MV poo.
Discussion in 'UK Motorcycles' started by Krusty, Aug 17, 2005.
  1. Krusty
    In what way is "locked solid" not a seizure?
    Champ, Aug 18, 2005
  2. Krusty
    I realise this marks me down as a mechanical idiot, but I'd always
    assumed a "seizure" involved two bits of metal becoming stuck together
    that shouldn't be stuck together, not just something caught against
    something else, IYSWIM[1]
    [1] though I doubt you will SWIM, as it doesn't make full sense to me.
    darsy, Aug 18, 2005
  3. Krusty
    Eiron Guest
    In the sense that nothing much was broken and IIRC, I just replaced a
    ring. No metal bits welded themselves together.
    And the fact that it stopped in rather less than a millisecond
    whereas an engine seizure takes a second or so.
    Not a lot of difference really.
    Eiron, Aug 18, 2005
  4. Krusty
    darsy says...
    It's when something isn't moving the way it should, for whatever
    reason. You can have partial seizures, which is when the piston will
    still move in the bore, but the heat damage and resultant once molten
    alloy picking up on the side of the piston and bore has made things a
    bit tight. The most common type is the heat seizure, where a piston has
    overheated through a lack of lubrication and expanded beyond the limits
    of the bore. This usually results in bore damage as the rings tend to
    take chunks out it when they break, which they inevitably do.
    Lozzo, Aug 18, 2005
  5. Krusty
    Steve Parry Guest
    http://photobucket.com/albums/v448/mvmonoposto/Swiss Tour 2005/?action=view&current=DSCF0128.jpg
    Is this Arona/Stresa area?
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Aug 18, 2005
  6. Krusty
    Krusty, Aug 18, 2005
  7. Krusty
    Steve Parry Guest
    Thought so, stopped there while on a tour with a KLR600 a few years ago
    Steve Parry
    K100RS SE & F650
  8. Krusty
    OK, thanks. Only ever having owned one 2-stroke, which (so far) hasn't
    seized, I'm not really up on this subject. Give it time, mind.
    darsy, Aug 18, 2005
  9. Krusty
    Steve Parry Guest
    Funnily enough I had a mate do exactly the same routine when his
    GPZ550D1 threw a rod.
    Apparently the conrod guy at the factory had his torque wrench on the
    wrong setting!
    Steve Parry
    K100RS SE & F650
  10. Krusty
    Steve Parry Guest
    PS at 2 or 300 miles or so ..
    Steve Parry
    K100RS SE & F650
  11. Krusty
    darsy says...
    Top tip: Always ride with your left hand hovering over the clutch
    lever.
    When a seizure on a highly tuned stroker occurs, the bike will suddenly
    go like stink, then start to feel sluggish almost immediately. That's
    the time to whip the clutch in, hit the kill switch and coast to the
    side of the road or track. Leave it to cool right down before doing
    anything, don't try to ride it away after a couple of minutes. 9 times
    out of 10 there's been a lubrication failure, or cooling problem. Look
    right over the cooling and lube sytem before blaming anything else, and
    then look at the pistons/barrels to see if you can get away with not
    fitting new pistons and reboring/replating.
    Lean jetting usually shows itself by melting a hole in the top of a
    piston, as does timing being out. When this happens you may still have
    to strip the engine as bits of molten alloy will have got into the big-
    ends and main bearings.
    Lozzo, Aug 18, 2005
  12. Krusty
    Steve Parry Guest
    <snip>
    That's a habit I still have from my RD days :D
    Steve Parry
    K100RS SE & F650
  13. Krusty
    Wik Guest
    Luvverly. We stayed over t'other side of the "hill" on Como at a
    similarly gorgeous place, Bellagio.
    Wik, Aug 18, 2005
  14. Krusty
    darsyx Guest
    2-strokes: blame the East Germans.
    darsyx, Aug 18, 2005
  15. Krusty
    Certainly my experience.
    sweller, Aug 21, 2005
  16. Krusty
    Think Morris Minor with a column change and Vauxhall Chevette plastic
    interior but smaller and noisier.
    Many phenomenal 'design' features. Fuel filler above a hot engine, no
    fuel gauge (dipstick), 20L jerry can in the boot when full impossible to
    get out and a special hand scarifying feature if you cock up a gear
    change when a tram is bearing down on you.
