MPG
Discussion in 'UK Motorcycles' started by Muck, Mar 7, 2004.
  1. Muck
    Hmm.. Just worked out my CG mpg as 85.5 and my Bandit mpg as 41.6
    Is this bad? What do other peeps with Bandit 600s and CG125s get?
    Muck, Mar 7, 2004
  2. Muck
    Salad Dodger Guest
    Pitied.
    hth
    | ___ Salad Dodger
    |_\_____/_| ..62743../..14835.../..3157./.19406
    \|^|/ ANORAK#17
    Salad Dodger, Mar 7, 2004
  3. Muck
    Says the bloke with a GL1500.
    Vbg
    Muck, Mar 7, 2004
  4. Muck
    Molly Guest
    600s around 30mpg. CG125 about 21 million mpg.
    Molly
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    "Gower School" By Appointment".
    GSX-R1000 (a girly bike), Triumph Thunderbird, GS500, GHPOTHUF#27
    TGF, UKRMFBitchC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Molly, Mar 7, 2004
  5. Muck
    Heh.. 21 million? I thought for some reason that my CG125 did over 100mpg,
    maybe that was during running in though.
    Muck, Mar 7, 2004
  6. In uk.rec.motorcycles, Muck said:
    Depends, dunnit? I used to get about 100-110 before reserve on mine but
    that was stop start, stop start in the centre of London where you could
    go for more than a few yards without using the anchors.
    On a good run out I suppose 140?
    As for actual MPG, I never worked it out, sorry.
    Whinging Courier, Mar 7, 2004
  7. Muck
    I fill the Bandit up after 100 miles or so anyway, because I don't like
    going onto reserve. Hmm.. infact, I don't think the Bandit has ever been
    onto reserve, even after I did 130 miles without filling up on the way to
    last years EOSM.
    Muck, Mar 7, 2004
  8. In uk.rec.motorcycles, Muck said:
    I don't like going on reserve either. If you're getting 130 odd, that
    sounds ok to me, but I could be hideously wrong of course.
    My CBR's just gone on reserve after starting it and leaving it run a few
    times in my good lady's garden over the winter. Not sure if I want to do
    it again though as it might run out before I can get it to a garage...
  9. Muck
    Molly Guest
    Nice!
    Molly
    Molly, Mar 7, 2004
  10. Muck
    deadmail Guest
    30? Really?
    deadmail, Mar 7, 2004
  11. Muck
    Supprised me too, I'd always thought 40s were the norm.
    Muck, Mar 7, 2004
  12. Muck
    I'd just put some fogging oil in the cylinders, plug the exhaust pipes up,
    disconnect the battery, bung some petrol preserver in and put a cover on
    the thing.
    Got to be better than running it, that only builds up condensation inside
    the engine.
    Muck, Mar 7, 2004
  13. Muck
    jsp Guest
    !! That's got to depend on the bike. I used to get around 45 mpg
    (well, it was normally 13 litres to 130 miles) On long runs it was
    slightly better. On mad runs it went down a bit, as you'd expect.
    The SV does slightly less, which I didn't really expect. (13 litres to
    120/125 miles)
    "CG fuel economy matches Smart car shocker!"
    John
    SV650
    Black it is
    and naked
    jsp, Mar 7, 2004
  14. That's actually surprisingly shit compared with my notoriously thirsty
    unquote R80RT.
    Platypus - (unreal)
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    pseudoplatypus, Mar 7, 2004
  15. Muck
    Do behave.. A Bandit is an ok tool, to spend the whole time with the
    throttle pinned to the stop is 'tool' like riding imho.
    Not in the winter with greasy roads it's not.
    Muck, Mar 7, 2004
  16. Muck
    True. I was really wanting to know if my Bandit still had a healthy
    engine, as crap mpg can be a teller of a fucked lump.
    I'd much rather be on a CG thanks. Atleast I'm wearing a crash lid, so
    it's harder to see who I am.
    Muck, Mar 7, 2004
  17. Muck
    Economy can drop off with a fucked engine, that's why it's good to keep
    track of mpg if you can be fucked to.
    Heh..
    Muck, Mar 7, 2004
  18. In uk.rec.motorcycles, Muck said:
    I always thought I'd secretly snick a good ride out on it, which of
    course I haven't done. I don't know about condensation though because
    I'd leave the thing running for an hour and come back to it being like
    the opening of an oven door.
    True, I've heard this, and the poor thing is covered in a grey slimey
    film :-( but she starts no probs at all, even when there was snow on the
    seat and I hadn't started it for a month :)
  19. Muck
    Hmm.. not such a good thing to do. Riding a bike means that oil pressure /
    temp gets up to normal levels. Sitting a idle for an hour can thin oil too
    much leading to metal to metal contact in the engine, which is quite bad.
    For example, the manual for my old Rover V8 said that if the car wasn't
    driven off within a time limit, then you had to switch off, let things
    cool down and start again later.
    Slime on the outside is not so bad, slime on the inside is a lot worse
    imho.
    Muck, Mar 7, 2004
  20. In uk.rec.motorcycles, Muck said:
    Slime on the outside. I never bought a cover so she's exposed to the
    elements. Still, only five weeks to go :)
    <rubs hands with glee>
