My baby works!
Discussion in 'UK Motorcycles' started by BGN, Apr 18, 2005.
  1. BGN
    Eddie Guest
    You should be able to get pattern blinkers for a CB500 fairly easily,
    I'd have thought - probably under 20 quid, at a guess.
    Or get something that isn't pattern or OE - should be able to get
    something suitable for under a tenner.
    Eddie, Apr 18, 2005
  2. BGN
    No, you must have all four working on your machine.
    If you like I can point you in the direction to get replacements cheaply
    and maybe see if we can get some S/H clocks.
    I'll come over and fit them if you like. Can't do it for a few days as
    I'm a bit crock ATM.
    sweller, Apr 18, 2005
  3. BGN
    JackH Guest
    <nods>
    Be happy to help.
    Nick, when you get the estimate off of Cheriton Motorcycles, say ta very
    much and walk away, muttering something along the lines of you need time to
    raise the money - but make sure you take the estimate with you, so you've
    then got a list of what the bits will cost new, if needs be.
    See, they'll be looking to charge at least £35 + vat an hour, in terms of
    labour, and I reckon, even though the damage to your bike is mostly bolt on
    stuff, they'll be looking to get at least 2 hours worth out of you - I might
    be wrong, but I'd be surprised if they'd do it for less.
    Anyway... your next task, is to buy a copy of Motorcycle News on Wednesday
    (as it'll be the most current issue then), and browse through the back at
    the breakers section - any that list ER-5s for breaking, give them a ring
    and see what bits they've got... if they've got most of the bits on your
    list, see if the prices are favourable compared to the estimate prices, and
    if so, order them.
    You might have to get the bits from more than one breaker to get the lot...
    anything that is made of unobtainium, you'll have to order off a local
    Kawasaki dealers.
    Anyway... once you've got all the bits there, give me a shout, and I'll come
    down and help you fit them all - nothing on that list is going to be that
    much hassle to fit, so it should be a good introduction for you to the
    wonderful world of bike repairs!
    JackH, Apr 18, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    Good man. The fuse *may* have blown for a reason[1], so have a sniff
    round for damaged wiring. Try wiggling the wiring (with the ignition on)
    to see if you can provoke a nice fat blue spark and a satisfying "Pop!".
    Better to know now than on the way to work one morning.
    [1] Alternatively, you may have frightened it to death...
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Apr 18, 2005
  5. BGN
    Eddie Guest
    Do the search on the web for free - avoid all those phone calls and,
    better still, avoid having to buy that rag.
    http://www.part-locator.co.uk/
    http://www.uk-biker.net/partsf.html
    Eddie, Apr 18, 2005
  6. BGN
    Hooligan Guest
    Think again, would be my advice.
    Have a look at the list up there: there's nothing more complicated
    than a bit of unbolting and bolting up again.
    Get yourself a Haynes and get on with it: you'll save quite a bit, I
    imagine, and will increase your position on the learning and confidence
    curve somewhat.
    As others have said: e-bay and breakers for the parts. If you *have*
    to buy new, get pattern parts.
    Sounds like good news for you :)
    John
    SV 650
    Black it is
    And Naked
    Hooligan, Apr 18, 2005
  7. BGN
    Using these web searches has never successfully turned up parts for me
    but I'm prepared to give them another go.
    That'll be one cylinder head and rocker box for a Dnepr MT9, thanks.
  8. BGN
    Eddie Guest
    There's probably a reason for that.
    There could be a clue in that sentence, I think.
    Eddie, Apr 18, 2005
  9. BGN
    BGN Guest
    I hadn't had any problems before throwing it at a muddy bend. I can't
    really think of why the IGNITION fuse would blow in a crash though. I
    don't recall hearing any ignition noises while I was doing my party
    trick across the road, but I wasn't really listening for them.
    But I'm not sure what KAP did to it when they recovered it. All I
    know is that it must have been in 4th or 5th gear when I parted
    company with it, but when it was delivered to my driveway it was in
    neutral, but the ignition doesn't need to be operated to go that.
    If I have any more problems with the ignition then I'll look at more
    carefully.
    BGN, Apr 18, 2005
  10. BGN
    BGN Guest
    With is always better.
    I picked up the rest of the clocks off of the side of the A20 - now
    all I need is a hacksaw and some gaffer tape.
    Gaffer tape is just Duck tape, innit?
    BGN, Apr 18, 2005
  11. BGN
    Dan White Guest
    That would only be so they could wheel it onto the recovery truck without
    having to lift it.
    Dan White, Apr 18, 2005
  12. BGN
    BGN Guest
    Fantastic! I need all the help I can get at the moment!
    BGN, Apr 18, 2005
  13. BGN
    BGN Guest
    Lozzo is keeping his eyes open for some clocks, but I still need
    everything else.
    Shopping list:
    Brake lever
    Handlebar (Possibly - will investigate - it might be that everything
    was just shunted which is why everything has moved a bit)
    Headlight rim
    Right signal
    That's okay, I'm in a bit of a state currently (having my dressings
    done tomorrow morning!) but I'm off of work all week and I'm very,
    very happy at any help that anyone is able to offer.
    BGN, Apr 18, 2005
  14. BGN
    I'll look out some pattern suppliers and pass them onto you and when
    you're ready we'll sort the bike out.
  15. BGN
    Gas only escapes at traffic lights, and is usually wafted into car
    windows. :)
    Explode arm... ewww.. nice.
    BGN cyborg. heh...
    Buba cover, my mum had that, and it helped a lot when she got the
    cancer.
    Things like that do make you a little extra carefull for atleast a
    while. Shame you didn't manage to throw the bike in a ditch, then you
    would have gotten a DS#[1]. ;)
    [1]This stands for ditch surfer.
    Muck, Apr 18, 2005
  16. It was somewhere around Barstow, on the edge of the desert, when the
    More than likely in the aftermath. When the bike was being lifted and
    dropped off, a wire in the headlight shell or the smashed clocks shorted
    to earth.
    Whatever, if it's not blown yet, it's probably ok now.
    Grimly Curmudgeon, Apr 18, 2005
  17. BGN
    JackH Guest
    No worries... page me through here, or email me (this address is unmunged),
    if / when you've got all the bits needed for it sorted, and we'll take it
    from there.
    JackH, Apr 18, 2005
  18. BGN
    Have a word with Mick at MPC:
    http://www.uralmotorbikes.info/
    platypus, Apr 18, 2005
  19. BGN
    I wonder if sweller might be eligible for one of these. Or at least a
    "Where's my bike?" number.
    platypus, Apr 19, 2005
  20. BGN
    Molly G is the person that is KotL.
    Muck, Apr 19, 2005
