motorcycle weight (honda)
Discussion in 'Motorbike Technical Discussion' started by moose34, Apr 1, 2006.
  1. moose34
    moose34 Guest
    can someone please tell me what the dry weight of an 86 or 87 Rebel 450
    is?
    thanks in advance. I haven't had much luck with the search engines.
  2. moose34
    LJ Guest
    Courtesy google:<"honda rebel"&"450"& "Dry weight'>
    Contents:
    Honda Nighthawk 450 for 1986, 2 pages, color, specs. Specifications
    1986 NIGHTHAWK 450
    ENGINE 447cc parallel twin-cylinder
    BORE AND STROKE 75mm x 50.6mm
    COMPRESSION RATIO 9.3:1
    Carburetors Two 34mm CV
    IGNITION Solid State
    STARTER Electric
    TRANSMISSION Five-speed plus over drive sixth
    DRIVELINE 0-ring sealed chain
    WHEELBASE 57.1 inches
    SEAT HEIGHT 30.9 inches
    FUEL CAPACITY 3.2 gallons, including 0.5 gallon
    reserve
    WHEELS Cast alloy
    TIRES Front: 100/90-19 tubeless
    Rear: 130/90-16 tubeless
    SUSPENSION Front: Air-adjustable forks with
    dual Syntallic bushings
    Rear: VHD shocks
    BRAKES Front: Disc with twin-piston
    caliper
    Rear: Drum
    DRY WEIGHT 392.5 pounds
    COLORS Red, Blue
    OPTIONAL Nylon luggage (saddlebags, trunk
    HONDALINE bag, tank bag), leather saddle-
    EQUIPMENT bags, engine guard, luggage rack
    and backrest.
    LJ, Apr 1, 2006
  3. moose34
    moose34 Guest
    thanx.
    moose34, Apr 2, 2006
