My Bike Needs Me...
Discussion in 'Bay Area Bikers' started by Larry xlax Lovisone, Jan 26, 2005.
  1. My bike needs me plan and simple... who else will spend the time and money
    machining new magnesium triple clamps for it??? not the aftermarket companies...
    there's not enough RC45s world wide for them to bother with... so it's up to my
    Lathe and Mill to keep my bike happy...
    It all started with 43mm Ohlins forks found on Ebay that were for an R1
    Yamaha...
    http://www.fox302.com/userdata/netters2/files/ShopPics/Ohlins43mmRoadTrackForks.JPG
    Although the Ohlins slipped right into the stock triple trees... it would have
    upset the trail...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45StockClampsOhlins.JPG
    You see the stock RC45 fork leg features a 5mm offset whereas the Ohlins has
    zero offset... so the Ohlins net effect would add 5mm of trail... extra trail
    adds to a bikes stability but also adds to the tendency of going wide at the
    exit... not to mention heavier steering...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45FrontAxleOffset.JPG
    To make the new forks work I designed new triple clamps with an extra 5mm of
    offset to counter the 5mm missing in the straight leg Ohlins... I started with
    an 43 pound block of Dow Magnesium...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagClampsStart.JPG
    After 2 weeks the clamps steadily took shape... a lot of time spent on the
    rotary table on the milling machine...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagClampsProgress.JPG
    My unique design was model after an aircraft wing spar... the blue outline
    represents solid magnesium part whereas the silver represents the relieved
    parts... all sharp corners were radius...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagClampLayout.JPG
    I sent the Magnesium clamps off to TechPlate in L.A. for Mil-M-45202C protective
    coating called Dow #17... they came out nice and tan... no???
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagnesiumClampsOhlinsB.JPG
    I order titanium bolts from Yoyodyne and even made my own steering stem out of
    Fortal Aluminum which meets and exceeds 7075 T6...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagnesiumClampsOhlinsF.JPG
    I machined a pattern in the top clamp so I have something nice to behold as I
    actuate the key...
    http://www.fox302.com/userdata/netters2/files/ShopPics/RC45MagnesiumClampsOhlinsT.JPG
    Stock Clamps weight 4 lbs 7 oz... and my magnesium clamps turned out weighting
    exactly the same at 4 lbs 7 oz... so I didn't save any weight but I will save
    over all because the 43mm Ohlins are 1 lb 3 oz lighter than stock 41mm Showas...
    Does your bike need you???
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    http://www.fox302.com/index.pl?s=vg&user=netters2
  2. Larry xlax Lovisone
    N0EQL Guest
    All for the low, low price of????
    N0EQL, Jan 26, 2005
  3. Larry xlax Lovisone
    Shadowfax Guest
    Beautiful work, Larry.
    Shadowfax, Jan 26, 2005
  4. Larry xlax Lovisone
    Alex Charles Guest
    <snip>
    First let me say, nice work. I don't believe I would have had the patience
    to get that done on manual mill and rotary, I can appreciate the work
    involved in doing that way. Myself I would have taken it to work over the
    weekend an done them in my CNC, but I understand that is not always an
    option for most folks.
    My question though is why magnesium? We avoid that material because of the
    hazards involved in machining.(to which I'm sure you are well aware). My
    choice would have been aluminum for weight or maybe a Stainless for strength
    and corrosion resistance.
    Alex
    Alex Charles, Jan 26, 2005
  5. "Larry xlax Lovisone"
    SNIP
    <Ted>
    EXCELLENT!
    </Ted>
    <Bill>
    Indeed, most excellent...dude! That like ROCKS!
    </Bill>
    Indeed it does...no shop space and I wa^H^H^H^H^H NEED more
    power tools. I've the ideas...but it would be cheap do it
    like you do than pay.
    Nefarious Necrologist 42nd Degree
    Some people ride, some just like to show off their butt
    jewelry once in a while.
    Dum vivimus, vivamus
    <:(3 )3~ <:(3 )3~ <:(3 )~ <:(3 )~
    Keith Schiffner, Jan 26, 2005
  6. Impressive machining work, Larry. Got a question, though.
    Couldn't you have just made new (whatever you call the end
    of the forks where the axle bolts up) with the same offset as
    your original? Or, since the Ohlins have a larger hole for the
    axle, couldn't you just have made an offset bushing?
    "Brutal and sadistic? By what girly-man standards? Compared
    to how Saddam treated his prisoners, a bit of humiliation was
    a walk in the park. AFAIK, No one died or even lost any blood."
    -Albert Nurick, a usenet kook and blatant liar, on the rape,
    torture and murder at bu$h's Abu Ghraib prison in Iraq.
    http://www.commondreams.org/headlines04/0512-10.htm
    "I don't know where bin Laden is. I have no idea and I really
    don't care. It's not that important. It's not our priority."
    -- George W. Bush, March 13, 2002
    http://www.truthout.org/
    http://counterpunch.org/
    http://responsiblewealth.org/
    Don't let bu$h do to the United States what his very close
    friend and top campaign contributor, Ken Lay, did to Enron...
    Henry H. Hansteen, Jan 26, 2005
  7. Larry xlax Lovisone
    XS11E Guest
    Apparently not, it's been sitting for a very long time....
    XS11E, Jan 26, 2005
  8. Larry xlax Lovisone
    Paul Calman Guest
    Very nice. Maybe i should build a lightweight goldwing. I like the coating.
    I was told to take a set of NOS vintage magnsium Lotus racing wheels and
    machine the rims to a high polish. I tried to explain how quickly they would
    turn gray, but wound up doing it, and then had guy bury them in preservative
    until just before starting time. What a pain! Now he says he should have
    left them alone.
    Mag is fine for fast heavy cuts, but didn't like fine cuts, i had two chip
    fires, but as i kept it clean they were not a problem.
    Paul Calman, Jan 26, 2005
  9. Magnesium block was $120.00...
    Dow #17 was $240.00...
    Fortal stem was $ 40.00...
    Sweat equity 0.00...
    but if I were commissioned to engineer and machine a set that
    would push up labor to $800.00... not cheap eh???
    Larry L
    94 RC45 #2
  10. Larry xlax Lovisone
    Rob Gill Guest
    No, my bike needs you Larry.
    Rob Gill, Jan 26, 2005
  11. Thanks Alex...
    Granted... as you know doing it by hand and eye is tedious at best... one wrong
    move and it's junk... if I had to make another one I'd head straight for the
    nearest CNC shop...
    For the low weight and high strength the extra material affords... as you might
    know magnesium is a dead metal... it doesn't ring like aluminum... that quality
    should produce a superior feel at the hand bars on a my World Superbike frame
    that's stiff as a slab of marble...
    Yes... magnesium is the metal that burns... you can;t let the chips pile up...
    once ignited magnesium burns hot enough to ignite water flaring up like gas on a
    flame...
    This is my pumpkin on magnesium...
    http://www.fox302.com/userdata/netters2/files/ShopPics/MyPumpkinOnMagnesium.JPG
    This is my pumpkin after water was poured on the magnesium fire... any
    questions???
    http://www.fox302.com/userdata/netters2/files/ShopPics/AddWaterToMagnesium.JPG
    Larry L
    94 RC45 #2
  12. Larry xlax Lovisone
    Andrew Guest
    The Orange one does, it is like my baby. Baby Frakenstein.
    Andrew, Jan 26, 2005
  13. Larry xlax Lovisone
    Bill Smith Guest
    I'm a machinist by trade and, I like to tell myself my bike needs me.
    I haven't yet found enough of an excuse to make triple clamps,
    though. Maybe that RC-51 front end I want will do it.
    While I can't fault your workmanship and effort, I have a small
    quibble with your design. Customarily one would leave metal on the
    perimeter and carve out the innards from the underside to remove
    weight. This, of course, is much easier said than done on a manual
    machine. I think if you had done as I suggest, you might have saved
    some weight and had a stiffer part.
    There's always some jerk, right? :)
    Bill Smith
    Bill Smith, Jan 27, 2005
  14. Larry xlax Lovisone
    Dan Carter Guest
    Dude, I would be so paranoid that those forks still have Yamaha cooties
    on them.
    Dan Carter, Jan 27, 2005
  15. Larry xlax Lovisone
    Mas Rapido! Guest
    Yeah, I was thinking all three of my bikes could use a little Ex_Lax...
    Especially the VTR who asked me for a new set of forks last weekend up on
    Skagg's Springs Road.
    It also was whining about getting a real swingarm some day as well.
    Jim Stinnett
    VTR1000
    R1100RS
    YZF R1
    http://moto-rama.com
    Mas Rapido!, Jan 27, 2005
  16. Larry xlax Lovisone
    Richard Guest
    Bravo Larry!
    I couldn't supress an involuntary guffaw, when I read:
    " I started with an 43 pound block of Dow Magnesium..."
    Richard, Jan 27, 2005
  17. Hiya Dan... well the Ohlins have never seen an R1 left alone touched one and
    I'll make sure they only see 1s in passing... hey meet you at Bubba Gumps during
    MotoGp???
    Larry L
    94 RC45 #2
    Larry xlax Lovisone, Jan 27, 2005
  18. Larry xlax Lovisone
    Stephen! Guest
    Fire fighting teams at sea have two methods for extinguishing magnesium
    fires (used extensively in aircraft landing gear)...
    1. Sand.... LOTS of sand...
    2. Jettison...
    Guess which gets used most often.
    Stephen!, Jan 27, 2005
  19. Or rubbishing, or at least two other parties.
    Lady Chatterly
    "I don't know who she is. I doubt that its a bot. I have my guess as
    to who it is. Regard the frequency of posts. What frequent poster is
    missing? That Be Packi, is an old mind trick. Ignore it." -- Pip
    Lady Chatterly, Jan 27, 2005
  20. Larry xlax Lovisone
    notbob Guest
    2 ....because there is no "extinguishing" magnesium.
    nb
    notbob, Jan 27, 2005
