My thick post of the week...
Discussion in 'UK Motorcycles' started by dwb, Apr 27, 2005.
  1. dwb
    dwb Guest
    Fitting a Givi top box mounting plate - easy or not? Does it require any
    sort of drilling?
    Discovered *none* of my Oxford soft luggag will fit on the V-Strom -
    considering it's got a great big rack at the back and a huge seat to say
    this was surprising would be an understatement.
    Some of the language uttered as the bungee went ping (yet again), taking
    chunks out of my finger (yet again) as it went is probably also best
    understated.
    dwb, Apr 27, 2005
  2. dwb
    SteveH Guest
    If you're fitting a Givi top box, then you may as well go the whole way
    and stick a Wingrack on there - you _will_ run out of top-box space at
    some point and wish you could fit panniers.
    Took me about 1/2 hour to fit the full kit to the VFR.
    SteveH, Apr 27, 2005
  3. dwb
    SteveH Guest
    124 litres total capacity here.
  4. dwb
    SteveH Guest
  5. dwb
    dwb Guest
    The V-Strom has a factory fitted rack on the back - the Givi mount goes on
    top of that rack.
    If I wanted to add panniers, they sell a seperate mounting frame for these.
    They don't make a wing rack for it, and even if they did it would look very
    very silly :)
    BTW, If I wanted 124l of space, I'd take the car!
    dwb, Apr 27, 2005
  6. dwb
    SteveH Guest
    Ahhh, yeah, your SO doesn't do bikes, does she?
  7. Fit panniers instead.
    The Older Gentleman, Apr 27, 2005
  8. dwb
    Bear says...
    Agreed. The Nonfango hard luggage I had on the second ZZR11 really
    fucked the handling up, even when empty. That's why I sold it and stuck
    with Oxford Sports luggage.
    Lozzo, Apr 27, 2005
  9. dwb
    SteveH Guest
    How did it manage to **** up the handling when empty? - a Wingrack isn't
    exactly heavy, and I can't see it contributing to aerodynamic drag to a
    significant extent.
    The TRX, 2-up, with throwovers and a large top-box at an indicated
    140mph was 'interesting' to say the least.
  10. dwb
    dwb Guest
    Hard ones I presume you mean?
    Cause the soft ones don't seem to bloody well fit either!
    I'm sure i'm doing something thick and missing the obvious but I really
    reached the end of my tether (pardon the pun) with it this evening.
    I may revisit it tomorrow - or consider getting some more appropriate length
    bungees.
    dwb, Apr 27, 2005
  11. dwb
    SteveH says...
    Maybe because I ride in a more enthusiastic manner than yourself, and
    having all that weight and massive flat panelwork sitting behind the
    rear wheel spindle did **** all for the handling except **** it up. It
    was positively lethal in sidewinds, which is pretty much all you get on
    my old regular trip to Glasgow and back.
    Lozzo, Apr 27, 2005
  12. dwb
    Bear emerged from their own little world to say
    I sold my VFR750 in 1996. I removed the Wingrack to ride it 45 miles to
    swap bikes. It felt like a totally different bike riding through the Forest
    of Dean to Bristol. I think I should have done it much earlier as I may
    have kept the bike longer.
    Since then I've never bothered with hard panniers.
    wessie, Apr 27, 2005
  13. dwb
    SteveH Guest
    Mathematically it doesn't make sense..... however, if you're riding with
    empty panniers I can see how that might bugger things up.
  14. dwb
    SteveH says...
    So you have never heard of 'Centre of Gravity' then? I failed maths O
    level, but even I can understand why loading up a bike with extra
    weight that high and that far back is not a good thing. Then there's
    the matter of the screwed up aerodynamics. I think you'll find this is
    a simple physics matter, not exactly maths.
    Lozzo, Apr 27, 2005
  15. dwb
    dwb emerged from their own little world to say
    On the GS you lose the grabrail as the mounting plate bolts on in its
    place
    Simple 2 bolt job
    On the Vstrom you have grab handles on either side so it has to be
    different. Whatever system they use you will still only have 2 bolts
    holding the top plate on. There may be a small plate to fit under the
    existing rack or you may be supplied with some longer bolts to go into
    the standard threads.
    Whatever the system it will be simple. I've fitted a full pannier system
    to 2 bikes and a Monorack to 2 bikes. On each occasion the process was
    straightforward.
  16. dwb
    SteveH Guest
    But a Wingrack is made out of a relatively lightweight alloy - a 12 pack
    of beer would weigh more. It's hardly mounted 'high up', given that it
    more or less follows the contours of the bodywork.
    Aerodynamics shouldn't be an issue as a rack doesn't stick out that much
    and presents a very small frontal area to the air - a change of jacket
    would have more of an effect on aerodynamics.
    In conclusion, it's all in the mind.
  17. Yes. Seriously, top boxes, especially these giant ones they seem to
    peddle today, put the weight too high up, to far back, and too far
    behind the rear wheel spindle.
    Panniers are pricier, but if you'd ever experienced a full-blown
    three-figure speed wobble that was down to a bloody topbox, you'd think
    the same.
    I know I've got a topbox on the 400 Four, but it's a very small one.
  18. Nah.
    The amount of force generated by a throwover pannier, in these
    circumstances, is very small.
  19. A rack on its own will make very little difference. It's the load, or
    structure, added to it that will.
  20. dwb
    SteveH Guest
    *ding*
    And that's my point.
    OK, so a Wingrack isn't exactly pleasing on the eye, but I wouldn't have
    a bike without one now.
