrack.
    It's a trade-off..... I'd assume that on a Sunday afternoon hoon you're
    not going to take a full set of empty luggage. IMHO, the advantages of
    having a Wingrack outweigh the disadvantages to a significant extent.
    A Wingrack itself makes sod-all difference to the handling of a bike.
  15. dwb
    It would be seen as a come-on.
  16. dwb
    Onlookers would think it was Michael Howard.
  17. dwb
    But if you do that, you'll miss out on my witty & amusing repartee.
    Oh...
    <killfiles self for 364 days>
  18. dwb
    Are you mad? That would completely screw up the aerodynamics.
  19. dwb
    Fair enough. When they hang Blair, you can nail Howard to the gibbet.
    platypus, Apr 28, 2005
  20. dwb
    gomez Guest
    Funny that. On my next bike I am not going to bother with the
    wing-rack, as I hardly ever have a need to put the panniers on.
    gomez, Apr 28, 2005
