My first bit of SV fettling.
Discussion in 'UK Motorcycles' started by Krusty, Jun 14, 2010.
  1. Krusty
    Ben Guest
    Ha, exactly the same problem I had on the rear brake of my GSXR600
    track bike. Ended up buying a new caliper as the bolts to split the
    old one were seized as well.
    Ben, Jun 15, 2010
  2. Krusty
    SIRPip Guest
    It was you, man - but it's a Corvette, innit. Hey ho, I always get it
    wrong.
    SIRPip, Jun 15, 2010
  3. Krusty
    D'oh! Wasn't axle bolts either, it was a crossmember bolt. The remains
    are still there in the hole, along with half an eazi-out & part of a
    drillbit. I may add part of a lefthand drillbit to the party at some
    point.
    Krusty, Jun 15, 2010
  4. Krusty
    Exactly the same caliper as the SV650 K1 has, and the RF900, and the
    Bandit 600s and 1200s, and just about every Suzuki with a rear disc
    from that era.
    Lozzo, Jun 15, 2010
  5. Krusty
    Maybe I've been lucky.
    Pip Luscher, Jun 15, 2010
  6. Krusty
    I've never failed to press out the pin on those.. Bit of penetrating oil.
    Heat. Bob's your Auntie. Drilling blank end holes was never an issue either.
    Caliper off first of course but if you have a couple of widgets to stop the
    fluid leaking so loss is minimal and the workshop time reduced.
    Hog, Jun 15, 2010
  7. Krusty
    the rear Brembo corroded on my R-GS after 3 years. BMW part funded a
    replacement despite being well outside the warranty period
    wessie, Jun 16, 2010
  8. Krusty
    <pedant mode>
    There is no excuse for corroded in brake pins
    Hog, Jun 17, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beav
    No, you're going to have to explain that in more detail please.
    You have a pin stuck in a blind hole in a casting. You have unlimited
    access to the other side of the casting, and a pair of compasses.
    Please explain how you find the centre of the pin. (Forgive me, I'm
    obviously being thick here).
    Wicked Uncle Nigel, Jun 17, 2010
  10. Krusty
    SIRPip Guest
    Is there a small dog?
    SIRPip, Jun 18, 2010
  11. Krusty
    Steve Guest
    It's obvious innit?
    Find true north with one compass and align the other with the ley
    line running through Glastonbury.Mark where they intersect and drill.
    Steve, Jun 18, 2010
  12. Krusty
    Beav Guest
    So you take one point of the compass and place it on the head of the pin on
    the accessible side of the caliper and place the other point of the compass
    on a point at the edge of the caliper. You've now flip the caliper over and
    place one point of the compass on the corresponding edge of the caliper and
    scribe an arc with the other end of the compass. Do this twice using two
    different starting points on the "accessible" side and you will then, after
    transferring the compass to the "back side" again, have two arcs which
    intersect. The intersect point is the other end of the pin. Drill and insert
    drift.
    Of just about anyone on here, I'd have thought that you would know about
    transferring measurements from one side of an item to the other, being a
    machiney type of bloke, so you're forgiven.
    Beav, Jun 18, 2010
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beav
    How do you accurately locate this corresponding edge?
    Wicked Uncle Nigel, Jun 18, 2010
  14. No, you can get pistons and seals as a set, just not seals on their own.
    stephen.packer, Jun 19, 2010
  15. Oh, right. Didn't know that. Not as bad as I thought: I was under the
    impression that the calipers were utterly non-serviceable.
    The Older Gentleman, Jun 19, 2010
  16. Krusty
    Kind of makes sense. Handy to know, too. Thanks.
    Pip Luscher, Jun 21, 2010
