Multiple SCART Problem
Discussion in 'UK Motorcycles' started by sweller, Jun 20, 2008.
  1. sweller
    I have a SCART related difficulty. I've recently acquired a PVR (many
    thanks to Higgins) but don't have enough SCART sockets on my TV (many
    thanks to darsy) for the Cable box (thanks to Virgin/NTL), DVD/HDD
    recorder (many thanks to me), PS2 (many thanks to Ben) and the said PVR.
    The television has two sockets and (I think) the deterioration of the
    analogue signal going through all the boxes means I'm going to have to
    find a way of connecting all the various things to the television and not
    rely on the coax leads.
    Will this be a solution?
    http://www.maplin.co.uk/Search.aspx?criteria=L07BB&DOY=20m6
    How does it know which one to display and how will it work in practice?
    Currently the cable box is connected to the television with the aerial
    lead and a SCART to the DVD/HDD recorder. The DVD/HDD is attached to AV1
    with a SCART lead. The PVR is attached to AV2. The PS2 is looking
    forlorn with its lead on the floor.
    Or would some form of signal booster be the answer to cure the grainy
    feed to the television - that goes Cable box > PVR > DVD/HDD?
  2. sweller
    antonye Guest
    It'll work as long as they're not all trying to play at once!
    As you have two recorders (PVR & DVD/HDD) you want to make your
    mind up which one records which source (Cable or Aerial) as there's
    no point in it doing both?
    So something like:
    Cable > HD/DVD > AV 1
    Aerial > PVR > Multi > AV 2
    PS2 > "
    That way you can record from the cable box using the HD/DVD, as long
    as
    it has a pass-through so you can just watch Cable too. You can record
    through the aerial to your PVR or play on the PS2.
    BTW, if you want one of those multi-way scart boxes, they have
    them in my local Pound shoppe, so best you check your local
    one and save a bit of cash!
    antonye, Jun 20, 2008
  3. sweller
    Catman Guest
    Partly. It will work, but may be irritating in practice.
    It will probably show the last device to be turned on.
    These rock mightily
    http://cgi.ebay.co.uk/The-Ultimate-...photoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
    www.cuore-sportivo.co.uk
    Catman, Jun 20, 2008
  4. sweller
    RichardA Guest
    I've got a SCART switching unit if you want it, 4 x SCART (1xtv,
    3xSCART I/P and 6xphono). [1]
    [1] Bought over a year ago, never used and unopened, a couple of beer
    vouchers at the next 'osm if you want it. http://tinyurl.com/5sfqs6
    Richard
    XJ900S
    BOTAFOT #138, YTC#18, OMF#12
    Email-remove insult to reply
    RichardA, Jun 21, 2008
  5. sweller
    ST Guest
    Ive got one of these: http://www.maplin.co.uk/Module.aspx?ModuleNo=4724&criteria=scart&doy=21m6
    Does the job - just lets you select the source to view. Bought one
    about 10 years ago and it was getting flaky - £15 for a new one. New
    model is more robust and solid (metal case rather than plastic).
    ST, Jun 21, 2008
  6. sweller
    Emailed
    sweller, Jun 21, 2008
  7. sweller
    Dr Zoidberg Guest
    I've got a two way scart switcher that you can have for postage costs (or UR
    it) which would help , and as long as one other bit of equipment has two
    scars so you can daisy-chain things then you're sorted.
    Alex
    "I laugh in the face of danger , then I hide until it goes away"
    www.drzoidberg.co.uk
    Dr Zoidberg, Jun 21, 2008
  8. sweller
    frag Guest
    Quote from the FAQ on those devices:-
    Q) if i connect two units (dvd player and sky unit), does the unit
    which is most recently switched on have the priority ? - colin campbell
    A) these are unswitched so if 2 inputs are on at the same time it will
    display both - causing problems - L08BJ would be a better solution with
    automatic switching
    So its a bit thick.
    I'd use the other one they recommend, as that works the way you want
    http://www.maplin.co.uk/Search.aspx?criteria=l08bj&source=15&SD=Y
    frag, Jun 22, 2008
  9. sweller
    frag Guest
    frag, Jun 22, 2008
  10. sweller
    TD Guest
    AOL. But not needed in these heady days of component, DVI, HDMI, and some
    other shit.
    TD
    1991 VFR400R NC30 (black and red)
    2001 ZX-9R (red and black)
    1999 M5 (neither black nor red)
    Missing: SOB, Unreliable Italian exotica, Lardy tourer
    TD, Jun 22, 2008
  11. sweller
    Catman Guest
    Indeed. Got rid of mine some time ago.
    Catman, Jun 22, 2008
  12. sweller
    frag Guest
    Have you noticed how the HDMI equivalent bits cost 5 times as much?
    Fucking unwanted HDCP crap forcing the price up I bet.
    frag, Jun 22, 2008
  13. sweller
    Catman Guest
    Well it's gonna be a tad more complex shifting that digital stuff around.
  14. sweller
    frag Guest
    If they didn't have the HDCP digital security sessions and other
    complicated two way gubbins it'd be a hell of a lot easier and cheaper.
    <shrug>
    The DVDO switcher I've got can take a number of HDMI inputs, SVideo,
    RGB, analogue and digital audio, scales from anything to anything and
    has a number of other tricks up its sleeve (positive and negative audio
    delay for one - brilliant!) but it did cost half as much as the plasma.
    frag, Jun 22, 2008
  15. sweller
    Double Vaginal - Double Oral?
    Pip, Jun 22, 2008
  16. sweller
    davethedave Guest
    No use to man nor dog. Its for splitting out 1 signal to more than one
    VCR or device.
    For the input side you'll need an amplifiying video switch.
    such as
    http://www.maplin.co.uk/Module.aspx?ModuleNo=97941&doy=search
    You prod the appropriate button.
    davethedave, Jun 23, 2008
  17. sweller
    That's exactly the kind of thing we have at home. Works a treat, so long
    as you're not hopping between sources too often.
    ogden, Jun 23, 2008
