Must resist.....
Discussion in 'Classic Motorbikes' started by WorkTOG, Aug 22, 2003.
  1. WorkTOG
    WorkTOG Guest
  2. WorkTOG
    Too far away, but looks pretty clean (as in together). Seized engines
    are an afternoons work and about £50 (inc mains) if the bore isn't too
    badly molished.
    If big end gone, that's another £50 ish.
    sweller, Aug 22, 2003
  3. advertised as a 150, mind. how'd you know it's a 250?
    looks pretty complete, rather depends why it's seized - if it seized in use
    at high revs from lack of oil, then it might be a bit dodgy.
    Austin Shackles, Aug 22, 2003
  4. WorkTOG
    This is a 125/150
    http://www.sweller.co.uk/sob/images/ts150/cutsde.jpg
    http://www.mztech.fsnet.co.uk/images/lh24.jpg
    This is a 250
    http://www.sweller.co.uk/sob/images/mz_ts.jpg
    http://www.mztech.fsnet.co.uk/images/lh23.jpg
    Note engine and sidepanels, later deluxe 125/150's also had twin clocks
    like the (deluxe) 250.
    MZ's seize because of ignition timing. Lack of oil causes bearing
    failure, which will eventually cause seizure but the engine rattles to a
    halt first, but will still turn over.
    If the top end's melted/seized/pitted it *will* be over advanced ignition
    or hot plug, if the bearings are fubar'd then it's lack of oil.
    My money's on ignition or left standing. If the piston isn't melted it
    will run again that day....
    Top tip, time your MZ (6v) at 2 to 2.25mm BTDC, *NOT* 3mm.
  5. WorkTOG
    Sean Guest
    It is a 250. The 125s and 150s were somewhat different to look at, plus they
    weren't fitted with that 250 engine :)
    Getting whole engines, indeed whole bikes to cannablise doesn't bump the
    cost up too much.
    You can rebuild MZs fairly cheaply, and if the bore is arsed, hog it out to
    300cc. Or fit a Suzuki piston a'la MZ racers as they are available in
    larger oversizes.
    Now I want another MZ. Anyone want to swap a GSX400ez for an ETZ 250 or 300?
    Sean, Aug 22, 2003
  6. Austin Shackles, Aug 22, 2003
  7. WorkTOG
    For the love of tiny Tim, I've sold running fuckers for less...
    "Hey, itsa a classic..."
  8. WorkTOG
    SteveH Guest
    Which reminds me.....
    Just spotted an ETZ250 selling for £236 in a local-ish dealer.
    Description is of a real minter - owned by a complete
    nutt^h^h^henthusiast from new, full documentation of everything he's
    ever done to it......
    <must resist>
    Thinking about it...... wonder if I could put in some track time on it?
    SteveH, Aug 22, 2003
  9. WorkTOG
    SteveH Guest
    Motorcycles Unlimited. Saw it on Biketrader.
    Here you go:
    http://atsearch.autotrader.co.uk/WWW/BIKES_popup.asp?miles=40&max_record
    s=50&modelexact=1&make=&model=&cc=2&postcode=MK109DD&search.x=0&search.y
    =0&start=1&distance=38&adcategory=BIKE&channel=BIKES&id=200333105761647
    SteveH, Aug 23, 2003
  10. WorkTOG
    The Older Gentleman was seen penning the following ode to ... whatever:
    There's also a bloke in Essex who's been advertising a Saxon Tour for
    395 in several issues of Classic Bike now. It's still in the current
    one...
    Timo Geusch, Aug 23, 2003
  11. <fx: legs it down to Smiths>
    The Older Gentleman, Aug 23, 2003
  12. WorkTOG
    <fx: Waits for 'sig change'>
  13. Austin Shackles, Aug 23, 2003
  14. glutton for punishment, innit...
  15. WorkTOG
    Sean Guest
    Bwahaha!. C'mon, you -are- taking the piss aren't you?. There are bodges,
    botches and kludges, but that one gets awarded the Hob-Nob of incredulity.
    Sean, Aug 23, 2003
  16. Honest truth, guv'nor. Still makes Oi larf to think about it.
