Motorcycles and fuel economy: the good, the bad and the ugly
Discussion in 'UK Motorcycles' started by TOG@Toil, Sep 14, 2010.
  1. TOG@Toil
    Well enough to visit the family pile in Chalfont, on October 2nd, so I
    hear.
    wessie, Sep 20, 2010
  2. TOG@Toil
    Twibil Guest
    "Good chap"? Is that what you're calling hopeless psychopaths over
    there now?
    Never let it be said that the British are ill-mannered!
    Twibil, Sep 20, 2010
  3. TOG@Toil
    Henry Guest
    There's actually a pretty easy method to determine if
    someone is a deluded nutjob, or a rational, logical, and
    intelligent person.
    If you ask the latter to defend or explain his/her beliefs,
    the intelligent, rational person will cite hard evidence,
    credible expert research, science, physics, etc., and do so
    in a clear, logical, calm, and articulate manner.
    OTOH, ask a nutjob to defend or explain its beliefs, and
    the nutjob becomes offended, uncomfortable, and irrational,
    and its "thought" process pretty much shuts down. The nutjob,
    rather than defend its beliefs with evidence, research, or
    logic, will do one of several things - change the subject,
    shamefully run away confused and frustrated, or "attack"
    the person who's challenged its beliefs with childishly comical
    "insults", such as "You're a communist", "You're a janitor",
    "Your mother smokes crack", "You're a desperate, squirming,
    evasive, poor loser", etc..
    What the nutjob is pitifully and comically incapable of doing,
    is engaging in a calm, rational, open, and honest dialog of the
    relevant facts, research, and evidence.
    Let's give it a go, shall we? This little experiment is usually
    quite revealing - and fun - unless, of course, you happen to be
    a deluded and confused nutjob.... <vbg>
    The demolitions shown in the video below both display all
    the characteristics of controlled demolition, and none of
    fire induced failure, yet followers of the government's 9-11
    conspiracy theory try to tell us that one was caused by the
    partial, gradual, and random weakening of a small percentage
    of support columns due to gradual heating, and the other was
    caused by the total, instant, and symmetric destruction of all
    the support columns due to demolition. But obviously, partial
    is not total, gradual is not instant, and random is not
    symmetric. The contradiction is blatant and extreme. That's why
    no one can produce even *one* example of a steel framed high rise
    that dropped due to fire. Not one. Not ever. Not anywhere. It's
    physically impossible.
    http://tinyurl.com/c8c3q4
    Now, look at the buckled column in the photo linked below. That's
    the sort of gradual bending and sagging that would be caused by
    *extreme* heat. Of course, the fires in WTC7 never even got that
    hot nor did they even make contact with most of WTC7's massive
    hurricane and earth quake resistant steel frame.
    http://911research.wtc7.net/mirrors/guardian2/fire/SCI-3-6.jpg
    Photo from: http://911research.wtc7.net/mirrors/guardian2/fire/SCI.htm
    Here is some more expert research. Please tell us where you believe
    they are all mistaken as they use logic, physics, detailed evidence,
    and common sense, to prove that random, gradual heating can not possibly
    cause the free fall and symmetric drop of a steel framed high rise.
    http://wtc7proof.blogspot.com/
    http://11syyskuu.blogspot.com/2006/02/destruction-of-wtc-7.html
    Proof that WTC 7 was demolished professionally
    (This is a summary of the argument presented here, complete with more
    detailed source links, including Architects and Engineers for 9/11
    Truth.)
    WTC 7 was the third steel-framed skyscraper that was completely
    destroyed on 9/11. Unlike the Twin Towers, it was not hit by a plane.
    Its height was 174 meters, and it had 47 floors. It was located in a
    block separate from the other WTC buildings, 110 meters from the closest
    tower. The implosion of WTC 7 is shown below (note the dropping of the
    penthouse).
    Investigations. As this was one of the biggest building disasters in
    world history, the remains of the skyscraper should have been
    painstakingly investigated. If the building collapsed in seconds to the
    ground as a result of fires ? as FEMA speculated in 2002 ? the
    significance of the event for building safety, building codes, etc. is
    enormous. It would have been easy to properly examine the debris from
    the building, as it landed mostly within its own footprint. This was not
    done, and the physical research material was quickly removed and
    destroyed. According to NIST, the governmental agency that is still ?
    well after 6.5 years from the event ? trying to come up with a plausible
    report, ?no steel was recovered from WTC 7?. This can be seen as either
    suspicious or absurd, and I don?t think building disasters are
    investigated absurdly.
    The speed of destruction. WTC 7 fell into a pile of debris in
    approximately 6.5 seconds. The corresponding free fall time is 5.95
    seconds, while an apple dropped from the roof would have taken 7 seconds
    to fall to the ground (Kurttila 2005; the exact time varies with the air
    resistance of the object). The 80 steel support pillars of the building,
    therefore, did not in practice resist the destruction. However,
    destroying the support structures throughout the floors of the 174-meter
    building demanded energy that would have been away from pure kinetic
    energy; in other words, gravitational destruction of those structures
    would necessarily have slowed down the collapse. No slowing down
    required by destruction work can have taken place within the short time
    it took WTC 7 to collapse. To simplify: the roof came down as if mere
    air (and not 47 stories) had separated it from the ground. This can only
    be explained by the removal of structural resistance in a controlled
    demolition. In controlled demolitions, the roofs of highrises typically
    reach the ground in a time that is slightly longer than free fall. [1]
    The sudden onset and symmetry of the destruction. WTC 7 dropped suddenly
    straight down. This means that the 80 support pillars had to give in
    simultaneously. To believe that random fires on separate floors and
    damage to one side caused the sudden vertical collapse is to believe in
    a miracle (as pointed out by professor David Ray Griffin). Moreover,
    achieving the outcome of a controlled demolition by means of matches and
    damaging one side of a highrise would mean that companies specialized in
    controlled demolition would have to start thinking about new business ideas.
    Hot debris. According to NASA?s thermal imaging, the surface temperature
    of the WTC 7 debris pile exceeded 700 degrees Celcius ? five days after
    the destruction. Residual temperatures like this cannot be explained by
    fires or gravitational collapse. The latter can only result in a few
    degrees' increase in temperature.
    Molten and vaporized steel. As in the case of the Twin Towers, molten
    steel was reportedly found in the remains of WTC 7. Some steel samples
    that the researchers did manage to examine were also partially
    vaporized. In a New York Times interview, professor Jonathan Barnett
    points out that fires cannot explain this. Evidently, not even these
    samples were kept, and NIST has ignored this finding. Molten steel can
    be explained by explosives but not by fires, as their temperature simply
    cannot rise anywhere close to the melting point of steel, let alone the
    temperature required by vaporization.
    Expert statements. The Dutch demolition expert Danny Jowenko, who owns a
    demolition firm and has been in the business for 30 years, regards it as
    certain that WTC 7 was demolished. His view is shared by numerous
    architects, engineers and other demolition professionals ? see
    Architects and Engineers for 9/11 Truth, http://www.ae911truth.org/, and
    this page exemplifying people with demolition expertise who question the
    official account.
    The testimony of first responders. Several rescue personnel have
    testified to being told that WTC 7 would be brought down.
    [1] Another way of looking at this:
    1) In a vacuum, an object falls the height of WTC 7 in 5.95 seconds. An
    object falling in a vacuum does not crush, twist or displace anything ?
    not even air. If WTC 7 had collapsed in 5.95 seconds, not even air (let
    alone the rest of the building) would have separated its roof from the
    ground.
    2) WTC 7 collapsed into a rubble pile in approximately 6.5 seconds.
    3) As an object falling freely does not crush or twist anything, the
    time available for gravitational crushing or twisting of the building's
    ~80 steel columns throughout its 47 floors is slightly over 0.5 seconds
    (6.5 - 5.95 seconds) ? or, if you like, ~0.01 seconds per floor ( 0.5 / 47).
    4) The 0.5 seconds is not enough even in theory for a total
    gravitational collapse of a 174-meter highrise. Ergo, the structural
    resistance was removed by means of explosives.
    Let us know if you disagree with anything written below, and
    if so, what and why. The writer proves that gradual weaken due
    to heat couldn't possibly have caused WTC7's sudden, free fall,
    and symmetric drop, and he uses a clear, logical combination of
    evidence, basic physics, and common sense to do it.
    http://www.journalof911studies.com/letters/f/LeggeLastTry4.pdf
    "If you think about the nature of the collapse, supposedly due to
    fire weakening the steel, you will agree that it would only be
    necessary to follow the early stages of the collapse to determine
    its character. If heat is the cause, the steel will weaken gradually
    and will start to sag in the region where the fire is most intense.
    At that moment the steel will have almost enough strength to hold up
    the weight of the building, but not quite. So we have the force of
    gravity acting downwards, trying to produce an acceleration of 32
    feet per second per second, and the force of the hot steel pushing
    upwards, a force a bit less than that of gravity. Let us say we are
    looking at it at the moment when the strength has declined to the
    point where the steel is capable of pushing upwards with 90% of the
    force required to hold the building up against gravity. There would
    thus be a net downward force of 10% of gravity. Now acceleration is
    proportional to force and we have a net force of 10% of gravity
    so we would see an acceleration downwards of 3.2 feet per second
    per second.
    When you graph the data you find that the fall did not start with a
    motion which could be ascribed to a small net force of that order.
    The downward acceleration of the roof was very close to free fall
    right from the start, 30 feet per second per second, and continued
    at that rate until out of sight. There is no hint of a slow start.
    This tells us that the steel supports went from adequate strength to
    virtually no strength in an instant. For reasons stated above this is
    absolutely impossible if the loss of strength is due to the application
    of heat."
    -- http://911research.wtc7.net http://www.journalof911studies.com/
    "Condemnation without investigation is the height of ignorance." --
    Albert Einstein.
    Henry, Sep 21, 2010
  4. TOG@Toil
    Henry Guest
    Henry, Sep 21, 2010
  5. TOG@Toil
    M J Carley Guest
    It is unimportant: Cd = D/(1/2 rho V^2 S). Once you have a value for
    Cd, the length is irrelevant.
    What has Bernoulli to do with it?
    M J Carley, Sep 21, 2010
  6. TOG@Toil
    S'mee Guest
    <delurk> Indeed his premise is utter shite. Consider this in the mid
    90's a gentleman in the use designed and build a single enging home
    built aircraft (not an ultralight) whose frontal area was only 1sqft.
    His CD was good...not as good as some cars though. it's the hidden
    drag that's the issue. Also management of your airflow from the engine
    area, exhaust and rider placement. Oh and for the dingleberries who
    think the rims and tyres have an affect on the airflow...not as such,
    sorry.
    Now what's really interesting is the magpie attitudes of the fools who
    buy sprot bikes and all they care about is the front end* and care
    ****-all about the rear of the motorcycle that is SO damned dirty
    (aerodynamicly) that it practically sucks the motorcycle backwards.
    *same bunch of prats who only look at the boobs not the uh rear
    quarter and what makes her tick. ;^)
    S'mee, Sep 21, 2010
  7. TOG@Toil
    S'mee Guest
    actually you and that are wrong not sure you could understand why.
    It's one of those "VERY obvious things"
    and that right there is evidence that you don't know as much as you
    think you do.
    But at least you are trying unlike the cunts over in reeky and the
    states in general.
    S'mee, Sep 21, 2010
  8. TOG@Toil
    S'mee Guest
    There, there Pip no need to be nice to the leach...his kind are always
    picking fights to support their INSANE beliefs. Better to just club
    the bastards like baby seals, chuck the body in a deep lake and use
    the hide for gloves or some such.
    Or more politely he's insane and so is every person in those links of
    his...bigots the lot of them.
    S'mee, Sep 21, 2010
  9. TOG@Toil
    davethedave Guest
    Boobs! Where? I love boobs!
    davethedave, Sep 21, 2010
  10. TOG@Toil
    I'm not actually sure why I bothered answering: just exasperation I
    guess.
    Pip Luscher, Sep 21, 2010
  11. If ever you wanted a definition of a Netk00k, that would be Drain Man.
    The Older Gentleman, Sep 21, 2010
  12. TOG@Toil
    CT, Sep 22, 2010
  13. TOG@Toil
    SIRPip Guest
    Reference, please. You wouldn't get an engine and prop within a square
    foot, let alone wings, pilot and tail.
    SIRPip, Sep 22, 2010
  14. TOG@Toil
    davethedave Guest
    davethedave, Sep 22, 2010
  15. TOG@Toil
    SIRPip Guest
    Having suffered the outpourings of "Henry" on changing newsreaders (in
    the short time before he once again was consigned to the deepest corner
    of my killfile) I did notice that all his posts follow exactly the same
    pattern, and are in fact essentially the same bloody 100+ line post,
    pasted out again and again.
    I do wonder what he hopes to achieve by this, as any rational person
    reading one of his posts would have any glimmering of interest swiftly
    quashed upon reading the second identical post, and then the third and
    the fourth follow swiftly, guaranteeing to turn any reader against him.
    This led me inevitably to a mental picture of "Henry": small, fat, big
    googly eyes: just like a nasty little vacuum cleaner, switch stuck
    permanently on "BLOW".
    Just like this:
    http://ibm-1401.info/VacuumCleanerHenry-.jpg
    Only without the smiley face, obviously. Just as red in the face,
    however.
    Moreover, nasty things happen when Henry goes into "suck" mode:
    http://www.dailymail.co.uk/news/article-476560/
    SIRPip, Sep 24, 2010
  16. TOG@Toil
    M J Carley Guest
    Outside of aeronautical engineering, drag coefficients are fairly
    universally based on frontal area. Once you measure, or calculate, the
    drag coefficient for a given shape, the length of the body does not
    affect the drag. It is always (mod Re and Ma effects, neither of which
    are relevant here) given by Cd.V^2.rho.S/2.
    If it's very obvious, you'll have no trouble explaining it.
    You can measure a drag coefficient even if you have never heard of
    Bernoulli (which one did you have in mind, by the way?), unless you
    know otherwise.
    M J Carley, Sep 24, 2010
