Multistrada will not start
Discussion in 'Australian Motorcycles' started by Steve, Jun 24, 2006.
  1. Steve
    Steve Guest
    The battery went flat, but the bike would start with a booster. after
    replacing with a new battery the bike will not go through the self
    check. The immobiliser light stays on (flashing) irresepective of the
    position of the key. none of the keys make it work including the
    dreaded RED key. Is there some sort of reset or anyway I can actually
    get it to run. On one occasion, with the main fuse removed it actually
    went through the correct routine. But of course would not start. When
    the fuse was replaced it then started
    (with the booster) but now removing the fuse has no effect. It does try
    to self check. (there is a noise). The RH indicator will flash once
    when the key is turned on. The parking and brake lights work. The
    hazard lights sometimes work.
    Steve, Jun 24, 2006
  2. Steve
    G-S Guest
    There is a small possibility that if you didn't do the jump start correctly
    that you damaged some of the electronics.
    Either way... I think it's time to see your Duck dealer...
    G-S
    G-S, Jun 24, 2006
