Motorcycle power socket
Discussion in 'UK Motorcycles' started by Gavin, Feb 21, 2010.
  1. Gavin
    Catman Guest
    I don't think so, TBH.
    I've read far worse in fiction.
    www.cuore-sportivo.co.uk
    Catman, Feb 22, 2010
  2. Gavin
    Surely a box of matches wrapped up in clingfilm would be simpler to
    implement?
    platypus, Feb 22, 2010
  3. Gavin
    Don't get me started.
    I know a lot about matches, see. When I was four or five years old, I
    Discovered the joys of fire, growing up in a house where the only
    heating was from two open coal fires. Saturday and Sunday mornings I
    would always be first up, and I'd spend ages coaxing the living room
    fire back to life, feeding the last embers with strips of tissue,
    paper, cardboard and shredded kindling.
    By six or seven, I was into lighting fires: on the beach with driftwood
    and any other combustibles that had washed up or blown in; in the woods
    with dead fallen limbs; in fields with dry wood ... or one very
    memorable occasion, tall dry grass.
    The source of ignition was always matches, of course. Dad had a
    lighter, a proper old shiny chromed steel Ronson with a leather cover
    but there were no cheap disposable lighters then, so kids used matches.
    Proper matches with red sulphurous heads, none of your girly safety
    matches. We'd light little fires in alleys, round the back of the
    shops, anywhere there was something that would burn. We experimented
    with trying to recreate the blazing torches we'd see on telly, but
    they'd either go out too quickly or they'd burn far too fast to be
    useful for anything except burning skin and clothing.
    We discovered the joy of striking a match and while it was still
    flaring, stick it back into the box next to the other match heads -
    that made a great, intense flare that was sadly short-lived. Access to
    petrol was, fortunately, difficult - but we could get paraffin, meths
    and turps. We made big flares that burned gloriously, we made better
    flaming torches, we lost layers of skin and patches of hair joyously.
    We discovered building sites, and the cornucopia of flammables therein.
    Bonfires weren't restricted to November and it was open season on
    scarpering from incoming blue lights down carefully pre-planned routes
    through narrow alleys and over walls where adults wouldn't pursue.
    That all came to an end with the first serious burning, when one of the
    big boys discovered the exquisite agony inflicted by burning tar on a
    nylon shirt.
    When I went to Cubs, my firelighting skills were in great demand: on
    the beach or in the hills, we'd drag soggy sossijjes out of greasy
    pockets and cook them over fires on sharpened sticks. One-match (Swan
    Vesta, natch - favoured despite their short length for the sheer
    quantity in a box) fires were a source of great pride, but OTOH the
    flint and steel in a tinderbox was always in my pocket, and I could
    smoulder up a spark from a bow quite well too.
    Later, on expeditions I found that drying out clothing (that had
    contained pocketed matches that had got wet) over a fire was a bad
    idea. Wet match heads roll off the wood, leaving smears of sulphur and
    phosphorous in the material. So not only were the matches useless
    except for use as small kindling when they'd dried out, the deposits
    within the pockets went up a treat once they'd got hot enough. Not
    only do slightly singed trousers feel awkward, explaining loss of
    pockets to parents was a little awkward too. "A big boy did it and ran
    away" doesn't really cut it in that scenario.
    We didn't have cling film then, and the ostensibly watertight tobacco
    tins crammed with 'survival' gear didn't always work that well. So I
    started dipping matches in molten candlewax. Wax-impregnated matches
    flare really well, you know - I've got pink fingertips from skin loss
    due to that still. The best way, I found, was to tape several matches
    together side-by-side, and dip them like a line of soldiers. They
    could be broken out individually when required and the middle matches
    were less heavily waxed, so burned in a more predictable fashion.
    I have tried clingfilming matches in later years, but the advent of
    cheap lighters has gone past that - it's easier to keep a lighter dry,
    or use a Zippo which doesn't suffer from moisture ingress so badly if
    you keep a flint in the cottonwool. I don't think I've ever had great
    success with clingfilm, in fact - getting a good seal seems to be a
    problem, as is condensation (probably of sweat in a pocket) and age
    seems to be an issue too. A ziplock resealable bag is prolly better,
    but I think the alternatives are superior and easier.
    Now you've made me cast my mind back, I can smell the aroma of snared,
    skinned and spitted rabbit smoking over one of my fires now. I'll draw
    a tactful veil over my later, more adult firelighting activities, as
    there's prolly no Statute of Limitations on them.
    Suffice to say, I know matches.
    Pip, Feb 22, 2010
  4. Gavin
    Pete Fisher Guest
    How about wrapping several matches tightly in 'Bacofoil' then throwing
    them in the fire? That's discounting the experiments with the contents
    of proper old fashioned FOAD bangers, DIY gunpowder and fuses made from
    string and saltpetre solution.
    The lad was trying that method only recently without much success. I
    blame 'Safety Matches'.
    Matchless prose !
    | Pete Fisher at Home: |
    Pete Fisher, Feb 22, 2010
  5. Gavin
    Oh, yeah. We were into that - shaving the heads into a square of foil
    was effective in making a satisfying 'crack' when it got hot enough: a
    subtle way to get the Girl Guides shrieking by slipping one into their
    fire too. With just the heads in foil, smashing the package between
    two big stones made a good bang and produced a great cloud of stinking
    smoke too.
    Aye. We started off with "genies" made by laying the contents of a
    proper banger on the ground and lighting it. Then we had to go bigger,
    of course, so it became a pile of the contents of several fireworks ...
    which later led to experiments with fuses as the girls really didn't
    like the look of blokes with no eyebrows and apparent premature male
    pattern baldness.
    Yeah, doesn't work with Safeties. The inevitable traces of wax get in
    the way and clog up the striker on the box immediately, aprt from
    interfering with the chemical ignition sequence.
    I thank you, Sir. I am only one of many here, and a mere acolyte to
    some.
    Pip, Feb 22, 2010
  6. Gavin
    Catman Guest
    Pip wrote:
    I feel it encumbent upon me to point out that I don't *think* there was
    a single swear word in that lot......
  7. But you omitted one thing - modifying them into bangers. We used to wrap
    Swan Vesta heads in silver foil, tightly, and then chuck them into fires
    or otherwise ignite them.
    And they'd go off like firecrackers with a surprisingly loud BANG.
    If you had the patience to (carefully) scrape the heads off a whole box
    ofthe things, you had a surprisingly powerful miniature explosive.
    For some reason safety matches just when "phut" under the same
    treatment.
    The Older Gentleman, Feb 22, 2010
  8. Gavin
    'Proper' delinquents got a 3/4" bolt, wound a corresponding nut onto
    it so just under 1/3 of the nut was on the bolt, put the scraped off
    heads of about 20 swan vesta matches into the open half of the nut and
    then tightened another bolt onto the match heads. The real knack here
    was to tighten the bolts together enough to make a good tight
    connection but not set the matches off or you might lose fingers.
    Once this was done you hurled the whole lot at the road as hard as you
    could and relied on one of the bolt heads making a good solid contact.
    If all went well the IED shot off into the distance and might travel
    a couple of hundred yards before either running out of energy or
    hitting something. Big fun when you're 11 years old.
    When I was an apprentice we played a similar game with 1" bolts but
    put the powder out of .22 blanks into the gap. We then put the device
    horizontally in a vice, smashed one end with a 4lb hammer and watched
    the other end of the device fly off up the workshop into whatever
    you'd aimed it at. This sort of toy would go through doors. Big fun
    when you're 16 years old.
    I really enjoyed engineering when I was younger.
    Andy Bonwick, Feb 22, 2010
  9. Gavin
    Jeweller Guest
    Heartfelt thanks due to Beav for prompting that glorious monologue.
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo, R80/7, R100RT
    (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Feb 22, 2010
  10. Gavin
    frag Guest
    Pip took a blunt brush and painted...
    <snip>
    Applause! Nice story, as always Pipster.
    Personally I'm a cheapo plastic lighter man, simply cause I lose them a lot.
    frag, Feb 22, 2010
  11. Gavin
    'Hog Guest
    Oh indeed with patience a schoolboy can prime his first flintlock pistol and
    half inch ball bearing mortar.
    Of course the danger is escalation to stripping out shotgun cartridges which
    inevitably leads to commercial explosives and from there the sky is the
    limit......
    'Hog, Feb 22, 2010
  12. Oi! Hog! Check your SMS messages and emails!
    Ta.
  13. Gavin
    'Hog Guest
    Does the email addy start sm911 as per the header and does the phone number
    end 333
    If not that would be why I've not heard anything
    Though you also have my work email addy
    'Hog, Feb 22, 2010
  14. I recall doing that when I was a kid too. Back when you could buy
    proper fireworks legally. Ones that would take out the neighbour's
    letterbox in a big way.
    Another one when I was in army cadets at school was to throw sealed
    cans of army issue vegemite into the bonfire we were all sitting
    around. They go off quite nicely but we a small can, probably 50-100g
    max. Some bright spark chucked in a sealed can of concentrated butter.
    Like a 600g can. I saw it enter the bonfire and asked him what it was.
    ****! Run!. It went off like a bloody mortar and the bits burned hole
    in a nearby tent.
    Kev
    Kevin Gleeson, Feb 22, 2010
  15. Just email me. Have a pig to collect first weekend in March.
  16. Gavin
    boots Guest
    The flash would leave you with disturbed vision for hours afterwards
    and indoors made far too much smoke to explain away to parents.
    How no one got seriously injured when my school went through this
    craze I am not sure.
    boots, Feb 22, 2010
  17. Gavin
    Dan L Guest
    A 33cl bottle of lager bedded into the coals of a hot BBQ is fairly
    spec-tac-lee-arr
    Dan L, Feb 22, 2010
  18. Gavin
    petrolcan Guest
    Drop the head off at Riley Avenue.
    petrolcan, Feb 22, 2010
  19. Gavin
    Beav Guest
    I was almost tempted to not snip and simply add... "You've given this some
    thought, haven't you"? :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 22, 2010
  20. Gavin
    Beav Guest
    Or a small length of neoprene tubing that'll fit in the tank filler hole. It
    could also double as a tank siphoning tool if the bike runs out of fuel.
    Can't see it getting fuel out of the Zippo though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 22, 2010
