Motorcycle oil
Discussion in 'UK Motorcycles' started by Speedgazebo, Jan 19, 2004.
  1. Speedgazebo
    Speedgazebo Guest
    There is an article in this months 'Bike' magazine about , amongst other
    things, oil, is says that you should not use 'car' oil, presumably GTX and
    the like in a bike as the gearbox action chops up the molecules and reduces
    the lubrication qualities, I have used 10/40 GTX in my bikes for years and
    never had a problem. Has any one here ever had a problem due to using 'car'
    oil?
    Nick
    1200 Bandit KMX 200
  2. Speedgazebo
    Oldbloke Guest
    Google for my tale of a 2 stroke **** up last month.
    Since replacing the erroneous 2 stroke oil with some left over synthetic
    Volkswagen stuff the little TS seems fine.
    The SAE number was similar (but not the same) as that recommended in the
    HBOL.
    Oldbloke
    My Bike - 2000 Honda CB500
    M'boy's Bike - 1990 Suzuki TS50X
    i Bike - MotoRumi Junior Gentleman
    BOTAFOT #140
    "He's like Robbo's chubby kid brother"
    Oldbloke, Jan 19, 2004
  3. Speedgazebo
    PeterT Guest
    Speedgazebo
    Gearbox chopping up molecules?
    PeterT, Jan 19, 2004
  4. I don't think it's chopping up the oil molecules...
    Nope. But I use bog standard Halfords own brand, and change it
    often.
    William Grainger, Jan 19, 2004
  5. Speedgazebo
    dwb Guest
    Personally I think the cost is negligible, so what's the point in skimping?
    dwb, Jan 19, 2004
  6. Speedgazebo
    A.Lee Guest
    I used cheapish car oil on my despatch bike for 3 years, and when I jacked
    it in, I took the head off to check for wear - not even a slight ridge in
    the bores.Obviously an unscientific example. AIUI, bike engines have a
    higher power/weight performance than car engines, with a lower amount of
    oil in the sump, so the oil has to work a little bit harder than a typical
    car engines oil.So long as your oil meets the recommended standards, then
    it will be fine.I reckon the best thing is to make sure you change the oil
    regularly, my despatcher was done every 3000 miles, even though it was
    recommended every 5000 miles.
    Alan.
    A.Lee, Jan 19, 2004
  7. It's bollocks.
    The Older Gentleman, Jan 19, 2004
  8. Speedgazebo
    Buzby Guest
    Dunno. I always used miller diesel engine oil in my FJ for about 35k as
    recommended by them wot knows at the FJOC, so I suspect it's complete
    bollocks.
    Buzby
    Buzby, Jan 19, 2004
  9. Speedgazebo
    PDannyD Guest
    What utter arse. Many cars use 'engine' oil in their gearboxes.
    FZS600 - silver/black
    GS125 - black/rust
    '81 Bobtail - vaguely green (FOR SALE £800)
    CAAD7 - black
    LTS2 - blue, not black
    OE6 + Quotefix
    PDannyD, Jan 19, 2004
  10. Speedgazebo
    Chris H Guest
    I have three comments...
    1) Use a cheap oil and change it often...
    2) ..but don't use gas turbine oil, even if you can get it free, because
    a) It's monograde and b) it buggers all of the oil seals [1].
    3) Don't expect to read technical articles in bike magazines that aren't
    bollocks. In this case probably 'sponsored' by the oil companies [2]
    Chris H,
    CBR600FK-1, two#55
    Please remove veg to reply
    [1] Don't ask me how I know this. I just know that it will.
    [2] i.e relying on their experts/spokespersons and promotional
    literature.
    Chris H, Jan 19, 2004
  11. Speedgazebo
    Alan.T.Gower Guest
    They are very, very big molecules.
    Alan.T.Gower, Jan 19, 2004
  12. Speedgazebo
    deadmail Guest
    Well the difference between fully synth at 25- for 4l and GTX at 8 is
    not really 'negligible' is it.
    deadmail, Jan 19, 2004
  13. Speedgazebo
    deadmail Guest
    What's the argument behind using a "diesel" oil in a bike?
  14. Speedgazebo
    mb Guest
    Different spec I suppose.
    Hardley Davidson recommend Diesel engine oil if you can't find genuine
    Harley oil...
    mb, Jan 19, 2004
  15. Speedgazebo
    wrote in
    GTX comes in 5l packs, so even better value. Last time I bought one of the
    10W/40 Eurolight GTX [1] it came with a free 1l pack too. Very handy it is.
    Packs neatly into luggage for trips away, no spillage and it has a nice clear
    strip on the side so you know how much oil you've put in.[2]
    [1] bit dearer than cooking GTX but the recommended viscoscity for my bike
    [2] easy to overfill the boxer so I only add oil in 200ml slugs
    wessie, Jan 19, 2004
  16. But these molecules are close.
  17. Speedgazebo
    Buzby Guest
    Nothing. Engine oils are all basically the same (give or take viscosity etc)
    and the one oil that the FJOC found to suit the FJ just happened to be a
    'diesel' engine oil. I suppose it could just as easily work the other way
    around.
    Buzby
    Buzby, Jan 19, 2004
  18. Buzby said:
    It's usually got more detergent in it. Might keep the engine cleaner?
    Simon Atkinson, Jan 19, 2004
  19. Speedgazebo
    deadmail Guest
    Some cash and carry did a deal on GTX recently- can't remember who but I
    bought four five litre containers for 6 quid (plus vat) each.
    Which was nice.
    But more concerningly, what am I meant to do with all the used oil. I
    had a look around my garage and counted 7 5l containers and 1 25l drum
    of it. So that's about 60l of used engine oil.
    I wonder if I should just put the odd 5l container into the tank of my
    diesel car or maybe run it through my central heating. It seems a shame
    to simply waste it. I mean, road diesel is almost 80p a litre and on
    that basis I've almost 50 quids worth...
  20. Speedgazebo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Just an idea here, take it or leave, do what you will:
    Used engine oil is quite flammable if you get a reasonable fire going
    first.
    Now, let your imagination run wild.
    Nigel Eaton, Jan 19, 2004
