My questions for Kawasaki
Discussion in 'UK Motorcycles' started by AndrewR, Feb 23, 2004.
  1. AndrewR
    AndrewR Guest
    Dear Mr Kawasaki heavy industries & motorbikes,
    I have three questions for you, I hope you will find the time to answer
    them.
    They all relate to your wonderful ZX-6R J1 motorcycle.
    1. Why did you chose to fit 6 pot brakes instead of the more normal 4 pots?
    I have never seen anything to suggest that braking performance is improved
    by having 6 pots rather than 4, it just means that when the pistons seize up
    it takes 50% more time to clean them. I know this because ...
    2. ... For the love of god, could you not have made your brakes from
    something that doesn't seize tighter than a nun's fanny if you dare to ride
    your bike in anything that could even be remotely called winter? Why did
    you want me to spend long hours on cold days on my knees in front of the
    bike armed with a toothbrush and can of brake cleaner? What made you
    believe that, while I was busy hack-sawing out pad retaining pins, I'd idly
    think, "**** me, these Kwaks are great bikes. I should buy another one."?
    3. As for the pad retainers... they're held in place with a retaining pin.
    It's a lovely little retaining pin. It does its job very well. It's easy
    to remove, easy to replace, it generally scrubs up OK, even after winter
    abuse. WHY THE **** DIDN'T YOU PUT TWO OF THEM IN? Sorry, about that, it's
    my nerves you know. It's just that, if you had put two of them in then,
    rather than having to blank off one end of the run for the pad retainer, you
    could have just had a hole all of the way through. Which would mean that
    WHEN THE FUCKING, BASTARD, CUNTING PAD RETAINER SEIZED SOLID YOU COULD
    HAMMER IT OUT, CLEAN IT UP AND PUT IT BACK IN RATHER THAN HAVING TO HACKSAW
    THE FUCKER OUT AND THEN PAY FOR A NEW ONE!
    4. Sorry, I know I said I only had three questions, but 2 more just sprang
    to mind. Firstly, do you know if brake cleaner fumes can cause violent mood
    swings?
    5. Secondly, would it be possible for me to meet the engineer who designed
    the brakes for me bike? If possible I'd like to meet him somewhere dark,
    with no witnesses, but plenty of heavy objects; house bricks, lead piping,
    socks full of pool balls, etc.
    6. Um, any chance of some free Kwak merchandise?
    Yours with a twitch,
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, Keeper of the TFSTR#
    The speccy Geordie twat.
  2. AndrewR
    [snip brake 'issues']
    <fx: FWD:>
    CT, Feb 23, 2004
  3. AndrewR
    Ben Guest
    cc it to Suzuki as well.
    Ben, Feb 23, 2004
  4. AndrewR
    flashgorman Guest
    <big snip>
    I picking up a hint that you have had some problems with your motorcycle.
    Which bit was it? Electrics? Wheels?
    flashgorman, Feb 23, 2004
  5. AndrewR
    Fashion. For a while it looked like brakes would go the same way as
    razors, and we'd eventually have 10 pot calipers covering half the
    wheel. But, in fact, everything's gone back to four now.
    You should wash your bike occassionally. Even throwing a bucket of
    cold water over the brakes a couple of times a week during winter
    would make quite a difference.
    If you'd have to drift it out, you would need a new one. The pads
    float on the pin, so for optimum performance they need to be in quite
    good nick anyway.
    But anyway, if you didin't ride like such a poof, you'd wear the pads
    out much more often. The resulting frequent replacement activity
    would give you plenty of opportunity to clean and re-grease the
    calipers, and so avoid these problems.
    So, it's your fault.
    Champ, Feb 23, 2004
  6. AndrewR
    Chris H Guest
    Yes it would make quite a difference. Unless you washed all the salt off
    it might make things worse, because the seizing is caused by galvanic
    corrosion for which water is required. It's a bit like throwing petrol
    on to a bonfire, only not as much fun.
    The best solution is to grease the bits that corrode (not the discs
    stupid). Whenever I get a new bike now it's the first thing that I get
    done.
    Chris H, Feb 23, 2004
  7. AndrewR
    I know, I know. Tell me about Italians and winter.
    I did the Guzzi brakes this weekend, replaced all the pads, the front
    /discs/[1], greased the pins and checked all the pistons were good and
    free. Took me an hour, maybe an hour and a half.
    ermmm, that's not quite the same is it.
    [1] 95,000 miles and well under service limits (6mm) at 4.5mm
    sweller, Feb 23, 2004
  8. AndrewR
    AndrewR Guest
    It's a while since you last fished, isn't it Bonnas?
    Kawasaki ZX-6R J1
  9. AndrewR
    dwb Guest
    Really? on the 1000?
    I've _so far_ not had the brakes sieze up on either the SV or the GSX-R6...
    And that's not washing it much at all.
    dwb, Feb 23, 2004
  10. AndrewR
    Ben Guest
    Not on the Thou, but I head pretty nearly the same experience on the
    750. Except without the seized pad retaining pins.
    The Thou won't be seeing salt enough to cause a problem.
    It got washed every weekend, but it got used everyday no matter what
    the weather.
    Ben, Feb 23, 2004
  11. AndrewR
    MrMoosehead Guest
    <SNIP BRAKE PROBS>
    I'll not mention how nice and easy MrHonda's were then...
    MrMoosehead, Feb 23, 2004
  12. AndrewR
    Ginge Guest
    I've got them too, they seem OK but aren't as good as the 4 pots on the
    R6 / R1 used to be.
    Ginge, Feb 23, 2004
  13. Champ wrote
    <sigh>
    I miss Bear.
    steve auvache, Feb 23, 2004
  14. AndrewR
    Chris H Guest
    *Shrug*. Who knows. It'd still be better if the pins and pistons were
    greased to exclude the water and salt. Equally, it wouldn't be beyond
    the wit of Tokico man to isolate aluminium bodies and steel pins/pistons
    from each other to avoid galvanic corrosion.
    Ah, the good old days when they used proper salt. The ammonium chloride
    they typically use now is far better at corroding stuff.
  15. AndrewR
    Ginge Guest
    It could be.
    Suzuki really need to get a move on with their gixxer thou based
    streetfighter. Hopefully they'll put a bit of a screen on it, and I'll
    go out and buy one.
    Ginge, Feb 23, 2004
  16. Chris H wrote
    You could help though. Try not doing so much east/west riding for a
    start.
  17. AndrewR
    Chris H Guest
    I haven't been to the West Riding for ages.
  18. AndrewR
    Chris H Guest
    <pedantic mode on>
    An alloy of what?
    <pedantic mode off>
    ITYF that the sliding pins are steel.
  19. AndrewR
    Heh. All of his excuses would be gone.
    OTOH he might actually improve, given how easy they are to ride. G'wan
    Rob, you know you want to.
    Ace, Feb 24, 2004
  20. AndrewR
    Ben Guest
    I think mechanically they're the same as the Thou ones as well, except
    the Thou's are painted gold.
    Ben, Feb 24, 2004
